I have a computer with ONLY ONE MONITOR - these are the specs:
Ubuntu 15.04 - 32 bits
Processor Intel® Pentium(R) Dual CPU E2180 @ 2.00GHz × 2
Graphics Intel® G33 x86/MMX/SSE2
$ lspci -v | grep -i vga
00:02.0 VGA compatible controller: Intel Corporation 82G33/G31 Express Integrated Graphics Controller (rev 10) (prog-if 00 [VGA controller])
# lshw -class display
PCI (sysfs)
  *-display
       description: VGA compatible controller
       product: 82G33/G31 Express Integrated Graphics Controller
       vendor: Intel Corporation
       physical id: 2
       bus info: pci@0000:00:02.0
       version: 10
       width: 32 bits
       clock: 33MHz
       capabilities: msi pm vga_controller bus_master cap_list rom
       configuration: driver=i915 latency=0
       resources: irq:28 memory:feb00000-feb7ffff ioport:e140(size=8) memory:d0000000-dfffffff memory:fe900000-fe9fffff
$ xrandr
Screen 0: minimum 8 x 8, current 1024 x 768, maximum 32767 x 32767
VGA1 connected primary 1024x768+0+0 (normal left inverted right x axis y axis) 0mm x 0mm
   1024x768       60.0*
   800x600        60.3     56.2
   848x480        60.0
   640x480        59.9
VIRTUAL1 disconnected (normal left inverted right x axis y axis)
$ sudo xrandr --newmode "1680x1050_60.00"  146.25  1680 1784 1960 2240  1050 1053 1059 1089 -hsync +vsync
$ sudo xrandr --addmode VGA1 1680x1050_60.00
$ xrandr
Screen 0: minimum 8 x 8, current 1680 x 1050, maximum 32767 x 32767 VGA1 connected primary 1680x1050+0+0 (normal left inverted right x axis y axis) 0mm x 0mm
1680x1050 60.0*+ 1024x768 60.0
800x600 60.3 56.2
848x480 60.0
640x480 59.9
1680x1050_60.00 60.0
This works (changes the resolution), then I do
$ sudo reboot
and on start I get the previous resolution and the following message
No se pudo aplicar la configuración almacenada para los monitores
none of the selected modes were compatible with the possible modes:
Trying modes for CRTC 63 CRTC 63:
trying mode 1024x768@60Hz with output at 1680x1050@60Hz (pass 0)
CRTC 63: trying mode 800x600@60Hz with output at 1680x1050@60Hz (pass 0)
CRTC 63: trying mode 800x600@56Hz with output at 1680x1050@60Hz (pass 0)
CRTC 63: trying mode 848x480@60Hz with output at 1680x1050@60Hz (pass 0)
CRTC 63: trying mode 640x480@60Hz with output at 1680x1050@60Hz (pass 0)
CRTC 63: trying mode 1024x768@60Hz with output at 1680x1050@60Hz (pass 1)
CRTC 63: trying mode 800x600@60Hz with output at 1680x1050@60Hz (pass 1)
CRTC 63: trying mode 800x600@56Hz with output at 1680x1050@60Hz (pass 1)
CRTC 63: trying mode 848x480@60Hz with output at 1680x1050@60Hz (pass 1)
CRTC 63: trying mode 640x480@60Hz with output at 1680x1050@60Hz (pass 1)
Trying modes for CRTC 64
CRTC 64: trying mode 1024x768@60Hz with output at 1680x1050@60Hz (pass 0)
CRTC 64: trying mode 800x600@60Hz with output at 1680x1050@60Hz (pass 0)
CRTC 64: trying mode 800x600@56Hz with output at 1680x1050@60Hz (pass 0)
CRTC 64: trying mode 848x480@60Hz with output at 1680x1050@60Hz (pass 0)
CRTC 64: trying mode 640x480@60Hz with output at 1680x1050@60Hz (pass 0)
CRTC 64: trying mode 1024x768@60Hz with output at 1680x1050@60Hz (pass 1)
CRTC 64: trying mode 800x600@60Hz with output at 1680x1050@60Hz (pass 1)
CRTC 64: trying mode 800x600@56Hz with output at 1680x1050@60Hz (pass 1)
CRTC 64: trying mode 848x480@60Hz with output at 1680x1050@60Hz (pass 1)
CRTC 64: trying mode 640x480@60Hz with output at 1680x1050@60Hz (pass 1)
Trying modes for CRTC 65
CRTC 65: trying mode 1024x768@60Hz with output at 1680x1050@60Hz (pass 0)
CRTC 65: trying mode 800x600@60Hz with output at 1680x1050@60Hz (pass 0)
CRTC 65: trying mode 800x600@56Hz with output at 1680x1050@60Hz (pass 0)
CRTC 65: trying mode 848x480@60Hz with output at 1680x1050@60Hz (pass 0)
CRTC 65: trying mode 640x480@60Hz with output at 1680x1050@60Hz (pass 0)
CRTC 65: trying mode 1024x768@60Hz with output at 1680x1050@60Hz (pass 1)
CRTC 65: trying mode 800x600@60Hz with output at 1680x1050@60Hz (pass 1)
CRTC 65: trying mode 800x600@56Hz with output at 1680x1050@60Hz (pass 1)
CRTC 65: trying mode 848x480@60Hz with output at 1680x1050@60Hz (pass 1)
CRTC 65: trying mode 640x480@60Hz with output at 1680x1050@60Hz (pass 1)
karel
  • 122,292
  • 133
  • 301
  • 332
Tabula Rasa
  • 33
You need to add the xrandr configurations to a startup file, so that you'll get your desired resolution upon reboot/startup:
  • Create a bash script, xrandr.sh for example, and place your xrandr commands into it:
#!/bin/bash
xrandr --output VGA1 --mode 1680x1050_60.00
  • Make the script executable with chmod +x xrandr.sh
  • Search for "Startup Applications" in the dash, run it, and add the script as a startup application.
The commands will now run every time you log into your account.
TellMeWhy
  • 17,964
  • 41
  • 100
  • 142
