I am planning to upgrade my current 9.04 server version to 12.04LTS server.
I've successfully backup and restore my Cacti version 8.7d to 8.7i that comes with the distribution.
However, the plugin patch installation for PIA 3.1 it is not working for only ubuntu.
Can you assist? or it's there a way to include Cacti 8.8a which is a stable version which comes with PIA 3.1 preinstalled.
regards, thomas
Kevin Bowen
  • 20,055
  • 57
  • 82
  • 84
Pininy
There has been a backport created for Cacti 0.8.8a for use in 12.0.4.
You can read the details about it in this Launchpad bug issue:Please backport cacti 0.8.8a-3 (universe) from quantal to precise
To upgrade your Cacti installation from 8.7i to 8.8a, perform the following commands from a terminal:
sudo add-apt-repository ppa:micahg/ppa
sudo apt-get install cacti
You should now be able to use the new Cacti Plugin Architecture.
The latest plugins can be downloaded from http://docs.cacti.net/plugins
In order to install the plugin, change to the directory where it was downloaded. The default directory for cacti plugins is /usr/local/share/cacti/plugins/
Execute the following command:
sudo tar -xvf <insert-plugin-file-name-here>.tgz -C /usr/local/share/cacti/plugins/
The newly installed plugin should now be showing up in the cacti menu Console --> Plugin Management
Kevin Bowen
  • 20,055
  • 57
  • 82
  • 84
