Possible Duplicate:
How do I set Windows to boot as the default in the boot loader?
How to set Windows 7 as default for booting? I am using Dual boot in my laptop. And how do i later shift to Ubuntu easily?
Here are the steps to follow:
1- To edit the grub file open terminal and type the following command :
sudo gedit /etc/default/grub
You will got something like this :
GRUB_DEFAULT=0
#GRUB_HIDDEN_TIMEOUT=0
GRUB_HIDDEN_TIMEOUT_QUIET=true
GRUB_TIMEOUT=10
GRUB_DISTRIBUTOR=`lsb_release -i -s 2> /dev/null || echo Debian`
GRUB_CMDLINE_LINUX_DEFAULT=”quiet splash”
GRUB_CMDLINE_LINUX=””
# Uncomment to disable graphical terminal (grub-pc only)
#GRUB_TERMINAL=console
# The resolution used on graphical terminal
# note that you can use only modes which your graphic card supports via VBE
# you can see them in real GRUB with the command `vbeinfo’
#GRUB_GFXMODE=640×480
# Uncomment if you don’t want GRUB to pass “root=UUID=xxx” parameter to Linux
#GRUB_DISABLE_LINUX_UUID=true
# Uncomment to disable generation of recovery mode menu entrys
#GRUB_DISABLE_LINUX_RECOVERY=”true”
Now to change the boot order, you need to change the GRUB_DEFAULT Entry, for example you have windows7 in the 3rd position and you want to set it as default, to do that set default to 3: GRUB_DEFAULT=3
2- Now update Grub using the command:
sudo update-grub
And is done!
