11
I need help to resize my LV: /dev/mapper/ubuntu--vg-ubuntu--lv
The ubuntu installation is a VM, and the disk has been expanded from 8 GB to 11 GB. How do I resize / expand the /dev/mapper/ubuntu--vg-ubuntu--lv volume?
sudo pvdisplay:
  --- Physical volume ---
  PV Name               /dev/vda3
  VG Name               ubuntu-vg
  PV Size               8.46 GiB / not usable 3.00 MiB
  Allocatable           yes
  PE Size               4.00 MiB
  Total PE              2166
  Free PE               503
  Allocated PE          1663
  PV UUID               fhw3L2-RTCL-wu3w-WovP-6pGF-iQjv-tujWKE
sudo vgdisplay:
--- Volume group ---
  VG Name               ubuntu-vg
  System ID
  Format                lvm2
  Metadata Areas        1
  Metadata Sequence No  3
  VG Access             read/write
  VG Status             resizable
  MAX LV                0
  Cur LV                1
  Open LV               1
  Max PV                0
  Cur PV                1
  Act PV                1
  VG Size               8.46 GiB
  PE Size               4.00 MiB
  Total PE              2166
  Alloc PE / Size       1663 / <6.50 GiB
  Free  PE / Size       503 / 1.96 GiB
  VG UUID               ZTcc3J-A3jZ-olN4-rFGR-h40F-wqFD-c3hmCn
sudo lvdisplay:
  LV Path                /dev/ubuntu-vg/ubuntu-lv
  LV Name                ubuntu-lv
  VG Name                ubuntu-vg
  LV UUID                Q31Qia-F92v-te0V-P1fH-4SXv-3uB8-4889p0
  LV Write Access        read/write
  LV Creation host, time ubuntu-server, 2021-10-02 09:59:32 +0200
  LV Status              available
  # open                 1
  LV Size                <6.50 GiB
  Current LE             1663
  Segments               1
  Allocation             inherit
  Read ahead sectors     auto
  - currently set to     256
  Block device           253:0
More info added:
GPT PMBR size mismatch (20971519 != 23068671) will be corrected by write.
The backup GPT table is not on the end of the device. This problem will be corrected by write.
Disk /dev/vda: 11 GiB, 11811160064 bytes, 23068672 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: gpt
Disk identifier: 07C77B10-B73C-442D-9F03-A422017A6AE9
Device Start End Sectors Size Type /dev/vda1 2048 1050623 1048576 512M EFI System /dev/vda2 1050624 3147775 2097152 1G Linux filesystem /dev/vda3 3147776 20899839 17752064 8.5G Linux filesystem
Disk /dev/mapper/ubuntu--vg-ubuntu--lv: 6.51 GiB, 6975127552 bytes, 13623296 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
When I try sudo lvextend -l 100%VG ubuntu-vg/ubuntu-lv I get:
/etc/lvm/archive/.lvm_outlineserver_26853_1055914493: write error failed: No space left on device
And when I try sudo fdisk -l /dev/mapper/ubuntu--vg-ubuntu--lv:
and last when I try sudo resize2fs /dev/mapper/ubuntu--vg-ubuntu--lv I get:
resize2fs 1.45.5 (07-Jan-2020) The filesystem is already 1702912 (4k) blocks long. Nothing to do!
julianb
  • 113
I'm not really sure what you have done so far. The partition /dev/vda3 has been increased to 8.5 GB (which means 10GB of the disk are used), but the end of partition vda3 (20899839) is less than the end of the "physical" disk (23068672), see the output of fdisk -l. Maybe GPT PMBR size mismatch (20971519 != 23068671) gives some hint.
Anyway, parts of the LVM structures (pv and vg) are already reflecting the new size. What is missing is the size of the logical volume and the size of the filesystem. As you can see from pvdisplayand vgdisplay, there are 503 extents = 1.96 GiB still free.
So, first increase the size of the logical volume to that of the volume group:
fdisk -l /dev/mapper/ubuntu--vg-ubuntu--lv should then give you the new size of ~ 8.5 GB.
Now, increase the size of the filesystem to that of the logical volume (I suppose ext4 here for '/'; if it is a different filesystem, you will have to use a different command!):
This is possible for a mounted filesystem, when the kernel supports it, which all recent kernels should do.
For more information, see man lvextend and man resize2fs. Or Please help me work out what is happening with the available space on my VM's LVM2 partition
ridgy
  • 2,516
