Ubuntu Server and here is what I have:
When running lsblk I get this
fd0                   2:0    1     4K  0 disk
sda                   8:0    0  1000G  0 disk
├─sda1                8:1    0   487M  0 part /boot
├─sda2                8:2    0     1K  0 part
└─sda5                8:5    0 199.5G  0 part
  ├─mail03--vg-root 252:0    0 126.3G  0 lvm  /
  └─mail03--vg-swap 252:1    0  65.8G  0 lvm  [SWAP]
sdb                   8:16   0   500G  0 disk
sr0                  11:0    1   667M  0 from
When running df -h I get this
Filesystem                   Size  Used Avail Use% Mounted on
udev                         4.4G     0  4.4G   0% /dev
tmpfs                        900M   97M  803M  11% /run
/dev/mapper/mail03--vg-root  125G  114G  4.2G  97% /
tmpfs                        4.4G  4.0K  4.4G   1% /dev/shm
tmpfs                        5.0M   44K  5.0M   1% /run/lock
tmpfs                        4.4G     0  4.4G   0% /sys/fs/cgroup
/dev/sda1                    472M  108M  340M  25% /boot
tmpfs                        900M     0  900M   0% /run/user/1000
sda has 1000G but the partition mounted on / has only 125G
Is it possible to extend the /dev/mapper/mail03--vg-root filesystem ?
If not can you help me please how to mount space from sda ?
I also don't want to lose any data from /dev/mapper/mail03--vg-root
Thanks !
Try running sudo resize2fs /dev/sda1 25G and replace /dev/sda1 with the path to your drive. Also, replace 25G with the size that you want. If you want it to make up the entire 1000G, replace 25G with 1000G. It may not allow it, because of other partitions (ex. SWAP) on the disk that take up other space. If it doesn't allow it, use the GNOME disks utility to view remaining free space and resize in regards to that. Hope this helps.
Logan
  • 482
