I have changed the data directory of mysql.
For that
I moved the folder
/var/lib/mysqlto a newDirectorychanged the datadir in
/etc/mysql/mysql.conf.d/mysqld.cnf,changed the apparmor config in
/etc/apparmor.d/usr.sbin.mysqld:/newDirectory/mysql/ r, /newDirectory/mysql/** rwk,added
alias /var/lib/mysql/ -> /newDirectory/mysql/,to/etc/apparmor.d/tunables/aliasgranted ownership and permission to mysql
sudo chown -R mysql.mysql /newDirectory/mysql sudo chmod -R 775 /newDirectory/mysql
But still I can not start mysql and get the following error:
mysqld: Can't change dir to '/newDirectory/mysql/' (Errcode: 13 - Permission denied)
What else could be the reason for that error?
EDIT:
journalctl -xe
Aug 24 13:29:30 Server audit[2288]: AVC apparmor="DENIED" operation="open" profile="/usr/sbin/mysqld" name="/proc/2288/status" pid=2288 comm="mysqld" requested_mask="r" denied_mask="r" fsuid=121 ouid=121
Aug 24 13:29:30 Server audit[2288]: AVC apparmor="DENIED" operation="open" profile="/usr/sbin/mysqld" name="/sys/devices/system/node/" pid=2288 comm="mysqld" requested_mask="r" denied_mask="r" fsuid=121 ouid=0
Aug 24 13:29:30 Server kernel: audit: type=1400 audit(1535110170.413:3083): apparmor="DENIED" operation="open" profile="/usr/sbin/mysqld" name="/proc/2288/status" pid=2288 comm="mysqld" requested_mask="r" denied_mask="r" fsuid=121 ouid=121
Aug 24 13:29:30 Server kernel: audit: type=1400 audit(1535110170.413:3084): apparmor="DENIED" operation="open" profile="/usr/sbin/mysqld" name="/sys/devices/system/node/" pid=2288 comm="mysqld" requested_mask="r" denied_mask="r" fsuid=121 ouid=0
Aug 24 13:29:30 TIE-Server kernel: audit: type=1400 audit(1535110170.413:3085): apparmor="DENIED" operation="open" profile="/usr/sbin/mysqld" name="/proc/2288/status" pid=2288 comm="mysqld" requested_mask="r" denied_mask="r" fsuid=121 ouid=121
Aug 24 13:29:30 Server mysqld[2288]: mysqld: Can't change dir to '/newDirectory/mysql/' (Errcode: 13 - Permission denied)
EDIT2:
Inspired by this post https://askubuntu.com/a/953988/863451, I added in the file /etc/apparmor.d/usr.sbin.mysqld
/proc/*/status r,
/sys/devices/system/node/ r,
Unfortunately this did not change anything.
EDIT 3:
After trying to run the solution from George Udosen (https://askubuntu.com/a/1068832/863451) the error logs look like this:
**journalctl -xe**
Aug 27 11:04:33 Server mysqld[19214]: 2018-08-27T09:04:33.673061Z 0 [Warning] Changed limits: table_open_cache: 431 (requested 2000)
Aug 27 11:04:33 Server mysqld[19214]: 2018-08-27T09:04:33.844943Z 0 [Warning] TIMESTAMP with implicit DEFAULT value is deprecated. Please use --explicit_defaults_
Aug 27 11:04:33 Server mysqld[19214]: 2018-08-27T09:04:33.845053Z 0 [Warning] Can't create test file /newDirectory/Server.lower-test
Aug 27 11:04:33 Server mysqld[19214]: 2018-08-27T09:04:33.845104Z 0 [Note] /usr/sbin/mysqld (mysqld 5.7.23-0ubuntu0.16.04.1) starting as process 19214 ...
Aug 27 11:04:33 Server mysqld[19214]: 2018-08-27T09:04:33.849145Z 0 [Warning] Can't create test file /newDirectory/mysql/Server.lower-test
Aug 27 11:04:33 Server mysqld[19214]: 2018-08-27T09:04:33.849168Z 0 [Warning] Can't create test file newDirectory/mysql/Server.lower-test
Aug 27 11:04:33 Server mysqld[19214]: 2018-08-27T09:04:33.850029Z 0 [ERROR] failed to set datadir to /newDirectory/mysql/
Aug 27 11:04:33 Server mysqld[19214]: 2018-08-27T09:04:33.850049Z 0 [ERROR] Aborting
Aug 27 11:04:33 Server mysqld[19214]: 2018-08-27T09:04:33.850071Z 0 [Note] Binlog end
Aug 27 11:04:33 Server mysqld[19214]: 2018-08-27T09:04:33.850133Z 0 [Note] /usr/sbin/mysqld: Shutdown complete
Aug 27 11:04:33 Server systemd[1]: mysql.service: Main process exited, code=exited, status=1/FAILURE
Aug 27 11:05:03 Server systemd[1]: Failed to start MySQL Community Server.
-- Subject: Unit mysql.service has failed
-- Defined-By: systemd
-- Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel
-- Unit mysql.service has failed.
-- The result is failed.
Aug 27 11:05:03 Server systemd[1]: mysql.service: Unit entered failed state.
Aug 27 11:05:03 Server systemd[1]: mysql.service: Failed with result 'exit-code'.
Aug 27 11:05:04 Server systemd[1]: mysql.service: Service hold-off time over, scheduling restart.
Aug 27 11:05:04 Server systemd[1]: Stopped MySQL Community Server.
-- Subject: Unit mysql.service has finished shutting down
-- Unit mysql.service has finished shutting down.
Aug 27 11:05:04 TIE-Server systemd[1]: Starting MySQL Community Server...
-- Subject: Unit mysql.service has begun start-up
-- Unit mysql.service has begun starting up.
Aug 27 11:05:04 Server mysqld[19313]: mysqld: Can't change dir to '/newDirectory/mysql/' (Errcode: 13 - Permission denied)
Aug 27 11:05:04 Server mysqld[19313]: 2018-08-27T09:05:04.170717Z 0 [Warning] Changed limits: max_open_files: 1024 (requested 5000)
Aug 27 11:05:04 Server mysqld[19313]: 2018-08-27T09:05:04.170788Z 0 [Warning] Changed limits: table_open_cache: 431 (requested 2000)
Aug 27 11:05:04 Server mysqld[19313]: 2018-08-27T09:05:04.345141Z 0 [Warning] TIMESTAMP with implicit DEFAULT value is deprecated. Please use --explicit_defaults_
Aug 27 11:05:04 Server mysqld[19313]: 2018-08-27T09:05:04.345239Z 0 [Warning] Can't create test file /newDirectory/mysql/Server.lower-test
Aug 27 11:05:04 Server mysqld[19313]: 2018-08-27T09:05:04.345288Z 0 [Note] /usr/sbin/mysqld (mysqld 5.7.23-0ubuntu0.16.04.1) starting as process 19313 ...
Aug 27 11:05:04 Server mysqld[19313]: 2018-08-27T09:05:04.349475Z 0 [Warning] Can't create test file /newDirectory/mysql/Server.lower-test
Aug 27 11:05:04 Server mysqld[19313]: 2018-08-27T09:05:04.349498Z 0 [Warning] Can't create test file /newDirectory/mysql/Server.lower-test
Aug 27 11:05:04 Server mysqld[19313]: 2018-08-27T09:05:04.350320Z 0 [ERROR] failed to set datadir to /newDirectory/mysql/
Aug 27 11:05:04 Server mysqld[19313]: 2018-08-27T09:05:04.350339Z 0 [ERROR] Aborting
Aug 27 11:05:04Server mysqld[19313]: 2018-08-27T09:05:04.350357Z 0 [Note] Binlog end
Aug 27 11:05:04 TIE-Server mysqld[19313]: 2018-08-27T09:05:04.350414Z 0 [Note] /usr/sbin/mysqld: Shutdown complete
Aug 27 11:05:04 TIE-Server systemd[1]: mysql.service: Main process exited, code=exited, status=1/FAILURE
**systemctl status mysql.service**
mysql.service - MySQL Community Server
Loaded: loaded (/lib/systemd/system/mysql.service; enabled; vendor preset: enabled)
Active: activating (start-post) (Result: exit-code) since Mon 2018-08-27 11:18:01 CEST; 11s ago
Process: 21747 ExecStart=/usr/sbin/mysqld (code=exited, status=1/FAILURE)
Process: 21730 ExecStartPre=/usr/share/mysql/mysql-systemd-start pre (code=exited, status=0/SUCCESS)
Main PID: 21747 (code=exited, status=1/FAILURE); : 21749 (mysql-systemd-s)
Tasks: 2
Memory: 6.2M
CPU: 291ms
CGroup: /system.slice/mysql.service
└─control
├─21749 /bin/bash /usr/share/mysql/mysql-systemd-start post
└─21779 sleep 1
Aug 27 11:18:01 Server systemd[1]: Starting MySQL Community Server...
Aug 27 11:18:01 TIE-Server mysqld[21747]: mysqld: Can't change dir to 'newDirectory/mysql/' (Errcode: 13 - Permission denied)
Aug 27 11:18:01 Server mysqld[21747]: 2018-08-27T09:18:01.671709Z 0 [Warning] Changed limits: max_open_files: 1024 (requested 5000)
Aug 27 11:18:01 Server mysqld[21747]: 2018-08-27T09:18:01.671780Z 0 [Warning] Changed limits: table_open_cache: 431 (requested 2000)
Aug 27 11:18:01 Server mysqld[21747]: 2018-08-27T09:18:01.844978Z 0 [Warning] TIMESTAMP with implicit DEFAULT value is deprecated. Please use --explicit_defaults_
Aug 27 11:18:01 Server mysqld[21747]: 2018-08-27T09:18:01.845090Z 0 [Warning] Can't create test file /newDirectory/mysql/Server.lower-test
Aug 27 11:18:01 Server mysqld[21747]: 2018-08-27T09:18:01.845141Z 0 [Note] /usr/sbin/mysqld (mysqld 5.7.23-0ubuntu0.16.04.1) starting as process 21747 ...
Aug 27 11:18:01 Server systemd[1]: mysql.service: Main process exited, code=exited, status=1/FAILURE
EDIT 4:
The current status of mysql apparmor profile:
sudo aa-status | grep -e "^[[:alnum:]]" -e mysql
apparmor module is loaded.
80 profiles are loaded.
41 profiles are in enforce mode.
39 profiles are in complain mode.
/usr/bin/mysql
/usr/sbin/mysqld
12 processes have profiles defined.
8 processes are in enforce mode.
4 processes are in complain mode.
/usr/sbin/mysqld (8455)
0 processes are unconfined but have a profile defined.
EDIT5:
Bind mounting did not help either: https://askubuntu.com/a/663945/863451
