I'm using Kubuntu 21.04 and trying to hibernate/suspend-to-disk my laptop. I'm not having much luck. The errors I'm getting seem to suggest a deeper issue than all the other Q&As I've seen about this - most other answers seem to suggest echo disk | sudo tee /sys/power/state is the solution, but I can't even get that far. I've tried several things and ultimately ended up at the system sleep states documentation for the kernel, which says to check /sys/power/state and /sys/power/disk to see if it's even supported.
$ sudo systemctl hibernate
Failed to hibernate system via logind: Sleep verb "hibernate" not supported
$ echo disk | sudo tee /sys/power/state
disk
tee: /sys/power/state: Operation not permitted
$ cat /sys/power/state
freeze mem
$ cat /sys/power/disk
[disabled]
So it looks to me like my kernel doesn't support hibernation...? The sleep states docs also say,
Hibernation is supported if the
CONFIG_HIBERNATIONkernel configuration option is set. However, this option can only be set if support for the given CPU architecture includes the low-level code for system resume.
- Is there a reason Kubuntu doesn't have it enabled by default but ships with a "Hibernate" action?
- How would I go about enabling this option on the kernel?
- This is pedantic, but is it important that my
/sys/power/diskexists and reports[disabled]even though the kernel docs say it's supposed to not exist if hibernation is unsupported? Are the docs wrong?
Copypasta from system information:
Operating System: Kubuntu 21.04
KDE Plasma Version: 5.22.5
KDE Frameworks Version: 5.86.0
Qt Version: 5.15.2
Kernel Version: 5.11.0-38-generic (64-bit)
Graphics Platform: X11
Processors: 8 × 11th Gen Intel® Core™ i5-1135G7 @ 2.40GHz
Memory: 15.4 GiB of RAM
Graphics Processor: Mesa Intel® Xe Graphics
