After installing the latest nvidia drivers on ubuntu 20.04 I can no longer use mouse/keyboard. I used this recipe: How can I install Nvidia drivers on Ubuntu 18.04 with secure boot?.
I believe this must be something to do with secure boot since I was asked to set a password at the bios screen after rebooting.
Since I can still access via ssh, I have followed the instructions here.
However, the following message comes up:
WARNING:root:_pkg_get_support nvidia-driver-390: package has invalid Support Legacyheader, cannot determine support level
Reading package lists... Done
Building dependency tree
The following packages have unmet dependencies. linux-modules-nvidia-470-generic-hwe-20.04 : Depends: linux-modules-nvidia-470-5.11.0-37-generic (= 5.11.0-37.41~20.04.2) but it is not going to be installed Depends: nvidia-kernel-common-470 (<= 470.63.01-1) but 470.74-0ubuntu0.20.04.1 is to be installed E: Unable to correct problems, you have held broken packages.
I first tried to purge nvidia packages but when I try to remove the package with have unmet dependencies directly (linux-modules-nvidia-470-generic-hwe-20.04), it fails saying it is not installed!
And whilst this is going on, it seems that nvidia-driver-390 is named as well.
So I've stopped before I do anything more damaging...
The main problem is the keyboard and mouse, not the driver atm. I cannot use the keyboard to enter bios.
Has anyone got any ideas?
I have tried the following:
Lucidnonsense
  • 533
  • 16
I got the exact same error concerning the unmet dependencies and for me the following worked: Paste each code line by line into the terminal
sudo su
(enter root password)
for FILE in $(dpkg-divert --list | grep nvidia-470 | awk '{print $3}'); do dpkg-divert --remove $FILE; done
exit
After that:
sudo apt-get install -f
sudo apt-get update
sudo apt-get upgrade
Then:
sudo apt-get autoclean
sudo apt-get autoremove
Then I rebooted the system, ran sudo apt-get update && sudo apt-get upgrade again and could install the correct driver in the Additional Drivers tab from Software & Updates. Hope it helps!
Masado
