Command prime-run outputs prime-run: command not found. I have Ubuntu 20.04.3 and nvidia-driver-470
Fab1can
  • 117
I have the same nvidia driver version and for some reason prime-run command does not exist.
I just solved it by doing the following:
  1. Copy contents of the gist here
    #!/bin/bash
    export __NV_PRIME_RENDER_OFFLOAD=1
    export __GLX_VENDOR_LIBRARY_NAME=nvidia
    export __VK_LAYER_NV_optimus=NVIDIA_only
    export VK_ICD_FILENAMES=/usr/share/vulkan/icd.d/nvidia_icd.json
    exec "$@"
  2. Create a file ~/bin/prime-run ("~" means your home directory)
  3. Paste the contents there.
  4. Run chmod +x "~/bin/prime-run" to make it executable.
You might want to re-open your terminal or restart your session so your terminal could recognize your ~/bin folder and be able to run prime-run command, that is, if the folder is not already there.
