My computer has one integrated graphics card and 2 Nvidia RTX 3070 GPUS. I am using Ubuntu 20.04 and nvidia-driver-530.
lspci | grep VGA
00:02.0 VGA compatible controller: Intel Corporation AlderLake-S GT1 (rev 0c)
01:00.0 VGA compatible controller: NVIDIA Corporation GA104 [GeForce RTX 3070 Lite Hash Rate] (rev a1)
05:00.0 VGA compatible controller: NVIDIA Corporation GA104 [GeForce RTX 3070 Lite Hash Rate] (rev a1)
I am currently trying to test my 3070 graphics cards with the Phoronix Test Suite.
I am using nvidia-prime and prime-select: on-demand to run the terminal on the intel iGPU and phoronix tests on the Nvidia 3070: prime-run phoronix-test-suite run unigine-heaven.
There were some issues getting nvidia-prime to work, so I followed the suggestions from this article: Prime-run command not found.
cat /usr/bin/prime-run
#!/bin/bash
export __NV_PRIME_RENDER_OFFLOAD=1
export __GLX_VENDOR_LIBRARY_NAME=nvidia
export __VK_LAYER_NV_optimus=NVIDIA_only
export VK_ICD_FILENAMES=/usr/share/vulkan/icd.d/nvidia_icd.json
exec "$@"
By using prime-run I am successfully able to run the phoronix test suite on GPU 0 which has bus id 01:00.0 / PCI:1:0:0.
However, I seem unable to run any tests with GPU 1 which has bus id 05:00.0 / PCI:5:0:0.
Modifying /etc/X11/xorg.conf by changing the bus number and rebooting as suggested by the following links didn't seem to do anything and still ran on GPU 0.
- https://stackoverflow.com/questions/18382271/how-can-i-modify-xorg-conf-file-to-force-x-server-to-run-on-a-specific-gpu-i-a
- setting the default gpu
cat /etc/X11/xorg.conf
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 530.41.03
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0"
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Unknown"
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BusID "PCI:1:0:0"
BusID "PCI:5:0:0"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
SubSection "Display"
Depth 24
EndSubSection
EndSection
In fact, I deleted etc/X11/xorg.conf and was able to run the phoronix tests on GPU 0 without the conf file at all. I would guess that one of the drivers or programs I run automatically selects the nvidia card with the lowest bus id.
I would like to know where I should look to change the settings or any configuration files in order to select the second RTX 3070 gpu with the bus id 05:00.0. I would be more than happy to provide any further information.
