20
I'm using Ubuntu 20.10 groovy for my Desktop. Unfortunately its end of life has exceed.
According to EOLUpgrade guide sources.list is becomes:
deb http://old-releases.ubuntu.com/ubuntu/ groovy main restricted universe multiverse
deb http://old-releases.ubuntu.com/ubuntu/ groovy-updates main restricted universe multiverse
deb http://old-releases.ubuntu.com/ubuntu/ groovy-security main restricted universe multiverse
I got this log after running apt update:
~ sudo apt-get update
[sudo] password for farhad:
Hit:1 http://ppa.launchpad.net/atareao/atareao/ubuntu groovy InRelease
Hit:2 ***
Ign:3 http://old-releases.ubuntu.com/ubuntu groovy InRelease
Hit:4 ***
Ign:5 http://old-releases.ubuntu.com/ubuntu groovy-updates InRelease
Hit:6 http://ppa.launchpad.net/atareao/atareao/ubuntu focal InRelease
Ign:7 http://old-releases.ubuntu.com/ubuntu groovy-security InRelease
Hit:8 ***
Err:9 http://old-releases.ubuntu.com/ubuntu groovy Release
  404  Not Found [IP: 91.189.91.124 80]
Hit:10 http://ppa.launchpad.net/audio-recorder/ppa/ubuntu groovy InRelease
Err:11 http://old-releases.ubuntu.com/ubuntu groovy-updates Release
Err:12 http://old-releases.ubuntu.com/ubuntu groovy-security Release
Hit:13 http://ppa.launchpad.net/kubuntu-ppa/backports/ubuntu groovy InRelease
Hit:14 http://ppa.launchpad.net/kubuntu-ppa/backports/ubuntu focal InRelease
Hit:15 http://ppa.launchpad.net/kubuntu-ppa/beta/ubuntu groovy InRelease
Hit:16 http://ppa.launchpad.net/kubuntu-ppa/ppa/ubuntu groovy InRelease
Hit:17 http://ppa.launchpad.net/kubuntu-ppa/ppa/ubuntu focal InRelease
Reading package lists... Done                      '
E: The repository 'http://old-releases.ubuntu.com/ubuntu groovy Release' does not have a Release file. N: Updating from such a repository can't be done securely, and is therefore disabled by default. N: See apt-secure(8) manpage for repository creation and user configuration details. E: The repository 'http://old-releases.ubuntu.com/ubuntu groovy-updates Release' does not have a Release file. N: Updating from such a repository can't be done securely, and is therefore disabled by default. N: See apt-secure(8) manpage for repository creation and user configuration details. E: The repository 'http://old-releases.ubuntu.com/ubuntu groovy-security Release' does not have a Release file. N: Updating from such a repository can't be done securely, and is therefore disabled by default. N: See apt-secure(8) manpage for repository creation and user configuration details.
It seems something is wrong in http://old-releases.ubuntu.com.
What should I do to upgrade my Ubuntu 20.10 now?
P.S: *** repositories were third-party and were truncated here.
beigirad
  • 333
5 Answers5
35
This can be done without reinstalling or modding your sources.list. I was able to upgrade from 20.10 -> 21.04 -> 21.10.
If running sudo do-release-upgrade fails like so
Please install all available updates for your release before upgrading.
then you will need to remove apt's cache (broken links) before sudo apt upgrade will succeed.
sudo rm -rf /var/lib/apt/lists/*
sudo apt update
sudo apt upgrade
Nevertheless the sudo do-release-upgrade command will still fail since it doesn't have a direct path to 21.10 anymore
An upgrade from 'groovy' to 'impish' is not supported with this tool.
so you can use this workaround and upgrade to 21.04 first.
wget http://archive.ubuntu.com/ubuntu/dists/hirsute-updates/main/dist-upgrader-all/current/hirsute.tar.gz
mkdir upgrader
tar -xaf hirsute.tar.gz -C upgrader
cd upgrader
sudo ./hirsute
Reboot into 21.04 and apt update should be working like normal but you might as well upgrade to 21.10 to stay ahead of this problem.
sudo apt update && sudo apt upgrade
This is a good reason to stick with LTS once 22.04 is released in April.
17
By some reason http://old-releases.ubuntu.com/ubuntu/dists/ does not list groovy (20.10), while really it is EOL since July 22, 2021.
So you have to change old-releases back to archive in the sources.list:
sudo sed -i "s/old-releases/archive/g" /etc/apt/sources.list /etc/apt/sources.list.d/*.list
sudo apt-get update
sudo apt-get dist-upgrade
Running EOL version is dangerous and non-productive, so it is recommended to upgrade 20.10 (EOL) to 21.04 (actual, hirsute) by rebooting machine and running standard procedure like
or
update-manager -c
N0rbert
  • 103,263
2023 Update: Now that 20.10 is EOL, you do need to modify your sources.list. Fortunately this is very easy.
Add these 3 lines to /etc/apt/sources.list with your favorite terminal editor (i.e. sudo nano):
Now, Run these commands you can continue with the update process. Note - I'm just copying these steps from hackengineer's post on this same page, since that worked great for me.
sudo apt update
sudo apt upgrade
wget http://old-releases.ubuntu.com/ubuntu/dists/hirsute-updates/main/dist-upgrader-all/current/hirsute.tar.gz
mkdir upgrader
cd upgrader
sudo ./hirsute
Reboot
Dr-Bracket
  • 2,267
Tried to apt update and upgrade EOL Groovy based unit.
Hints from N0rbert are good, however groovy is neither in http://old-releases.ubuntu.com/ubuntu/dists/ nor in http://archive.ubuntu.com/ubuntu/dists/. Tried also us.archive and local <countrycode>.archive .. groovy is gone.
Therefore apt update fails with errors as in original post.
And do-release-upgrade just keeps telling me to run do-release-upgrade as "Your Ubuntu release is not supported anymore."
Unexpected "Vicious circle" in update loop and 'issue' on mature OS like Ubuntu.
sudo sed -i "s/groovy/focal/g" /etc/apt/sources.list /etc/apt/sources.list.d/*.list /etc/apt/sources.list.d/*.sources
Above commands got me back to 20.04 Focal Fossa. Supported OS.
Now waiting for 22.04.?? Jammy Jellyfish based LTS.
Just add source https://mirrors.ustc.edu.cn/ubuntu-old-releases/ubuntu/ (or other like this) in every category in /etc/apt/sources.list and also left originals as is. Make full update and upgrade. In next step use normal upgrade procedure.
I did it today on RPI and everithing works perfect.
