I Can't Install any software :( my software center is disappeared
and when I use packages like apt for example when I want to install vlc
sudo apt install vlc
I get this error
Reading package lists... Done
Building dependency tree
E: Unable to locate package vlc
I tried to add sudo apt-update before the installing I got
Hit:1 http://ppa.launchpad.net/mc3man/mpv-tests/ubuntu groovy InRelease
Err:2 https://dl.google.com/linux/chrome/deb stable InRelease
  Cannot initiate the connection to dl.google.com:443 (2a00:1450:4019:805::200e). - connect (101: Network is unreachable) Could not connect to dl.google.com:443 (216.58.208.238), connection timed out
Err:3 http://packages.microsoft.com/repos/code stable InRelease
  Connection failed [IP: 104.214.230.139 80]
Err:4 http://us.archive.ubuntu.com/ubuntu groovy InRelease
  Connection failed [IP: 91.189.91.38 80]
All packages are up to date.
W: Failed to fetch http://us.archive.ubuntu.com/ubuntu/dists/groovy/InRelease  Connection failed [IP: 91.189.91.38 80]
W: Failed to fetch https://dl.google.com/linux/chrome/deb/dists/stable/InRelease  Cannot initiate the connection to dl.google.com:443 (2a00:1450:4019:805::200e). - connect (101: Network is unreachable) Could not connect to dl.google.com:443 (216.58.208.238), connection timed out
W: Failed to fetch http://packages.microsoft.com/repos/code/dists/stable/InRelease  Connection failed [IP: 104.214.230.139 80]
W: Some index files failed to download. They have been ignored, or old ones used instead.
I Tried may thing If you get the same error please help me
Check that your Ubuntu machine really has Internet access, i.e. appropriate network interface is enabled and properly configured, cable plugged in, wifi spot is available, etc. Because this error message connect (101: Network is unreachable) says you don't have it for some reason.
ivan.ukr
  • 461
