I am facing several issues with using Bluetooth earphones in Ubuntu 20.04.2 LTS, having the kernel 5.4.0-80-generic. The earphones work well in other operating systems.
Issue 1: Whenever I switch on the earphones, they automatically connect to my laptop's Bluetooth, but they are detected as keyboards, instead of earphones. So, I cannot hear sound from them, and within a couple of seconds, they get automatically disconnected. Logs from /var/log/syslog:
Aug 3 17:11:58 ashish-Inspiron-7570 kernel: [230658.746268] input: Soundcore Life Note-L (AVRCP) as /devices/virtual/input/input115
Aug 3 17:11:58 ashish-Inspiron-7570 /usr/lib/gdm3/gdm-x-session[7877]: (II) config/udev: Adding input device Soundcore Life Note-L (AVRCP) (/dev/input/event22)
Aug 3 17:11:58 ashish-Inspiron-7570 /usr/lib/gdm3/gdm-x-session[7877]: (**) Soundcore Life Note-L (AVRCP): Applying InputClass "libinput keyboard catchall"
Aug 3 17:11:58 ashish-Inspiron-7570 /usr/lib/gdm3/gdm-x-session[7877]: (II) Using input driver 'libinput' for 'Soundcore Life Note-L (AVRCP)'
Aug 3 17:11:58 ashish-Inspiron-7570 /usr/lib/gdm3/gdm-x-session[7877]: (II) systemd-logind: got fd for /dev/input/event22 13:86 fd 63 paused 0
Aug 3 17:11:58 ashish-Inspiron-7570 /usr/lib/gdm3/gdm-x-session[7877]: (**) Soundcore Life Note-L (AVRCP): always reports core events
Aug 3 17:11:58 ashish-Inspiron-7570 /usr/lib/gdm3/gdm-x-session[7877]: (**) Option "Device" "/dev/input/event22"
Aug 3 17:11:58 ashish-Inspiron-7570 /usr/lib/gdm3/gdm-x-session[7877]: (**) Option "_source" "server/udev"
Aug 3 17:11:58 ashish-Inspiron-7570 /usr/lib/gdm3/gdm-x-session[7877]: (II) event22 - Soundcore Life Note-L (AVRCP): is tagged by udev as: Keyboard
Aug 3 17:11:58 ashish-Inspiron-7570 /usr/lib/gdm3/gdm-x-session[7877]: (II) event22 - Soundcore Life Note-L (AVRCP): device is a keyboard
Aug 3 17:11:58 ashish-Inspiron-7570 /usr/lib/gdm3/gdm-x-session[7877]: (II) event22 - Soundcore Life Note-L (AVRCP): device removed
Aug 3 17:11:58 ashish-Inspiron-7570 /usr/lib/gdm3/gdm-x-session[7877]: (**) Option "config_info" "udev:/sys/devices/virtual/input/input115/event22"
Aug 3 17:11:58 ashish-Inspiron-7570 /usr/lib/gdm3/gdm-x-session[7877]: (II) XINPUT: Adding extended input device "Soundcore Life Note-L (AVRCP)" (type: KEYBOARD, id 22)
Aug 3 17:11:58 ashish-Inspiron-7570 /usr/lib/gdm3/gdm-x-session[7877]: (**) Option "xkb_model" "pc105"
Aug 3 17:11:58 ashish-Inspiron-7570 /usr/lib/gdm3/gdm-x-session[7877]: (**) Option "xkb_layout" "us"
Aug 3 17:11:58 ashish-Inspiron-7570 /usr/lib/gdm3/gdm-x-session[7877]: (WW) Option "xkb_variant" requires a string value
Aug 3 17:11:58 ashish-Inspiron-7570 /usr/lib/gdm3/gdm-x-session[7877]: (WW) Option "xkb_options" requires a string value
Aug 3 17:11:58 ashish-Inspiron-7570 /usr/lib/gdm3/gdm-x-session[2172]: (II) config/udev: Adding input device Soundcore Life Note-L (AVRCP) (/dev/input/event22)
Aug 3 17:11:58 ashish-Inspiron-7570 /usr/lib/gdm3/gdm-x-session[2172]: (**) Soundcore Life Note-L (AVRCP): Applying InputClass "libinput keyboard catchall"
Aug 3 17:11:58 ashish-Inspiron-7570 /usr/lib/gdm3/gdm-x-session[2172]: (II) Using input driver 'libinput' for 'Soundcore Life Note-L (AVRCP)'
Aug 3 17:11:58 ashish-Inspiron-7570 kernel: [230658.857301] input: Soundcore Life Note (AVRCP) as /devices/virtual/input/input116
Aug 3 17:11:58 ashish-Inspiron-7570 /usr/lib/gdm3/gdm-x-session[2172]: (II) systemd-logind: got fd for /dev/input/event22 13:86 fd 31 paused 1
Aug 3 17:11:58 ashish-Inspiron-7570 /usr/lib/gdm3/gdm-x-session[2172]: (II) systemd-logind: releasing fd for 13:86
Aug 3 17:11:58 ashish-Inspiron-7570 /usr/lib/gdm3/gdm-x-session[2172]: (II) config/udev: Adding input device Soundcore Life Note (AVRCP) (/dev/input/event23)
Aug 3 17:11:58 ashish-Inspiron-7570 /usr/lib/gdm3/gdm-x-session[2172]: (**) Soundcore Life Note (AVRCP): Applying InputClass "libinput keyboard catchall"
Aug 3 17:11:58 ashish-Inspiron-7570 /usr/lib/gdm3/gdm-x-session[2172]: (II) Using input driver 'libinput' for 'Soundcore Life Note (AVRCP)'
Aug 3 17:11:58 ashish-Inspiron-7570 /usr/lib/gdm3/gdm-x-session[2172]: (II) systemd-logind: got fd for /dev/input/event23 13:87 fd 31 paused 1
Aug 3 17:11:58 ashish-Inspiron-7570 /usr/lib/gdm3/gdm-x-session[2172]: (II) systemd-logind: releasing fd for 13:87
Aug 3 17:11:58 ashish-Inspiron-7570 /usr/lib/gdm3/gdm-x-session[7877]: (II) config/udev: Adding input device Soundcore Life Note (AVRCP) (/dev/input/event23)
Aug 3 17:11:58 ashish-Inspiron-7570 /usr/lib/gdm3/gdm-x-session[7877]: (**) Soundcore Life Note (AVRCP): Applying InputClass "libinput keyboard catchall"
Aug 3 17:11:58 ashish-Inspiron-7570 /usr/lib/gdm3/gdm-x-session[7877]: (II) Using input driver 'libinput' for 'Soundcore Life Note (AVRCP)'
Aug 3 17:11:58 ashish-Inspiron-7570 /usr/lib/gdm3/gdm-x-session[7877]: (II) systemd-logind: got fd for /dev/input/event23 13:87 fd 78 paused 0
Aug 3 17:11:58 ashish-Inspiron-7570 /usr/lib/gdm3/gdm-x-session[7877]: (**) Soundcore Life Note (AVRCP): always reports core events
Aug 3 17:11:58 ashish-Inspiron-7570 /usr/lib/gdm3/gdm-x-session[7877]: (**) Option "Device" "/dev/input/event23"
Aug 3 17:11:58 ashish-Inspiron-7570 /usr/lib/gdm3/gdm-x-session[7877]: (II) event23 - Soundcore Life Note (AVRCP): is tagged by udev as: Keyboard
Aug 3 17:11:58 ashish-Inspiron-7570 /usr/lib/gdm3/gdm-x-session[7877]: (II) event23 - Soundcore Life Note (AVRCP): device is a keyboard
Aug 3 17:11:58 ashish-Inspiron-7570 /usr/lib/gdm3/gdm-x-session[7877]: (II) event23 - Soundcore Life Note (AVRCP): device removed
Aug 3 17:11:58 ashish-Inspiron-7570 /usr/lib/gdm3/gdm-x-session[7877]: (**) Option "config_info" "udev:/sys/devices/virtual/input/input116/event23"
Aug 3 17:11:58 ashish-Inspiron-7570 /usr/lib/gdm3/gdm-x-session[7877]: (II) XINPUT: Adding extended input device "Soundcore Life Note (AVRCP)" (type: KEYBOARD, id 23)
Aug 3 17:11:58 ashish-Inspiron-7570 gnome-shell[8535]: Window manager warning: Overwriting existing binding of keysym 31 with keysym 31 (keycode a).
Aug 3 17:11:58 ashish-Inspiron-7570 gnome-shell[8535]: Window manager warning: Overwriting existing binding of keysym 38 with keysym 38 (keycode 11).
Aug 3 17:11:58 ashish-Inspiron-7570 gnome-shell[8535]: Window manager warning: Overwriting existing binding of keysym 39 with keysym 39 (keycode 12).
Aug 3 17:11:58 ashish-Inspiron-7570 gnome-shell[8535]: Window manager warning: Overwriting existing binding of keysym 32 with keysym 32 (keycode b).
Aug 3 17:11:58 ashish-Inspiron-7570 gnome-shell[8535]: Window manager warning: Overwriting existing binding of keysym 33 with keysym 33 (keycode c).
Aug 3 17:11:58 ashish-Inspiron-7570 gnome-shell[8535]: Window manager warning: Overwriting existing binding of keysym 34 with keysym 34 (keycode d).
Aug 3 17:11:58 ashish-Inspiron-7570 gnome-shell[8535]: Window manager warning: Overwriting existing binding of keysym 35 with keysym 35 (keycode e).
Aug 3 17:11:58 ashish-Inspiron-7570 gnome-shell[8535]: Window manager warning: Overwriting existing binding of keysym 36 with keysym 36 (keycode f).
Aug 3 17:11:58 ashish-Inspiron-7570 gnome-shell[8535]: Window manager warning: Overwriting existing binding of keysym 37 with keysym 37 (keycode 10).
Aug 3 17:11:59 ashish-Inspiron-7570 gnome-shell[8535]: Window manager warning: Overwriting existing binding of keysym 31 with keysym 31 (keycode a).
Aug 3 17:11:59 ashish-Inspiron-7570 gnome-shell[8535]: Window manager warning: Overwriting existing binding of keysym 38 with keysym 38 (keycode 11).
Aug 3 17:11:59 ashish-Inspiron-7570 gnome-shell[8535]: Window manager warning: Overwriting existing binding of keysym 39 with keysym 39 (keycode 12).
Aug 3 17:11:59 ashish-Inspiron-7570 gnome-shell[8535]: Window manager warning: Overwriting existing binding of keysym 32 with keysym 32 (keycode b).
Aug 3 17:11:59 ashish-Inspiron-7570 gnome-shell[8535]: Window manager warning: Overwriting existing binding of keysym 33 with keysym 33 (keycode c).
Aug 3 17:11:59 ashish-Inspiron-7570 gnome-shell[8535]: Window manager warning: Overwriting existing binding of keysym 34 with keysym 34 (keycode d).
Aug 3 17:11:59 ashish-Inspiron-7570 gnome-shell[8535]: Window manager warning: Overwriting existing binding of keysym 35 with keysym 35 (keycode e).
Aug 3 17:11:59 ashish-Inspiron-7570 gnome-shell[8535]: Window manager warning: Overwriting existing binding of keysym 36 with keysym 36 (keycode f).
Aug 3 17:11:59 ashish-Inspiron-7570 gnome-shell[8535]: Window manager warning: Overwriting existing binding of keysym 37 with keysym 37 (keycode 10).
Aug 3 17:11:59 ashish-Inspiron-7570 bluetoothd[1365]: profiles/audio/a2dp.c:a2dp_select_capabilities() Unable to select SEP
Aug 3 17:12:00 ashish-Inspiron-7570 acpid: input device has been disconnected, fd 25
Aug 3 17:12:00 ashish-Inspiron-7570 /usr/lib/gdm3/gdm-x-session[7877]: (II) config/udev: removing device Soundcore Life Note-L (AVRCP)
Aug 3 17:12:00 ashish-Inspiron-7570 /usr/lib/gdm3/gdm-x-session[7877]: (**) Option "fd" "63"
Aug 3 17:12:00 ashish-Inspiron-7570 /usr/lib/gdm3/gdm-x-session[7877]: (II) event22 - Soundcore Life Note-L (AVRCP): device removed
Aug 3 17:12:00 ashish-Inspiron-7570 /usr/lib/gdm3/gdm-x-session[7877]: (II) UnloadModule: "libinput"
Aug 3 17:12:00 ashish-Inspiron-7570 /usr/lib/gdm3/gdm-x-session[7877]: (II) systemd-logind: releasing fd for 13:86
Aug 3 17:12:03 ashish-Inspiron-7570 acpid: input device has been disconnected, fd 26
Aug 3 17:12:03 ashish-Inspiron-7570 /usr/lib/gdm3/gdm-x-session[7877]: (II) config/udev: removing device Soundcore Life Note (AVRCP)
Aug 3 17:12:03 ashish-Inspiron-7570 /usr/lib/gdm3/gdm-x-session[7877]: (**) Option "fd" "78"
Aug 3 17:12:03 ashish-Inspiron-7570 /usr/lib/gdm3/gdm-x-session[7877]: (II) event23 - Soundcore Life Note (AVRCP): device removed
Aug 3 17:12:03 ashish-Inspiron-7570 /usr/lib/gdm3/gdm-x-session[7877]: (II) UnloadModule: "libinput"
Aug 3 17:12:03 ashish-Inspiron-7570 /usr/lib/gdm3/gdm-x-session[7877]: (II) systemd-logind: releasing fd for 13:87
When I connect to the earphones' Bluetooth manually from the GUI, they get connected and I can hear sound from them. Logs when manually connecting to the earphones are mentioned below.
Issue 2: The sound that I hear is not clear and it cracks in between. When I click on the "Sound" option in the settings, the sound becomes clear, similar to what I expect.
Image: Bluetooth connection GUI
Aug 3 17:13:07 ashish-Inspiron-7570 bluetoothd[1365]: src/service.c:btd_service_connect() a2dp-source profile connect failed for 8C:85:80:2C:F2:35: Device or resource busy
Aug 3 17:13:08 ashish-Inspiron-7570 kernel: [230728.120859] input: Soundcore Life Note (AVRCP) as /devices/virtual/input/input117
Aug 3 17:13:08 ashish-Inspiron-7570 /usr/lib/gdm3/gdm-x-session[7877]: (II) config/udev: Adding input device Soundcore Life Note (AVRCP) (/dev/input/event22)
Aug 3 17:13:08 ashish-Inspiron-7570 /usr/lib/gdm3/gdm-x-session[7877]: (**) Soundcore Life Note (AVRCP): Applying InputClass "libinput keyboard catchall"
Aug 3 17:13:08 ashish-Inspiron-7570 /usr/lib/gdm3/gdm-x-session[7877]: (II) Using input driver 'libinput' for 'Soundcore Life Note (AVRCP)'
Aug 3 17:13:08 ashish-Inspiron-7570 /usr/lib/gdm3/gdm-x-session[2172]: (II) config/udev: Adding input device Soundcore Life Note (AVRCP) (/dev/input/event22)
Aug 3 17:13:08 ashish-Inspiron-7570 /usr/lib/gdm3/gdm-x-session[2172]: (**) Soundcore Life Note (AVRCP): Applying InputClass "libinput keyboard catchall"
Aug 3 17:13:08 ashish-Inspiron-7570 /usr/lib/gdm3/gdm-x-session[2172]: (II) Using input driver 'libinput' for 'Soundcore Life Note (AVRCP)'
Aug 3 17:13:08 ashish-Inspiron-7570 /usr/lib/gdm3/gdm-x-session[7877]: (II) systemd-logind: got fd for /dev/input/event22 13:86 fd 63 paused 0
Aug 3 17:13:08 ashish-Inspiron-7570 /usr/lib/gdm3/gdm-x-session[7877]: (**) Soundcore Life Note (AVRCP): always reports core events
Aug 3 17:13:08 ashish-Inspiron-7570 /usr/lib/gdm3/gdm-x-session[7877]: (**) Option "Device" "/dev/input/event22"
Aug 3 17:13:08 ashish-Inspiron-7570 /usr/lib/gdm3/gdm-x-session[7877]: (**) Option "_source" "server/udev"
Aug 3 17:13:08 ashish-Inspiron-7570 /usr/lib/gdm3/gdm-x-session[7877]: (II) event22 - Soundcore Life Note (AVRCP): is tagged by udev as: Keyboard
Aug 3 17:13:08 ashish-Inspiron-7570 /usr/lib/gdm3/gdm-x-session[7877]: (II) event22 - Soundcore Life Note (AVRCP): device is a keyboard
Aug 3 17:13:08 ashish-Inspiron-7570 /usr/lib/gdm3/gdm-x-session[7877]: (II) event22 - Soundcore Life Note (AVRCP): device removed
Aug 3 17:13:08 ashish-Inspiron-7570 /usr/lib/gdm3/gdm-x-session[7877]: (**) Option "config_info" "udev:/sys/devices/virtual/input/input117/event22"
Aug 3 17:13:08 ashish-Inspiron-7570 /usr/lib/gdm3/gdm-x-session[7877]: (II) XINPUT: Adding extended input device "Soundcore Life Note (AVRCP)" (type: KEYBOARD, id 22)
Aug 3 17:13:08 ashish-Inspiron-7570 /usr/lib/gdm3/gdm-x-session[7877]: (**) Option "xkb_model" "pc105"
Aug 3 17:13:08 ashish-Inspiron-7570 /usr/lib/gdm3/gdm-x-session[7877]: (**) Option "xkb_layout" "us"
Aug 3 17:13:08 ashish-Inspiron-7570 /usr/lib/gdm3/gdm-x-session[7877]: (WW) Option "xkb_variant" requires a string value
Aug 3 17:13:08 ashish-Inspiron-7570 /usr/lib/gdm3/gdm-x-session[7877]: (WW) Option "xkb_options" requires a string value
Aug 3 17:13:08 ashish-Inspiron-7570 /usr/lib/gdm3/gdm-x-session[2172]: (II) systemd-logind: got fd for /dev/input/event22 13:86 fd 31 paused 1
Aug 3 17:13:08 ashish-Inspiron-7570 /usr/lib/gdm3/gdm-x-session[2172]: (II) systemd-logind: releasing fd for 13:86
Aug 3 17:13:08 ashish-Inspiron-7570 gnome-shell[8535]: Window manager warning: Overwriting existing binding of keysym 31 with keysym 31 (keycode a).
Aug 3 17:13:08 ashish-Inspiron-7570 gnome-shell[8535]: Window manager warning: Overwriting existing binding of keysym 38 with keysym 38 (keycode 11).
Aug 3 17:13:08 ashish-Inspiron-7570 gnome-shell[8535]: Window manager warning: Overwriting existing binding of keysym 39 with keysym 39 (keycode 12).
Aug 3 17:13:08 ashish-Inspiron-7570 gnome-shell[8535]: Window manager warning: Overwriting existing binding of keysym 32 with keysym 32 (keycode b).
Aug 3 17:13:08 ashish-Inspiron-7570 gnome-shell[8535]: Window manager warning: Overwriting existing binding of keysym 33 with keysym 33 (keycode c).
Aug 3 17:13:08 ashish-Inspiron-7570 gnome-shell[8535]: Window manager warning: Overwriting existing binding of keysym 34 with keysym 34 (keycode d).
Aug 3 17:13:08 ashish-Inspiron-7570 gnome-shell[8535]: Window manager warning: Overwriting existing binding of keysym 35 with keysym 35 (keycode e).
Aug 3 17:13:08 ashish-Inspiron-7570 gnome-shell[8535]: Window manager warning: Overwriting existing binding of keysym 36 with keysym 36 (keycode f).
Aug 3 17:13:08 ashish-Inspiron-7570 gnome-shell[8535]: Window manager warning: Overwriting existing binding of keysym 37 with keysym 37 (keycode 10).
Aug 3 17:13:10 ashish-Inspiron-7570 bluetoothd[1365]: /org/bluez/hci0/dev_8C_85_80_2C_F2_35/sep2/fd25: fd(38) ready
Aug 3 17:13:10 ashish-Inspiron-7570 rtkit-daemon[2321]: Supervising 0 threads of 0 processes of 0 users.
Aug 3 17:13:10 ashish-Inspiron-7570 rtkit-daemon[2321]: Successfully made thread 686940 of process 7796 owned by '1000' RT at priority 5.
Aug 3 17:13:10 ashish-Inspiron-7570 rtkit-daemon[2321]: Supervising 1 threads of 1 processes of 1 users.
Issue 3: The earphones have both sink and source in them, which works with other devices. But, on connecting them to Ubuntu, only the output works. I can't use the microphone present in my earphones.
In the GUI, the Input option is not listed for the earphones. It is only listed in the output device:
Image: Sound Input and Output option GUI
I think that is probably because of the A2DP configuration. Even from the above logs, we can see a2dp-source profile connect failed. From the GUI itself, I try to change A2DP to HSP/HFP, but find that it can't switch the profile:
Aug 3 17:14:08 ashish-Inspiron-7570 pulseaudio[7796]: Refused to switch profile to headset_head_unit: Not connected
So, I needed help with the above issues:
- Bluetooth earphones can automatically connect to Ubuntu.
- The sound that is played by earphones does not crack in between.
- I can simultaneously utilize the input and output of the earphones, instead of only the output.
What steps can I take to fix or debug these issues?
Edit 1:
Output of lspci | grep Audio:
00:1f.3 Audio device: Intel Corporation Sunrise Point-LP HD Audio (rev 21)
