My Ubuntu 18.04 is unstable with nouveau (slow and crashes when I open system settings).
So I installed the Nvidia proprietary driver (I tried each one from nvidia-driver-390 to nvidia-driver-470) but at reboot I get only the 640x480 resolution without being able to change it (and the Nvidia control panel is empty).
I tried to purge all the nvidia stuff (sudo apt purge *nvidia*), I deleted xorg.conf and the I tried manually forcing the desired resolution... nothing works.
It used to work (with nvidia-driver-460), then I moved my Ubuntu install to a machine with integrated Intel graphics, when I moved back to the previous machine with the Nvidia GPU this issue appeared.
This is some information about my setup:
$ sudo lshw -C display
  *-display
       description: VGA compatible controller
       product: GP106 [GeForce GTX 1060 6GB]
       vendor: NVIDIA Corporation
       physical id: 0
       bus info: pci@0000:3b:00.0
       version: a1
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress vga_controller bus_master cap_list rom
       configuration: driver=nouveau latency=0
       resources: irq:68 memory:ee000000-eeffffff memory:d0000000-dfffffff memory:e0000000-e1ffffff ioport:f000(size=128) memory:c0000-dfff
$ sudo inxi -F -x Graphics: Card: NVIDIA GP106 [GeForce GTX 1060 6GB] bus-ID: 3b:00.0 Display Server: X.Org 1.20.8 drivers: fbdev,nouveau (unloaded: modesetting,vesa) Resolution: 2560x1440@59.95hz OpenGL: renderer: llvmpipe (LLVM 10.0.0, 128 bits) version: 3.3 Mesa 20.0.8 Direct Render: Yes
$ ubuntu-drivers devices WARNING:root:_pkg_get_support nvidia-driver-390: package has invalid Support Legacyheader, cannot determine support level == /sys/devices/pci0000:00/0000:00:03.1/0000:3b:00.0 == modalias : pci:v000010DEd00001C03sv00001043sd0000863Ebc03sc00i00 vendor : NVIDIA Corporation model : GP106 [GeForce GTX 1060 6GB] driver : nvidia-driver-450-server - distro non-free driver : nvidia-driver-390 - distro non-free driver : nvidia-driver-460-server - distro non-free driver : nvidia-driver-460 - distro non-free driver : nvidia-driver-470 - distro non-free recommended driver : nvidia-driver-418-server - distro non-free driver : xserver-xorg-video-nouveau - distro free builtin
Edit: I found that for some reason my system is using llvmpipe somehow related to VMware (that I had installed, but now is not installed anymore).
$ glxinfo -B
name of display: :0
display: :0  screen: 0
direct rendering: Yes
Extended renderer info (GLX_MESA_query_renderer):
    Vendor: VMware, Inc. (0xffffffff)
    Device: llvmpipe (LLVM 10.0.0, 128 bits) (0xffffffff)
    Version: 20.0.8
    Accelerated: no
    Video memory: 32084MB
    Unified memory: no
    Preferred profile: core (0x1)
    Max core profile version: 3.3
    Max compat profile version: 3.1
    Max GLES1 profile version: 1.1
    Max GLES[23] profile version: 3.1
OpenGL vendor string: VMware, Inc.
OpenGL renderer string: llvmpipe (LLVM 10.0.0, 128 bits)
OpenGL core profile version string: 3.3 (Core Profile) Mesa 20.0.8
OpenGL core profile shading language version string: 3.30
OpenGL core profile context flags: (none)
OpenGL core profile profile mask: core profile
OpenGL version string: 3.1 Mesa 20.0.8 OpenGL shading language version string: 1.40 OpenGL context flags: (none)
OpenGL ES profile version string: OpenGL ES 3.1 Mesa 20.0.8 OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.10
Any idea?
Wizard79
  • 171
