I am using Ubuntu 14.04 with an FX-6350 processor and a EVGA GTX 750 ti SC GPU. I installed the CUDA and display drivers for the 750 ti using this tutorial: Installing and testing CUDA in Ubuntu 14.04 after restarting lightdm, it works perfectly, but upon reboot, the resolution is stuck at 640 by 480. If I log in, Unity doesn't load, just the background. I'm also using a Gigabyte motherboard. When I boot up, after POST, it shows this:
Verifying DMI Pool Data ............
error: no video mode activated
[   2.771245] nouveau E[ DEVICE][0000:01:00.0] unknown chipset, 0x117000a2
[   2.771348] nouveau E[    DRM] failed to create 0x80000080, -22
I solved this problem on your PC.
This problem xorg.conf file.
me hardware: "acer x243hd" and "gigabyte geforce gtx760"
cat xorg.conf !!!not work (640x480) this file gen nvidia-xconfig:
~$ cat /etc/X11/xorg.conf.nvidia-xconfig-original
Section "ServerLayout"
    Identifier     "Layout0"
    Screen      0  "Screen0"
    InputDevice    "Keyboard0" "CoreKeyboard"
    InputDevice    "Mouse0" "CorePointer"
EndSection
Section "Files"
EndSection
Section "InputDevice"
    # generated from default
    Identifier     "Mouse0"
    Driver         "mouse"
    Option         "Protocol" "auto"
    Option         "Device" "/dev/psaux"
    Option         "Emulate3Buttons" "no"
    Option         "ZAxisMapping" "4 5"
EndSection
    Identifier     "Keyboard0"
    Driver         "kbd"
EndSection
Section "Device"
    Identifier     "Device0"
    Driver         "nvidia"
    VendorName     "NVIDIA Corporation"
EndSection
cat xorg.conf !!!work (1920x1080):
    Screen      0  "Screen0"
EndSection
Section "Files"
EndSection
    Identifier     "Mouse0"
    Driver         "mouse"
EndSection
    Driver         "kbd"
EndSection
Section "Monitor"
    Identifier     "Monitor0"
    VendorName     "Unknown"
    ModelName      "Unknown"
    HorizSync       30.0 - 80.0
    VertRefresh     55.0 - 75.0
    DisplaySize     400 225
    Modeline       "1920x1080_60.00"  172.80  1920 2040 2248 2576  1080 1081 1084 1118  -HSync +Vsync
    Option         "DPMS"
EndSection
Section "Device"
    BusID          "PCI:1:0:0"
    Driver         "nvidia"
EndSection
Section "Screen"
    Identifier     "Screen0"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
    SubSection     "Display"
        Viewport    0 0
        Depth       24
        Modes      "1920x1080_60.00"
    EndSubSection
EndSection
How get: Modeline "1920x1080_60.00" 172.80 192.... bla bla bla
~$ gtf 1920 1080 60
  # 1920x1080 @ 60.00 Hz (GTF) hsync: 67.08 kHz; pclk: 172.80 MHz
add this in Section "Monitor" and do not forget to add in Section "Screen" -> SubSection "Display" string Modes "1920x1080_60.00"
To summarize:
  1. Specify the correct HorizSync and VertRefresh
  2. Gen and add you Modeline
  3. Add name Modeline in Modes
Thank you all for your attention!!!
see my answer here. It's because of nvidia's xorg.conf. Removing it seems to fix the issue. Execute the commands below after pressing CTRL+ALT+F1 on GDM screen or within GNOME.
sudo mv /etc/X11/xorg.conf /etc/X11/xorg.conf.old
sudo touch /etc/X11/xorg.conf
