I've just installed Windows 11 on the first partition of my disk,that's partitioned like this :
# fdisk /dev/sdb -l
Disk /dev/sdb: 465.76 GiB, 500107862016 bytes, 976773168 sectors
Disk model: Samsung SSD 860
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0x1967ba67
Device Boot Start End Sectors Size Id Type
/dev/sdb1 * 2048 273092607 273090560 130.2G 7 HPFS/NTFS/exFAT
/dev/sdb2 273092608 274454527 1361920 665M 27 Hidden NTFS WinRE
/dev/sdb3 274456576 276553727 2097152 1G 82 Linux swap / Solaris
/dev/sdb4 276553728 976772477 700218750 333.9G 83 Linux
As you can see, Ubuntu 18.04 is installed on /dev/sdb3 and /dev/sdb4.
Previously Windows 10 was installed instead of Windows 11.
The problem is that the installation of Windows 11 broke grub2 that was installed on top of the disk /dev/sdb and now I want to reinstall it. I've tried to do like this :
# sudo grub-install --recheck --no-floppy --root-directory=/ /dev/sdb
But it gives this error :
Installing for x86_64-efi platform.
grub-install: error: cannot find EFI directory.
I think that it is a bug, because it detects an EFI partition, which isn't there. The disk has been formatted with MBR and it is DOS style and I have installed Windows 11 using RUFUS using the MBR method. Even /dev/sda is not EFI style :
# fdisk /dev/sda -l
Disk /dev/sda: 465.76 GiB, 500107862016 bytes, 976773168 sectors
Disk model: CT500MX500SSD4
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: dos
Disk identifier: 0xa6e39599
/dev/sda1 * 2048 976767672 976765625 465.8G 83 Linux
What's the right procedure here to reinstall grub2?
