I have dual booted my computer, (by default the OS my computer boots into is Ubuntu) and I now want to update my Windows 10 to Windows 11, will this affect my Ubuntu installation. I have read in some place that this can lead to MBR being overwritten and hence I could loose my Linux system, is it possible that I can do this without affecting my Ubuntu system
It seems that Microsoft considers the installation of Grub as an unsecure threat, which sould be deleted to be able to upgrade to Windows 11.
I interprete this that the quality of Linux is so high that Microsoft considers it as a threat for their futuristic market share!
What I suggest to test is:
have an Ubuntu live USB. (i.e.: the one of your installation)
use the Windows 10 installation usb to repair it's own boot startup.
enable secure boot
upgrade the windows 10 to windows 11
disable secure boot
repair the GRUB menu with the live USB
- 24,696
- 101
I had a dual-boot setup with windows 10 & a debian-based linux OS. I used the windows 11 assistant to upgrade my windows 10 pro version to windows 11 pro. Everything transferred fine, including the dual-boot linux operating system. No problems!
- 81
I had both windows 10 and Ubuntu 20.04 on dual boot (default OS: windows 10). I've visited this thread before upgrading to W11. I decided to back up Ubuntu and give it a try. And, I've upgraded to Windows 11 just a few hours ago using insiders, and it hasn't affected my Ubuntu installation at all. Everything's alright:) And lemme let you know, W11 isn't just fast, it's quicky quick quick to boot compared to W10 and the current version is pretty stable as far as I've explored and based on the reviews.
- 61
I use a ThinkPad T14 with encrypted LUKS and GRUB with two boot options, Manjaro and Windows Boot Manager.
To be able to update to Windows 11 I just had to enable SecureBoot (which led to booting directly into Windows), perform the update, and then deactivate SecureBoot again.
No hassle, my GRUB worked right away again.
- 3,779
- 31
Indeed Window can make things messy, several options:
if you don't care about reinstalling your Linux distribution, update Windows then do a clean reinstall,
if you do care, several disk utility allow to analyze the disk and reconfigure GRUB
the MBR. But I would make a backup first just in case...
Edit: Edited thanks to several comments.
- 56
I dualboot my Arch Linux with Windows 10 with secure boot disabled. I first tried upgrading in a QEMU virtual machine (with secure boot EFI and emulated TPM module, also had to passthrough my own CPU because the emulated CPU wasn't supported), had no problems and then I just upgraded my main machine. Everything works fine (except HP BIOS automatically selected Windows Boot Manager instead of GRUB but that can be fixed by copying the "Microsoft" folder to somewhere safe, deleting it, rebooting system so it auto-selects GRUB this time, then copying that folder back -NOTE: I don't recommend doing it-).
I used the Windows 11 upgrade tool to do it instead of an ISO which is why it finished without giving me "Secure Boot is disabled" error. (Secure boot was disabled while installing, hardware supports it -HP Pavilion 15-dk0005nt-)
- 21
I had Fedora 34 running parallel with Windows 10 on my ThinkPad X1 Yoga (3rd Gen) laptop. Just to upgrade Windows to Windows 11 I turned on Secure Boot and TPM in UEFI/BIOS and downloaded the Windows 11 Installation Assistant from Microsoft to start the upgrade. Upgrade was successful. GRUB works fine.
After Win10->Win11 upgrade I turned off the Secure Boot as my VMs in VirtualBox under Linux stopped working. Now everything works fine again.
- 360
I just updated a Dell Laptop that is dual booting Ubuntu 22.04 with Windows. I had Window 10 (the free download version) and it all went incredibly smooth. All I did was to boot Windows 10 (the second option in the bootloader order in grub) and simply choose to Upgrade to Windows 11. After the download and installation it rebooted to the usual grub bootloader, I chose Windows and it loaded Windows 11. No issues at all, nothing special to be done.
- 21
