After a do-release-upgrade to switch from 16.04 to 18.04, something failed and machine was left in a "in between" state, with lots of broken dependencies issues. My package tree is a mess, I am desperate... ;-)
I tried lots of things (including dpkg --configure -a, randomly removing packages with dpkg --force depends -P <pkg-name>, plus other things), but I am kinda stuck at present.
So, when I try:
$ sudo apt --fix-broken install
Reading package lists... Done
Building dependency tree
Correcting dependencies... Done
The following packages were automatically installed and are no longer required:
(here 20 lines)
The following additional packages will be installed:
... (here 5 lines)
Suggested packages:
... more
Recommended packages:
... more
The following packages will be REMOVED:
... more
The following NEW packages will be installed:
... more (10 lines)
28 upgraded, 6 newly installed, 1 to remove and 327 not upgraded.
228 not fully installed or removed.
Need to get 0 B/13,3 MB of archives.
After this operation, 2 771 kB of additional disk space will be used.
Do you want to continue? [Y/n]
Up to here, nothing I am afraid of. But now, entering Y:
Extracting templates from packages: 100%
(Reading database ... 977800 files and directories currently installed.)
Removing ubuntu-advantage-tools (27.0.2~18.04.1) ...
Traceback (most recent call last):
File "<string>", line 2, in <module>
File "/usr/lib/python3/dist-packages/uaclient/apt.py", line 9, in <module>
from uaclient import gpg
File "/usr/lib/python3/dist-packages/uaclient/gpg.py", line 3, in <module>
import shutil
ModuleNotFoundError: No module named 'shutil'
dpkg: error processing package ubuntu-advantage-tools (--remove):
installed ubuntu-advantage-tools package pre-removal script subprocess returned error exit status 1
So this sounds like a Python error, from what I understand, it can't find shutil.
So I manually downloaded what I thought was the thing:
https://packages.ubuntu.com/bionic/python-backports-shutil-get-terminal-size
and installed manually with:
sudo dpkg -i python-backports-shutil-get-terminal-size_1.0.0-5_all.deb
But doing apt --fix-broken install again ends up at the same point.
I have limited knowledge with Python, so I can't be sure this is the real issue, but any help is welcome. Else, next step will be probably reinstalling from scratch, but I'd really prefer to avoid that.
At present I am able to manually install packages (download from https://packages.ubuntu.com/ then dpkg -i) but that's about it, everything else fails.
For example, if I try to install libpython3.6-stdlib:
$ sudo apt-get install libpython3.6-stdlib
I get:
libpython3.6-stdlib : Depends: libpython3.6-minimal (= 3.6.9-1~18.04ubuntu1.4) but 3.6.13-1+xenial2 is to be installed
which means that I still have packages from 16.04 (Xenial).
How can I manually remove all the 16.04 packages?
Additional info (machine now boots only with a console):
$ python --version=> Python 3.6.13$ lsb_release -ais not available$ uname -atells me its a 4.15 kernel (which seem consistent with 18.04)
