So I did an upgrade form ubuntu 20.04 to 22.04 which did not quite go perfectly and there were some issues. While doing a sudo apt-get upgrade I am getting the following message
Reading package lists... Done
Building dependency tree... Done
You might want to run 'apt --fix-broken install' to correct these.
libpython3-stdlib : Depends: libpython3.10-stdlib (>= 3.10.6-1~) but it is not installed
python3-update-manager : Depends: python3-distupgrade but it is not installed
python3.10 : Depends: libpython3.10-stdlib (= 3.10.13-1+focal1) but it is not installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
Then when I did a sudo apt --fix-broken install I got the following message
The following packages will be REMOVED:
libpython3-stdlib lsb-release python3 python3-apt python3-distro-info python3-pkg-resources python3-update-manager
python3-xkit python3-yaml python3.10 ubuntu-advantage-tools
0 upgraded, 0 newly installed, 11 to remove and 10 not upgraded.
After this operation, 4,073 kB disk space will be freed.
Do you want to continue? [Y/n] Y
(Reading database ... 261415 files and directories currently installed.)
Removing ubuntu-advantage-tools (28.1~22.04) ...
Traceback (most recent call last):
File "<string>", line 2, in <module>
File "/usr/lib/python3/dist-packages/uaclient/apt.py", line 14, in <module>
import apt # type: ignore
File "/usr/lib/python3/dist-packages/apt/__init__.py", line 26, in <module>
from apt.package import Package as Package, Version as Version
File "/usr/lib/python3/dist-packages/apt/package.py", line 32, in <module>
from http.client import BadStatusLine
ModuleNotFoundError: No module named 'http'
dpkg: error processing package ubuntu-advantage-tools (--remove):
installed ubuntu-advantage-tools package pre-removal script subprocess returned error exit status 1
dpkg: too many errors, stopping
/usr/sbin/policy-rc.d returned 101, not running 'start ua-timer.timer'
/usr/sbin/policy-rc.d returned 101, not running 'start ubuntu-advantage.service'
Processing was halted because there were too many errors.
I think there were some issues with dkpg package which is probably causing this issue. I tried to fix it using methods mentioned in other posts about dkpg but no luck. I am not very good with linux os either. Any help to resolve this would be highly appreciated!
