52
sudo apt-get install chromium-browser for some reason installs not a proper apt-get package but is installing the chromium snap.
I am aware that blocking such installs will not magically establish a maintained package, and would result in an installation failure. But I prefer to get error and install manually - from source or in unlikely cases from snap.
I want to never install anything using snap (for start, due to Snap Store closed-source practice). Especially not silently when I install using apt-get.
How can I disable snaps in gnome-software centre? is not answering my question as I want to get rid of snap infestation in apt - not in gnome-software-center.
muru
  • 207,228
You have to remove snapd from the system by
sudo apt-get autopurge snapd
and then create special configuration file for APT, as LinuxMint did:
cat <<EOF | sudo tee /etc/apt/preferences.d/nosnap.pref
# To prevent repository packages from triggering the installation of Snap,
# this file forbids snapd from being installed by APT.
# For more information: https://linuxmint-user-guide.readthedocs.io/en/latest/snap.html
Package: snapd Pin: release a=* Pin-Priority: -10 EOF
This will prevent Snaps installation in future.
N0rbert
  • 103,263
Besides setting files in /etc/apt, you can run apt-mark to prevent anything requiring snapd from installing, just after purge snapd:
$ sudo apt-mark hold snapd
For example, installing firefox in Ubuntu 22.04 (which is a snapd-based package) gives you an error:
$ sudo apt install firefox
Reading package lists... Done
Building dependency tree... Done
The following packages have unmet dependencies: firefox : PreDepends: snapd but it is not going to be installed E: Unable to correct problems, you have held broken packages.
The only way to break this rule is to do it explicitly:
$ sudo apt install snapd
The following NEW packages will be installed:
  snapd
The following held packages will be changed:
  snapd
0 upgraded, 1 newly installed, 0 to remove and 11 not upgraded.
Need to get 23.8 MB of archives.
After this operation, 102 MB of additional disk space will be used.
Do you want to continue? [Y/n]
Also, you can undo the effect via:
$ sudo apt-mark unhold snapd
