Environment:
  Motherboard: X570 AORUS ULTRA
  CPU: AMD Ryzen 9 3950X 16-Core Processor
  Distro: Ubuntu server + xfce4
  Ubuntu version: 21.04
  Kernel version: 5.11.0-17-generic
  Wifi hardware: Intel Corporation Wi-Fi 6 AX200 [8086:2723] (rev 1a)
  Boot: Single boot (No Windows. Just Ubuntu). Fast book disabled in bios.
This is a clean install. No issues during install.
The problem I am running into is that, although the OS detects the hardware, the link seems to be DOWN.
$ ip a
3: wlp6s0: <BROADCAST,MULTICAST> mtu 1500 qdisc noqueue state DOWN group default qlen 1000 link/ether xx:xx:xx:xx:xx:xx brd ff:ff:ff:ff:ff:ff
There are many similar messages on the net:
Intel Wi-fi 6 AX200 adapter not found on Ubuntu 20.04
Cannot get an Intel Corporation Wi-Fi 6 AX200 (rev 1a) to work with Mate 20.04
Will intel Wifi AX200 work with ubuntu 20.4 in WIFI 6 mode
However, I already have incorporated all the recommendations:
  1. Disabled fast boot in bios
  2. No dual boot
  3. Have the latest x570 bios firmware
  4. Have a newer Linux kernel
  5. Have the latest Intel AX200 wifi driver (/lib/firmware/iwlwifi-cc-a0-59.ucode)
I still cannot figure out how to get the wifi to work. Please help.
Here is some useful info:
$ sudo dmesg | grep iwl
iwlwifi 0000:06:00.0: enabling device (0000 -> 0002)
iwlwifi 0000:06:00.0: api flags index 2 larger than supported by driver
iwlwifi 0000:06:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 89.3.35.22
iwlwifi 0000:06:00.0: loaded firmware version 59.601f3a66.0 cc-a0-59.ucode op_mode iwlmvm
iwlwifi 0000:06:00.0: Detected Intel(R) Wi-Fi 6 AX200 160MHz, REV=0x340
iwlwifi 0000:06:00.0: base HW address: 70:9c:d1:51:95:91
iwlwifi 0000:06:00.0 wlp6s0: renamed from wlan0
$ lshw -C network WARNING: you should run this program as super-user. *-network
description: Wireless interface product: Wi-Fi 6 AX200 vendor: Intel Corporation physical id: 0 bus info: pci@0000:06:00.0 logical name: wlp6s0 version: 1a serial: xx:xx:xx:xx:xx:xx width: 64 bits clock: 33MHz capabilities: bus_master cap_list ethernet physical wireless configuration: broadcast=yes driver=iwlwifi driverversion=5.11.0-17-generic firmware=59.601f3a66.0 cc-a0-59.ucode latency=0 link=no multicast=yes wireless=IEEE 802.11 resources: irq:175 memory:fc800000-fc803fff
$ lsmod | grep iw iwlmvm 421888 0 mac80211 1028096 1 iwlmvm iwlwifi 376832 1 iwlmvm cfg80211 892928 3 iwlmvm,iwlwifi,mac80211
$ lspci -nn | grep Network 06:00.0 Network controller [0280]: Intel Corporation Wi-Fi 6 AX200 [8086:2723] (rev 1a) 07:00.0 Ethernet controller [0200]: Intel Corporation I211 Gigabit Network Connection [8086:1539] (rev 03)
Peter
  • 513
By default, Ubuntu server edition does not include the required packages wpa_supplicant and wireless-tools. To install them, with a temporary working internet connection by tethering, ethernet or whatever means possible, do:
sudo apt update
sudo apt install wpasupplicant wireless-tools
Several dependencies will also be installed.
Next, edit your netplan file to add your exact details. For servers, I recommend a static IP address so that you can easily SSH and FTP into it. Please be certain to select an address outside the DHCP pool in the router.
Next, remove your not-working netplan file:
sudo rm /etc/netplan/*.yaml
And create a new file.
sudo nano /etc/netplan/01-netcfg.yaml
I suggest:
network:
  version: 2
  renderer: networkd
  wifis:
    wlp6s0:
      dhcp4: no
      dhcp6: no
      addresses: [192.168.0.150/24]
      gateway4: 192.168.0.1
      nameservers:
        addresses: [192.168.0.1, 8.8.8.8]
      access-points:
        "network_ssid_name":
          password: "**********"
Of course, substitute your exact details here.
Please note that the network SSID name and the password are enclosed in quotes. Netplan is very specific about spacing and indentation. It accepts spaces but not tabs. Proofread carefully twice. Save (Ctrl+O followed by Enter) and exit (Ctrl+X followed by Enter) the nano text editor.
Follow with:
sudo netplan generate
sudo netplan apply
If there are no mistakes, you should connect immediately and automatically on boot.
chili555
  • 61,330
For me, this solved the issue (cited from the source below):
# run this to determine which firmware the kernal is looking for
modinfo iwlwifi | grep iwlwifi-cc
example output:
firmware: iwlwifi-cc-a0-50.ucode
go https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git/tree/ and download the firmware
copy file to /lib/firmware
sudo cp ~/Download/iwlwifi-cc-a0-50.ucode /lib/firmware
reboot
sudo reboot
check that firmware was loaded
sudo dmesg | grep iwlwifi | grep version
example output
[ 4.566709] iwlwifi 0000:05:00.0: loaded firmware version 50.3e391d3e.0 op_mode iwlmvm
https://gist.github.com/mixxen/339846df6f316416336d038090a3c848
JoeFox
  • 121
If you don't see your WiFi,(specially if you are on a fresh install) check if your fast boot is turned off in bio. If that didn't work, and you are in dual boot, you need to go into windows at less 1x then reboot, then your WiFi will reappear
Ali
  • 101
