In this case a Feb Smart card because I found it listed in an Ubuntu compatible list.
sudo lshw returns
*-network description: Wireless interface product: Wi-Fi 6 AX200 vendor: Intel Corporation physical id: 0 bus info: pci@0000:01:00.0 logical name: wlp1s0 version: 1a serial: 78:2b:46:d9:a5:35 width: 64 bits clock: 33MHz capabilities: pm msi pciexpress msix bus_master cap_list ethernet physical wireless configuration: broadcast=yes driver=iwlwifi driverversion=5.4.0-65-generic firmware=48.4fa0041f.0 latency=0 link=no multicast=yes wireless=IEEE 802.11 resources: irq:16 memory:ef000000-ef003fff sudo lspci -nnk | grep -e 0200 -e 0280 -A3
Yields
00:1f.6 Ethernet controller [0200]: Intel Corporation Ethernet Connection (5) I219-LM [8086:15e3] Subsystem: Dell Ethernet Connection (5) I219-LM [1028:07a1] Kernel driver in use: e1000e Kernel modules: e1000e 01:00.0 Network controller [0280]: Intel Corporation Wi-Fi 6 AX200 [8086:2723] (rev 1a) Subsystem: Intel Corporation Wi-Fi 6 AX200 [8086:0084] Kernel driver in use: iwlwifi Kernel modules: iwlwifi
sudo lshw -class network produces
I have:
  • downloaded and installed the latest version of the firmware from Intel
  • tried the Atheros drivers through Ath10k. They're all now blacklisted.
Only the iwlwifi driver got the Wifi and Bluetooth icons to appear on the toolbar.
When I try to connect to my Wifi netowrk, I get the password screen but the connection always fails. During the initial connection
sudo lshw -class network -short && nmcli device status
returns
H/W path Device Class Description ========================================================= /0/100/1d/0 wlp1s0 network Wi-Fi 6 AX200 /0/100/1f.6 enp0s31f6 network Ethernet Connection (5) I219-LM DEVICE TYPE STATE CONNECTION enp0s31f6 ethernet connected Wired connection 1 wlp1s0 wifi connecting (configuring) neonjohn 1 p2p-dev-wlp1s0 wifi-p2p disconnected -- lo loopback unmanaged
When the authentication screen is presented,
H/W path Device Class Description ========================================================= /0/100/1d/0 wlp1s0 network Wi-Fi 6 AX200 /0/100/1f.6 enp0s31f6 network Ethernet Connection (5) I219-LM DEVICE TYPE STATE CONNECTION enp0s31f6 ethernet connected Wired connection 1 wlp1s0 wifi connecting (need authentication) neonjohn 1 p2p-dev-wlp1s0 wifi-p2p disconnected -- lo loopback unmanaged
After entering the password H/W path Device Class Description
The connection always fails. "neonjohn" is the SSID of my network. The antennae are about 4 ft away from the router. I've reset the router several times.
With the bluetooth, the menu appears but it does nothing when I select "devices" even though I have a BlueTooth speaker sitting next to the antennae.
This is the third day I've been working on this problem and I'm at my wit's end. Please Help
John
More information
If I reboot and uninstall the driver and then reinstall it, the WiFi connects immediately.
sudo modprobe -r iwlwifi Producing
remove (/sbin/lsmod | grep -o -e ^iwlmvm -e ^iwldvm -e ^iwlwifi | xargs /sbin/rmmod) && /sbin/modprobe -r mac80211 rmmod mac80211 rmmod libarc4 rmmod cfg80211
then sudo modprobe iwlwifi producing
nsmod /lib/modules/5.4.0-65-generic/kernel/net/wireless/cfg80211.ko insmod /lib/modules/5.4.0-65-generic/kernel/drivers/net/wireless/intel/iwlwifi/iwlwifi.ko
The WiFi connects immediately.
Anyone have any thoughts about this? Thanks John
UPDATE 02/11/2021
Taking the above action disabled my wired ethernet port. I had to remove the driver to get my wired connection back.
I have now purchased and returned 3 PCIe cards recommended as being compatible. A WiFi dongle that worked on 16.04 also fails. It looks like Canonical screwed the pooch on networking on this release.
Two questions:
Does anyone know of a PCIe combo wifi/bluetooth card KNOWN to work with 20.04 LTS?
Has the networking been fixed in 21.04? I want to stay with LTS releases but I also want networking.
Thanks, John
Neon John
  • 139
I never solved this problem. I bought and returned 3 other linux-compatible PCIi cards. None would come up. Neither would an WiFi dongle. Looks like wireless networking is really screwed up on this release.
Anyone know whether 21.04 solved the network problem?
Thanks for all the help
John
Neon John
  • 139
