14
The wifi settings page complained that no wifi adapter can be found. here's some relevant information
lshw -C network
*-network UNCLAIMED
description: Network controller product: Wi-Fi 6 AX200 vendor: Intel Corporation physical id: 0 bus info: pci@0000:04:00.0 version: 1a width: 64 bits clock: 33MHz capabilities: cap_list configuration: latency=0 resources: memory:fc600000-fc603fff
lspci -knn | grep Net; rfkill list
04:00.0 Network controller [0280]: Intel Corporation Wi-Fi 6 AX200 [8086:2723] (rev 1a) 0: hci0: Bluetooth Soft blocked: no Hard blocked: no
i also tried to follow the instructions on this page https://wireless.wiki.kernel.org/en/users/drivers/iwlwifi/core_release and also downloaded the firmware file from here https://wireless.wiki.kernel.org/en/users/drivers/iwlwifi and copied it over to /lib/firmware
i also tried to boot in insecure mode but doesnt work either.
FYI, my kernel version is 5.4.0-42-generic and I'm running only ubuntu 20.04 on my PC (not dual-booting)
Does anyone know of a solution to this problem?
hans
  • 141
12 Answers12
11
I had the same issue with AX200 (rev1a). I have a dual-boot (Windows 10, Ubuntu) and I turned both Fast Boot and Secure Boot in BIOS off, but the Wi-Fi still didn't work. After running the command:
sudo dmesg | grep iwl
I saw an error:
failed with error -110
And I found in a conversation, that I need turn off Fast Boot in Windows too.
It helped me. It was a lot of time.
IncSaint
  • 111
After disabling the "Fast Startup" the issue got resolved for me.
Thanks
I had the same thing and tried a lot of different fixes. What i think fixed it was updating my kernel.
wget https://raw.githubusercontent.com/pimlie/ubuntu-mainline-kernel.sh/master/ubuntu-mainline-kernel.sh
chmod a+x ubuntu-mainline-kernel.sh
sudo ./ubuntu-mainline-kernel.sh
I restarted the PC and it didnt initially work so i turned the machine off. When i turned it back on in the morning, the wifi was back!
Im now running the following kernel and the wifi seems to be reliable.
#~ uname -r
5.8.0-050800-generic
The error i was getting was something about failing to load the module -110. Now i get the following:
#~ sudo dmesg | grep iwl
[    4.603886] iwlwifi 0000:52:00.0: enabling device (0000 -> 0002)
[    4.616449] iwlwifi 0000:52:00.0: Direct firmware load for iwlwifi-cc-a0-56.ucode failed with error -2
[    4.616872] iwlwifi 0000:52:00.0: Direct firmware load for iwlwifi-cc-a0-55.ucode failed with error -2
[    4.616974] iwlwifi 0000:52:00.0: Direct firmware load for iwlwifi-cc-a0-54.ucode failed with error -2
[    4.617037] iwlwifi 0000:52:00.0: Direct firmware load for iwlwifi-cc-a0-53.ucode failed with error -2
[    4.617393] iwlwifi 0000:52:00.0: Direct firmware load for iwlwifi-cc-a0-52.ucode failed with error -2
[    4.617447] iwlwifi 0000:52:00.0: Direct firmware load for iwlwifi-cc-a0-51.ucode failed with error -2
[    4.617503] iwlwifi 0000:52:00.0: Direct firmware load for iwlwifi-cc-a0-50.ucode failed with error -2
[    4.617559] iwlwifi 0000:52:00.0: Direct firmware load for iwlwifi-cc-a0-49.ucode failed with error -2
[    4.620011] iwlwifi 0000:52:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 43.2.23.17
[    4.620022] iwlwifi 0000:52:00.0: Found debug destination: EXTERNAL_DRAM
[    4.620027] iwlwifi 0000:52:00.0: Found debug configuration: 0
[    4.620484] iwlwifi 0000:52:00.0: loaded firmware version 48.4fa0041f.0 cc-a0-48.ucode op_mode iwlmvm
[    4.620500] iwlwifi 0000:52:00.0: Direct firmware load for iwl-debug-yoyo.bin failed with error -2
[    4.636288] iwlwifi 0000:52:00.0: Detected Intel(R) Wi-Fi 6 AX200 160MHz, REV=0x340
[    4.658356] iwlwifi 0000:52:00.0: Applying debug destination EXTERNAL_DRAM
[    4.658499] iwlwifi 0000:52:00.0: Allocated 0x00400000 bytes for firmware monitor.
[    4.826168] iwlwifi 0000:52:00.0: base HW address: a8:7e:ea:6c:93:f5
[    5.128612] iwlwifi 0000:52:00.0 wlp82s0: renamed from wlan0
[    7.117844] iwlwifi 0000:52:00.0: Applying debug destination EXTERNAL_DRAM
[    7.285828] iwlwifi 0000:52:00.0: FW already configured (0) - re-configuring
Some of the other things i tried were making sure i didnt have the hardware switch on and removing/reloading the kernel module:
sudo rmmod iwlmvm
sudo rmmod iwlwifi
sudo rfkill unblock all
sudo modprobe iwlwifi
sudo modprobe iwlmvm
I tried installing the driver direct from intel - https://www.intel.co.uk/content/www/uk/en/support/articles/000005511/network-and-i-o/wireless-networking.html But that didnt seem to work.
I tried installing the backports as well but again, that didnt seem to work for me.
sudo apt install backport-iwlwifi-dkms
In my /lib/firmware, i have a lot of iwlwifi ucode files now....
#~ ls *iwl
iwlwifi-1000-5.ucode   iwlwifi-3168-22.ucode    iwlwifi-7260-16.ucode   iwlwifi-7265D-16.ucode  iwlwifi-8265-22.ucode              iwlwifi-9260-th-b0-jf-b0-43.ucode
iwlwifi-100-5.ucode    iwlwifi-3168-27.ucode    iwlwifi-7260-17.ucode   iwlwifi-7265D-17.ucode  iwlwifi-8265-27.ucode              iwlwifi-9260-th-b0-jf-b0-46.ucode
iwlwifi-105-6.ucode    iwlwifi-3168-29.ucode    iwlwifi-7260-7.ucode    iwlwifi-7265D-21.ucode  iwlwifi-8265-31.ucode              iwlwifi-cc-a0-46.ucode
iwlwifi-135-6.ucode    iwlwifi-3945-2.ucode     iwlwifi-7260-8.ucode    iwlwifi-7265D-22.ucode  iwlwifi-8265-34.ucode              iwlwifi-cc-a0-48.ucode
iwlwifi-2000-6.ucode   iwlwifi-4965-2.ucode     iwlwifi-7260-9.ucode    iwlwifi-7265D-27.ucode  iwlwifi-8265-36.ucode              iwlwifi-Qu-b0-hr-b0-48.ucode
iwlwifi-2030-6.ucode   iwlwifi-5000-5.ucode     iwlwifi-7265-10.ucode   iwlwifi-7265D-29.ucode  iwlwifi-9000-pu-b0-jf-b0-33.ucode  iwlwifi-Qu-b0-jf-b0-48.ucode
iwlwifi-3160-10.ucode  iwlwifi-5150-2.ucode     iwlwifi-7265-12.ucode   iwlwifi-8000C-13.ucode  iwlwifi-9000-pu-b0-jf-b0-34.ucode  iwlwifi-Qu-c0-hr-b0-48.ucode
iwlwifi-3160-12.ucode  iwlwifi-6000-4.ucode     iwlwifi-7265-13.ucode   iwlwifi-8000C-16.ucode  iwlwifi-9000-pu-b0-jf-b0-38.ucode  iwlwifi-Qu-c0-jf-b0-48.ucode
iwlwifi-3160-13.ucode  iwlwifi-6000g2a-5.ucode  iwlwifi-7265-16.ucode   iwlwifi-8000C-21.ucode  iwlwifi-9000-pu-b0-jf-b0-41.ucode  iwlwifi-QuZ-a0-hr-b0-48.ucode
iwlwifi-3160-16.ucode  iwlwifi-6000g2a-6.ucode  iwlwifi-7265-17.ucode   iwlwifi-8000C-22.ucode  iwlwifi-9000-pu-b0-jf-b0-43.ucode  iwlwifi-QuZ-a0-jf-b0-48.ucode
iwlwifi-3160-17.ucode  iwlwifi-6000g2b-6.ucode  iwlwifi-7265-8.ucode    iwlwifi-8000C-27.ucode  iwlwifi-9000-pu-b0-jf-b0-46.ucode
iwlwifi-3160-7.ucode   iwlwifi-6050-5.ucode     iwlwifi-7265-9.ucode    iwlwifi-8000C-31.ucode  iwlwifi-9260-th-b0-jf-b0-33.ucode
iwlwifi-3160-8.ucode   iwlwifi-7260-10.ucode    iwlwifi-7265D-10.ucode  iwlwifi-8000C-34.ucode  iwlwifi-9260-th-b0-jf-b0-34.ucode
iwlwifi-3160-9.ucode   iwlwifi-7260-12.ucode    iwlwifi-7265D-12.ucode  iwlwifi-8000C-36.ucode  iwlwifi-9260-th-b0-jf-b0-38.ucode
iwlwifi-3168-21.ucode  iwlwifi-7260-13.ucode    iwlwifi-7265D-13.ucode  iwlwifi-8265-21.ucode   iwlwifi-9260-th-b0-jf-b0-41.ucode
So if updating the kernel driver dosent work, try those other things.
I found that when i updated my kernel driver, i had to switch my nvidia graphics to the open source driver as well as the kernel update seemed to break the graphics so that i couldnt connect external monitors. I did this through the UI by selecting Additional Drivers -> Using NVIDIA driver metapackage from nvidia-driver-450 (open source)
(Previously it was on 440-proprietary)
You can update the intel backports and wifi driver using this. It will update the kernel needed for the wifi driver. It worked for me
sudo add-apt-repository ppa:canonical-hwe-team/backport-iwlwifi
sudo apt-get update
sudo apt-get install backport-iwlwifi-dkms
If I ran inxi -Fxz it would show no driver for my Wi-Fi.
I had a new computer and had only booted into windows once. Used my Linux for about three days and then had switched and came back to Linux to find no Wi-Fi. It was as @IncSaint mentioned. Basically, Windows fast boot doesn't shut down all the way and saves some stuff to memory, interfering with Linux setup for Wi-Fi. The answer was to turn off fast boot.
on Windows 10 it should be in “Control Panel→Hardware and Sound→Power Options→System Settings”. Select “Choose what the power buttons do” to access the System Settings from the Power Options. Then disable the “Fast Startup” option in “Shutdown Settings”.
My access was slightly different - choose what power buttons do was in power options.
About dual-boot with Windows and "fast-boot" enabled
Greenonline
  • 2,182
Ryan M
  • 111
Okay, so if you just installed Linux from a running Windows installation, you may have had Fast Boot enabled. Try to fully power cycle the machine. The network card may be getting passive power, thus keeping itself in a disabled state, which Linux does not seem to be able to enable it from automatically. This fixed Wi-Fi on my system after many attempts at solving the issue.
Kai
My wifi adapter on Ubuntu 20.04.3 LTS sometimes also not working. Just tried turn-off (restart not working), unplug source cable from power supply(only turn-off-on also not working), turn-on without electricity, plug in source cable to power supply and turn-on. It is weird but wifi is back. I was motivated to do this, because I read and also experienced that after turn-off PC at night and turn-on at morning wifi was working.
Adam Studenik
  • 69
I tried a lot of solutions such as disabling fast boot, disabling secure boot, updating kernel and etc...
What finally worked was upgrading my Ubuntu 20.04 to 21.10.
Zanna
  • 72,312
m00m
What finally worked was to swap the card to another PCIEx1 slot.
May it will help someone
What worked for me was this:
sudo ifconfig wlp2s0 up # check ifconfig to get your wifi device name!
sudo nmcli radio wifi on
The secret sauce here seems to have been the nmcli command.
CherryDT
  • 101
Ok, i had to replace original wifi adapter with intel ax210. lspci shows no network card, but lsusb shows bluetooth (integrated in this card). After few hours i finaly found "disabled" wifi network in bios security (probably i tried to lock bugy adapter in this way). Hope this answer will help someone with similar problem.
El'
  • 101
If any of y'all are dual-booting with Windows, you may need to add a registry key to use UTC time in Windows. Running Zorin OS 16.1, also ran into the same issue in PopOS, both of which are Ubuntu-based forks. Seems to be some sort of clock synchronization issue.
The below link has instructions.
https://wiki.archlinux.org/title/System_time#UTC_in_Microsoft_Windows
Kevin
