First of all, let me say that it is different. I've found the "solution" present in this question but it does not work for me, probably because I'm using a led keyboard in Ubuntu. So let me explain:
Ubuntu version: 18.04.5 LTS Keyboard: CM Storm Devastator.
It's troublesome I usually need to run the command xset led on
to enable light in my keyboard, while also numlock and scrlock light doesn't work in Ubuntu.
When I turn on the LEDs using that command my numeric keyboard stop working and it turns into mouse keyboard (it turns off the numlock), but if I access to Universal Controls it is disabled (last option - mouse keys):
I have to manually turn it on, and then I have to turn it off.
Note: If I disable LEDs using xset led off, the numeric pad works fine. I need both. Numeric pad and LEDs.
My target is to be able to change the last option in this image to enable/disable it using the terminal.
Does anybody see that problem and found the solution?
Edit: I've also tried setxkbmap -option keypad:pointerkeys, keypad:legacy and numepad:pc, but it doesn't do anything.
