I have mousekeys turned on in the Universal Access menu and lots of posts as well as this documentation page:
https://help.ubuntu.com/11.10/ubuntu-help/mouse-mousekeys.html
mention that NUMLOCK or SHIFT+NUMLOCK toggles this on or off. Neither of these work for me. The only way I can apparently turn this feature off is using the Universal Access menu, which is annoying if all I want to do is toggle it off to type a few numbers.
I use mousekeys on Windows and it works fine.
I am running on Ubuntu 11.10 and my keyboard is a MS Ergonomic 4000.
I wonder if some other config setting is getting in the way?
jrg
  • 61,707
I had the same problem. I'm also (still) on Ubuntu 11.10.
In my everyday work I use mousekeys primarily because I like using the num-5 key for mouse key presses.
Then I discovered that in Unity you can do very nice window tiling (ctrl-alt-num4 sends a window to the left of the screen, ctrl-alt-num6 to the right, ctrl-alt-9 top-right, etc).
So to do my window tiling I want to momentarily disable mousekeys.
I found the answer here: http://ubuntuforums.org/showpost.php?p=11776864&postcount=4
I saved the script as ubuntu-toggle-mousekeys and when I need to I type:
bash ubuntu-toggle-mousekeys
... in my terminal.
Here's my very slightly amended script - I just added some comments really:
#!/bin/bash
# http://ubuntuforums.org/showthread.php?t=1942984
# I needed this when I connected a big monitor to my ubuntu laptop.
# Unity has nice window tiling shortcuts that need the number keypad to work.
# ctrl-alt-num4 sends a window left, ctrl-alt-num6 sends a window right, etc.
STATUS=$(gsettings get org.gnome.desktop.a11y.keyboard mousekeys-enable) #Are mousekeys on (true or false)
if [ "$STATUS" == "true" ]
then
  gsettings set org.gnome.desktop.a11y.keyboard mousekeys-enable false
  notify-send -i  "/usr/share/icons/gnome/48x48/devices/keyboard.png" "                    Mousekeys OFF"
  echo "Mousekeys are OFF - use ctrl-alt-num4 to send window left, ctrl-alt-num6 to send window right"
else
  gsettings set org.gnome.desktop.a11y.keyboard mousekeys-enable true
  notify-send -i  "/usr/share/icons/gnome/48x48/devices/keyboard.png" "                    Mousekeys ON"
  echo "Mousekeys are ON"
fi
mcaleaa
  • 46
bash code didn't work , try this :
#!/usr/bin/env ruby
r = `gsettings get org.gnome.desktop.a11y.keyboard mousekeys-enable`
p r
if r =~ /true/i
  `gsettings set org.gnome.desktop.a11y.keyboard mousekeys-enable false `
  `notify-send -i  "/usr/share/icons/gnome/48x48/devices/keyboard.png" "Mousekeys OFF" `
  puts "Mousekeys are OFF - use ctrl-alt-num4 to send window left, ctrl-alt-num6 to send window right"
else
  `gsettings set org.gnome.desktop.a11y.keyboard mousekeys-enable true `
  `notify-send -i  "/usr/share/icons/gnome/48x48/devices/keyboard.png" "Mousekeys ON" `
  p "Mousekeys are ON"
end
sevk
