I'm using LXQt in Lubuntu 20.04 Focal Fossa.
I'd like to get rid of the Livepatch indicator, that's within the system tray that's on my panel (the tray is full of c*** I don't need anyway!)
I looked for answers here:
but the suggestions did not work, or were not about removing livepatch.
I don't mind disabling it completely, or just removing the icon. And it can be just for my user, or globally.
einpoklum
  • 881
  • 32
I was able to remove the Livepatch system tray panel indicator in Lubuntu 20.04 disabling some options in autostart, similar to the comments of @guiverc to the original question. In lxqt configuration center, under session configuration options: autostart.
I disabled:
  • upgNotifier: /usr/lib/lubuntu-update-notifier/lubuntu-upg-notifier.sh
  • Update notifier: update-notifier
  • Ubuntu report try to sends metrics data on release upgrade: /usr/bin/ubuntu-report send upgrade
How to enter lxqt configuration center
How to disable updates notifications
I looked up in the source code and found that it checks com.ubuntu.update-notifier.show-livepatch-status-icon in gsettings but it is ignored. Seems to be a bug that should be reported to the package maintainer. In the meantime the following trick works:
rename or delete the following file
/usr/share/applications/software-properties-livepatch.desktop
Then logout from your session and log in again. The livepatch icon will be gone.
-3
If I read you correctly, to disable "Livepatch (Canonical Livepatch Service)"
ubuntu-advantage disable-livepatch -r
this will Disable the Livepatch service. If the -r option is given, the canonical-livepatch snap will be removed after the service is disabled. Would have been easier/better if Dconf would have worked to hide the icon though. I don't use lubuntu sorry.
-3
Sorry about that: Will this work then:
sudo canonical-livepatch disable
Or
sudo snap run canonical-livepatch disable
I've used both with sucess
