So I recently installed Focal Fossa and now I can't use any of my sftp/ftp profiles. What's even stranger is that I can use the Terminal to perform commands like scp/ssh on those very same servers I used to use the file browser for.
I tried following some of the things from this other post cannot-connect-to-server-in-nautilus, but to no avail.
The Software & Updates section didn't even have the field they mentioned; let alone any checkboxes.
Here is a print out of the sudo apt install gvfs-backends command:
Reading package lists... Done
Building dependency tree
gvfs-backends : Depends: libsmbclient (>= 2:4.10.0+dfsg) but 2:4.7.6+dfsg~ubuntu-0ubuntu2.21 is to be installed
I tried to follow the chain of unmet dependencies but it felt like trying to kill a hydra. The next layer deeper just had more and more issues. Any help would be greatly appreciated.
EDIT #1: Tried to restore my sources.list file to its defaults. No change. how-do-i-restore-the-default-repositories
Edit #2: Was asked for the following command outputs.
For sudo apt-get update
Hit:1 http://archive.canonical.com/ubuntu focal InRelease
Hit:2 http://archive.ubuntu.com/ubuntu focal InRelease
Hit:3 http://dl.google.com/linux/chrome/deb stable InRelease
Ign:4 http://extras.ubuntu.com/ubuntu focal InRelease
Err:5 http://extras.ubuntu.com/ubuntu focal Release
404 Not Found [IP: 91.189.88.91 80]
Hit:6 http://archive.ubuntu.com/ubuntu focal-security InRelease
Hit:7 http://archive.ubuntu.com/ubuntu focal-updates InRelease
Hit:8 http://archive.ubuntu.com/ubuntu focal-proposed InRelease
Hit:9 http://archive.ubuntu.com/ubuntu focal-backports InRelease
E: The repository 'http://extras.ubuntu.com/ubuntu focal Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
For sudo apt-cache policy gvfs-backends libsmbclient
gvfs-backends:
Installed: (none)
Candidate: 1.44.1-1ubuntu1
Version table:
1.44.1-1ubuntu1 500
500 http://archive.ubuntu.com/ubuntu focal/main amd64 Packages
libsmbclient:
Installed: 2:4.7.6+dfsg~ubuntu-0ubuntu2.21
Candidate: 2:4.11.6+dfsg-0ubuntu1.6
Version table:
2:4.11.6+dfsg-0ubuntu1.6 500
500 http://archive.ubuntu.com/ubuntu focal-security/main amd64 Packages
500 http://archive.ubuntu.com/ubuntu focal-updates/main amd64 Packages
2:4.11.6+dfsg-0ubuntu1 500
*** 2:4.7.6+dfsg~ubuntu-0ubuntu2.21 100
100 /var/lib/dpkg/status
EDIT #3:
Output of sudo apt-get upgrade && sudo apt-get dist-upgrade
Hit:1 http://dl.google.com/linux/chrome/deb stable InRelease
Hit:3 http://archive.canonical.com/ubuntu focal InRelease
Hit:4 http://archive.ubuntu.com/ubuntu focal-security InRelease
Hit:5 http://archive.ubuntu.com/ubuntu focal-updates InRelease
Hit:6 http://archive.ubuntu.com/ubuntu focal-proposed InRelease
Hit:7 http://archive.ubuntu.com/ubuntu focal-backports InRelease
Calculating upgrade... Done
The following packages were automatically installed and are no longer required:
linux-headers-generic-hwe-18.04 linux-image-generic-hwe-18.04
Use 'sudo apt autoremove' to remove them.
The following packages have been kept back:
gdb gir1.2-peas-1.0 libpeas-1.0-0 libsmbclient libwbclient0 samba-libs
0 upgraded, 0 newly installed, 0 to remove and 6 not upgraded.
Pastebin: output-of-grep-command
