EDIT: This is not a duplicate of the issue linked.
When I boot my computer with my headphones plugged in, they are working. When I unplug them and plug back in they usually do not work.
To get it working again, I have installed pavucontrol "PulseAudio Volume Control". I go into "Configuration" and I under my audio controller, I change the Profile to "Analog Stereo Output" from "Off". It's almost as if it doesn't automatically detect the headphone being plugged in. there shouldn't be an issue with the hardware because it works fine on Windows with my dual boot.
How do I make it so that automatically it picks up that I have plugged in the headphones and switches the profile for me?
Edit: Following this does not fix the issue: Ubuntu 18.04: Audio doesn't work unless I switch between outputs, it is also a different scenario.
Edit: Looks like this is also a similar issue: Speakers stop working after plugging/unplugging headphones - Ubuntu 20.04.1 LTS
