10
I have recently installed 12.04, but the sound is not working from both internal speakers, and from headphones when I connect them.
I have followed the instructions at https://wiki.ubuntu.com/DebuggingSoundProblems to no avail and submitted a bug report. I've also tried running alsamixer and unmuting a few more things, but that didn't work.
I've tried to upgrade alsa sound drivers by running:
sudo add-apt-repository ppa:ubuntu-audio-dev/ppa
sudo apt-get update
sudo apt-get install linux-alsa-driver-modules-$(uname -r)
however on the last command:
$ sudo apt-get install linux-alsa-driver-modules-$(uname -r)
Reading package lists... Done
Building dependency tree
E: Unable to locate package linux-alsa-driver-modules-3.2.0-24-generic-pae
E: Couldn't find any package by regex 'linux-alsa-driver-modules-3.2.0-24-generic-pae'
What should I do to try get sound functioning?
It might be worth noting that 10.04 previously ran on this machine with no sound problems.
oadams
  • 1,341
What solved this problem in my case was posted over at the Ubuntu Forums.
Append /etc/modprobe.d/alsa-base.conf with the following line:
options snd-hda-intel model=generic
Then restart your Ubuntu system.
Eliah Kagan
  • 119,640
oadams
  • 1,341
Just delete / rename the hidden file and folder .pulse and .pulse-cookie and then reboot.
If that doesn't work, try to install the package pavucontrol
jplatte
  • 1,290
