The computer was working fine until this morning I found out the hdd (two 4TB disk in RAID0 made with mdadm) had Input/output error.
Upon lsing the directory, I was met with:
ls: reading directory '.': Input/output error
And further inspection on dmseg shows that accessing my disk md127 causes some warnings and errors:
[5789751.027967] EXT4-fs warning (device md127): htree_dirblock_to_tree:994: inode #184288528: lblock 2: comm rg: error -5 reading directory block
[5789751.027970] EXT4-fs warning (device md127): htree_dirblock_to_tree:994: inode #184288528: lblock 2: comm rg: error -5 reading directory block
[5789751.027973] EXT4-fs warning (device md127): htree_dirblock_to_tree:994: inode #161822641: lblock 7: comm cp: error -5 reading directory block
[5789751.027975] EXT4-fs warning (device md127): htree_dirblock_to_tree:994: inode #184288528: lblock 2: comm rg: error -5 reading directory block
[5789751.027976] EXT4-fs warning (device md127): htree_dirblock_to_tree:994: inode #184288528: lblock 2: comm rg: error -5 reading directory block
[5789751.027979] EXT4-fs warning (device md127): htree_dirblock_to_tree:994: inode #184288528: lblock 2: comm rg: error -5 reading directory block
[5789751.027982] EXT4-fs warning (device md127): htree_dirblock_to_tree:994: inode #184288528: lblock 2: comm rg: error -5 reading directory block
[5789751.027986] EXT4-fs warning (device md127): htree_dirblock_to_tree:994: inode #184288528: lblock 2: comm rg: error -5 reading directory block
[5789751.027987] EXT4-fs warning (device md127): htree_dirblock_to_tree:994: inode #161822641: lblock 7: comm cp: error -5 reading directory block
[5789751.027989] EXT4-fs warning (device md127): htree_dirblock_to_tree:994: inode #184288528: lblock 2: comm rg: error -5 reading directory block
Reading up on this, I found several articles on fixing this by doing fsck (I'm using Ubuntu 18.04).
I also found someone having the same issue with them using RAID0 disk (but a very long time ago since it's kernel 4.0.0).
My disk seems healthy since the output of smartctl reads PASSED. And inode seems to be functioning since there is still a lot left (only used 7% of inodes).
What could be the cause of this spontaneous failure? I would like to know since I want to know how I could prevent it or be ready for it next time it happens.
Currently, I'm still copying over non-corrupted files, but I'm planning to fix it by fsck.
