I'm trying to use Sony WH-1000XM4 with my Ubuntu 18.04.
I'm able to pair using a Bluetooth dongle and blueman, but the problem is that the headphones are not recognized as a sound device:
  • In blueman - right click doesn't show "audio" options.
  • In pulse audio - the headphones don't appear in the output devices.
I already tried:
mv ~/.config/pulse/ ~/.config/pulse.old
systemctl --user restart pulseaudio
as suggested at 20-04-sony-wh-1000xm4-does-not-output-to-headset
and the solution at Sony Noise-Cancelling Headphones (WH-1000XM2/3) and bluetooth initial autoconnect
so far, nothing works.
How can I find what's the problem and fix?
In order to correctly pair Ubuntu with the headphones, you need to put them in pairing mode. (not needed when pairing other devices)
Hold power button for 7 second (even after it says power off), until you hear pairing mode.
Then, Ubuntu's Bluetooth will recognize an audio device named WH-1000XM4 (not LE_WH-1000XM4), and it will work. more details here.
Pablo Bianchi
  • 17,371
The same is true for the Sony earphones like WF-1000XM3/4/5. They need to be connected in pairing mode, too. Otherwise the "LE" will not be reckognized as an audio device (i. e. headset), just as "unknown". Seems to be a linux bluetooth stack issue. Connecting to a windows 11 computer works flawlessly.
