I have just downloaded the Ubuntu .iso file and installed it on a 16gb USB I bought. While going through the installation setup I ran into the installation type (since I want to run it on a USB, while everything I do saves on it). I encountered some sort of text that showed the following things.
/dev/sda
/dev/sda1 (sda2,3,4,5,6)
As said before, I want everything done on Ubuntu to be saved on the USB, but I just don't understand what I must do.
Thanks in advance!
Zanna
  • 72,312
Full Install vs Persistent install
With a Full install of Ubuntu to USB you can run any program that you can run on an internal drive.
Comparison between Persistent and Full install USB
Advantages of a persistent install:
  1. You can use the persistent pendrive to install Ubuntu to another computer.
  2. A persistent install takes up less space on the pendrive.
  3. You can reset the pendrive by overwriting the old casper-rw file with a new one.
  4. The install to pendrive takes less time.
Advantages of a Full install:
  1. You can update and upgrade.
  2. If you have problems or wish to modify, the solution is the same as with an internal install, (You can ask for help in these forums).
  3. No ugly startup / install screen.
  4. Better security, you can use full encryption
  5. You can use proprietary drivers.
  6. Hibernation works.
  7. A persistent install is limited to a 4GB casper-rw and a 4GB home-rw persistence file, to get more persistence requires persistence partitions. Once casper-rw is full, the drive will not boot.
  8. More efficient usage of disk space. Does not require reserved space for persistence.
  9. Faster boot, no automatic disk checking or Try Ubuntu/Install Ubuntu screen.
  10. You can do anything, run any program, use any driver, etc, that you can do on internal drive.
Note that once booted, both methods run at about the same speed. If the computer has lots of RAM Ubuntu should run mainly in RAM and there will not be a bi difference between running off internal HDD and USB3 flash drive.
Full Install Method Three methods for creating a Full install USB: How to Create a Full Install of Ubuntu 20.04 to USB Device Step by Step
C.S.Cameron
  • 20,530
  • 78
  • 125
