I've been experiencing the same problem. It seems that Ubuntu attempts to suspend itself but some hardware doesn't want to comply. Here are some repairs that might work:
1. open a terminal by holding ctrl+alt+t;
2. type: sudo gedit /etc/pm/sleep.d/20_custom-suspend;
3. press Enter and authenticate;
4. put the following text into the created file; save it and exit.
5. reboot and see if it works.
This little script comes from somewhere on the Internet but I cannot find the source...
EHCI_BUSES="0000:00:1a.0 0000:00:1d.0"
case "${1}" in
hibernate|suspend)
# Switch USB buses off
for bus in $EHCI_BUSES; do
echo -n $bus > /sys/bus/pci/drivers/ehci_hcd/unbind
done
resume|thaw)
# Switch USB buses back on
echo -n $bus > /sys/bus/pci/drivers/ehci_hcd/bind
done
esac
Please try this out and tell me your findings!
If that script doesn't work, you might want to try another:
#!/bin/sh
#inspired by http://art.ubuntuforums.org/showpost.php?p=9744970&postcount=19
#...and http://thecodecentral.com/2011/01/18/fix-ubuntu-10-10-suspendhibernate- not-working-bug
# tidied by tqzzaa :)
VERSION=1.1
DEV_LIST=/tmp/usb-dev-list
DRIVERS_DIR=/sys/bus/pci/drivers
DRIVERS="ehci xhci" # ehci_hcd, xhci_hcd
HEX="[[:xdigit:]]"
MAX_BIND_ATTEMPTS=2
BIND_WAIT=0.1
unbindDev() {
echo -n > $DEV_LIST 2>/dev/null
for driver in $DRIVERS; do
DDIR=$DRIVERS_DIR/${driver}_hcd
for dev in `ls $DDIR 2>/dev/null | egrep "^$HEX+:$HEX+:$HEX"`; do
echo -n "$dev" > $DDIR/unbind
echo "$driver $dev" >> $DEV_LIST
done
done
bindDev() {
if [ -s $DEV_LIST ]; then
while read driver dev; do
while [ $((MAX_BIND_ATTEMPTS)) -gt 0 ]; do
echo -n "$dev" > $DDIR/bind
if [ ! -L "$DDIR/$dev" ]; then
sleep $BIND_WAIT
else
break
fi
MAX_BIND_ATTEMPTS=$((MAX_BIND_ATTEMPTS-1))
done
done < $DEV_LIST
fi
rm $DEV_LIST 2>/dev/null
case "$1" in
hibernate|suspend) unbindDev;;
resume|thaw) bindDev;;
esac
