I am trying to upgrade from Ubuntu 18.04.5 to 20.04.1 via:
$ sudo do-release-upgrade
This fails as follows:
Could not calculate the upgrade
An unresolvable problem occurred while calculating the upgrade.
This was likely caused by:
Unofficial software packages not provided by Ubuntu Please use the tool 'ppa-purge' from the ppa-purge package to remove software from a Launchpad PPA and try the upgrade again.If none of this applies, then please report this bug using the command 'ubuntu-bug ubuntu-release-upgrader-core' in a terminal. If you want to investigate this yourself the log files in '/var/log/dist-upgrade' will contain details about the upgrade. Specifically, look at 'main.log' and 'apt.log'.
The tail of /var/log/dist-upgrade/main.log contains the following error:
2020-10-11 18:36:30,320 WARNING Can't mark 'ubuntu-desktop' for upgrade (E:Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.)
2020-10-11 18:36:31,747 ERROR Dist-upgrade failed: 'Broken packages after upgrade: colord'
2020-10-11 18:36:31,747 DEBUG abort called
2020-10-11 18:36:31,755 DEBUG openCache()
2020-10-11 18:36:37,070 DEBUG Comparing 4.15.0-117 with
2020-10-11 18:36:37,071 DEBUG Comparing 4.15.0-118 with 4.15.0-117
2020-10-11 18:36:37,824 DEBUG /openCache(), new cache size 99980
Here are the reverse package dependencies of colord:
$ apt-cache rdepends colord
colord
Reverse Depends:
colord-sensor-argyll
gnome-control-center
colord:i386
cups-filters
colord:i386
cups-daemon
colord:i386
cups
colord:i386
xiccd
colord:i386
krita
colord:i386
gnome-color-manager
colord:i386
foomatic-filters
colord:i386
dispcalgui
colord:i386
diffoscope
colord:i386
colord:i386
colord-data
colord:i386
argyll
colord:i386
libcolord2
colord:i386
libcolord-gtk1
colord:i386
colord:i386
cups-filters
colord:i386
cups-daemon
colord:i386
cups
colord:i386
colord-data
I recently had a segmentation fault issue with mesa and installed a version from ppa:kisak/kisak-mesa. This might cause the upgrade problem now.
The following would happen if I remove the colord package:
$ sudo apt-get remove colord
Reading package lists... Done
Building dependency tree
The following packages were automatically installed and are no longer required:
apg colord-data gnome-control-center-faces gnome-online-accounts libcolorhug2 libnss-myhostname linux-headers-4.15.0-117 linux-headers-4.15.0-117-generic
linux-image-4.15.0-117-generic linux-modules-4.15.0-117-generic linux-modules-extra-4.15.0-117-generic python3-macaroonbakery python3-nacl
python3-protobuf python3-pymacaroons python3-rfc3339 ubuntu-system-service
Use 'sudo apt autoremove' to remove them.
The following packages will be REMOVED:
colord gnome-control-center ubuntu-desktop
0 upgraded, 0 newly installed, 3 to remove and 8 not upgraded.
After this operation, 5,782 kB disk space will be freed.
Do you want to continue? [Y/n]
This does not sound like a good idea because last time I removed ubuntu-desktop the UI did no longer start-up. See linked post.
Question
How can I resolve the upgrade problem without risking the segmentation fault to reincarnate?
