After upgrading my Ubuntu from 18.10 to 19.04 some packages were held back but I didn't really care since I thought the issues will be resolved in a few weeks when dependencies will be upgradeable to proper versions for my OS. After a while that didn't happen and I've poked around these "held back" packages and see a problem, that also explains why my system load indicator widget and other sensors dependent widgets stopped working.
There are only 2 packages left that are held back: libsnmp30 sysstat. Both depend in one way or the other on libsensors5 which in turn depends on libsensors-config. Now I could try installing libsensors-config via sudo apt install libsensors-config but the (last) output that I get makes me think that's not a good idea, right?
$ sudo apt install sysstat
Reading package lists... Done
Building dependency tree
The following packages have unmet dependencies.
sysstat : Depends: libsensors5 (>= 1:3.5.0) but it is not going to be installed
$ sudo apt install libsensors5
libsensors5 : Depends: libsensors-config but it is not going to be installed
$ sudo apt install libsensors-config
The following packages were automatically installed and are no longer required:
accountsservice-ubuntu-schemas acl activity-log-manager aglfn apg appmenu-qt apt-config-icons-large apt-config-icons-large-hidpi apturl-common argyll argyll-ref bamfdaemon blender-data breeze-cursor-theme breeze-gtk-theme calculix-ccx catdoc cheese-common cinnamon-desktop-data cinnamon-l10n colord-data debconf-kde-data docbook-xml
docbook-xsl epstool evolution-data-server-common fonts-dejavu fonts-dejavu-extra fonts-freefont-otf fonts-hack fonts-noto-hinted fprintd freecad-common freecad-runtime gdal-data geoclue geoclue-ubuntu-geoip gir1.2-accounts-1.0 gir1.2-accountsservice-1.0 gir1.2-gck-1 gir1.2-gcr-3 gir1.2-gdata-0.0 gir1.2-gdm-1.0
gir1.2-gnomebluetooth-1.0 gir1.2-gstreamer-1.0 gir1.2-gweather-3.0 gir1.2-javascriptcoregtk-4.0 gir1.2-nm-1.0 gir1.2-nma-1.0 gir1.2-signon-1.0 gir1.2-totemplparser-1.0 gir1.2-upowerglib-1.0 gist gjs gkbd-capplet gnome-calculator gnome-control-center-faces gnome-screensaver gnome-session-common gnome-todo-common gnome-video-effects
gnuplot-data grilo-plugins-0.3-base gvfs-libs haveged hddtemp hdf5-helpers hplip-data hwdata ibverbs-providers ieee-data indicator-appmenu indicator-datetime indicator-keyboard indicator-messages indicator-power indicator-printers indicator-session indicator-sound inxi jayatana kactivities-bin kate5-data kde-cli-tools-data
kde-style-qtcurve-qt4 kdelibs5-data kdeplasma-addons-data kdiff3-doc kdoctools5 khotkeys-data kio-extras-data kpackagetool5 ktexteditor-data ktorrent-data kwayland-data kwin-data libaccounts-glib0 libaccounts-qt5-1 libaec-dev libaec0 libappstreamqt2 libaribb24-0 libarmadillo9 libarpack2 libattica0.4 libbamf3-2
libbasicusageenvironment1 libblas-dev libblosc1 libboost-program-options1.67.0 libboost-python1.67.0 libboost-regex1.67.0 libbrotli1 libcaf-openmpi-3 libcamel-1.2-62 libcddb2 libcdio-cdda2 libcdio-paranoia2 libcfitsio7 libcharls2 libchm1 libcinnamon-desktop4 libclang1-8 libclutter-1.0-common libcoarrays-openmpi-dev libcogl-common
libcolord-gtk1 libcolorhug2 libcolumbus1-common libcolumbus1v5 libcue2 libcxsparse3 libdap25 libdapclient6v5 libdazzle-1.0-0 libdbusmenu-qt2 libdcmtk14 libdecoration0 libdlrestrictions1 libdmapsharing-3.0-2 libdmtx0a libdolphinvcs5 libdouble-conversion1 libdrm-dev libdvbpsi10 libebackend-1.2-10 libebml4v5 libebook-1.2-19
libebook-contacts-1.2-2 libecal-1.2-19 libedata-book-1.2-25 libedata-cal-1.2-29 libedataserver-1.2-24 libeditorconfig0 libegl-mesa0 libegl1 libegl1-mesa libepsilon1 libepub0 libevdev2 libevent-2.1-6 libevent-core-2.1-6 libevent-pthreads-2.1-6 libfabric1 libfakekey0 libfam0 libfcitx-config4 libfcitx-gclient1 libfcitx-utils0 libfltk1.3
libfprint0 libframe6 libfreeimage3 libfreexl1 libfyba0 libgail-3-0 libgbm1 libgdal20 libgdata-common libgdata22 libgdbm5 libgdcm2.8 libgdm1 libgeis1 libgeoclue0 libgeonames-common libgeonames0 libgeos-3.7.1 libgeos-c1v5 libgeotiff2 libgif7 libgit2-27 libgjs0g libglapi-mesa libgles1 libgles2 libglpk40 libglvnd-core-dev libglvnd0
libgnome-autoar-0-0 libgnome-todo libgnomekbd-common libgnomekbd8 libgom-1.0-0 libgphoto2-6 libgphoto2-l10n libgphoto2-port12 libgpod-common libgpod4 libgps23 libgrail6 libgrantlee-templates5 libgraphene-1.0-0 libgraphicsmagick++-q16-12 libgraphicsmagick-q16-3 libgrilo-0.3-0 libgroupsock8 libgsettings-qt1 libgsf-1-114 libgsf-1-common
libgsound0 libhavege1 libhdf4-0-alt libhdf5-103 libhdf5-cpp-103 libhdf5-dev libhdf5-openmpi-103 libhfstospell10 libhttp-parser2.8 libhwloc-dev libhwloc-plugins libhwloc5 libibverbs-dev libibverbs1 libido3-0.1-0 libieee1284-3 libimagequant0 libinput-bin libinput10 libixml10 libjavascriptcoregtk-4.0-18 libjemalloc2 libjpeg-dev
libjpeg-turbo8-dev libjpeg8-dev libjs-jquery-ui libjsoncpp1 libjxr0 libkaccounts1 libkdecorations2-5v5 libkdecorations2private6 libkdecore5 libkdeui5 libkf5activities5 libkf5activitiesstats1 libkf5archive5 libkf5attica5 libkf5auth-data libkf5balooengine5 libkf5bluezqt-data libkf5bluezqt6 libkf5bookmarks-data libkf5calendarevents5
libkf5codecs-data libkf5codecs5 libkf5completion-data libkf5config-bin libkf5config-data libkf5configcore5 libkf5configgui5 libkf5configwidgets-data libkf5coreaddons-data libkf5coreaddons5 libkf5dbusaddons-bin libkf5dbusaddons-data libkf5dbusaddons5 libkf5declarative-data libkf5dnssd-data libkf5dnssd5 libkf5doctools5
libkf5emoticons-data libkf5filemetadata-bin libkf5filemetadata-data libkf5filemetadata3 libkf5globalaccel-data libkf5guiaddons5 libkf5holidays-data libkf5holidays5 libkf5i18n-data libkf5i18n5 libkf5iconthemes-data libkf5itemmodels5 libkf5itemviews-data libkf5jobwidgets-data libkf5js5 libkf5jsapi5 libkf5jsembed-data libkf5kcmutils-data
libkf5kdcraw5 libkf5kdelibs4support-data libkf5kexiv2-15.0.0 libkf5khtml-data libkf5kiontlm5 libkf5kipi-data libkf5konq-data libkf5networkmanagerqt6 libkf5newstuff-data libkf5notifications-data libkf5notifyconfig-data libkf5package-data libkf5package5 libkf5parts-data libkf5people-data libkf5peoplebackend5 libkf5prison5 libkf5pty-data
libkf5pty5 libkf5screen-bin libkf5screen7 libkf5service-data libkf5service5 libkf5solid5-data libkf5sonnet5-data libkf5sonnetcore5 libkf5su-data libkf5syndication5abi1 libkf5syntaxhighlighting-data libkf5syntaxhighlighting5 libkf5sysguard-data libkf5texteditor5-libjs-underscore libkf5textwidgets-data libkf5threadweaver5
libkf5unitconversion-data libkf5unitconversion5 libkf5wallet-data libkf5waylandclient5 libkf5waylandserver5 libkf5widgetsaddons-data libkf5windowsystem-data libkf5xmlgui-bin libkf5xmlgui-data libkf5xmlrpcclient-data libkfontinst5 libkfontinstui5 libkmlbase1 libkmldom1 libkmlengine1 libksgrd7 libkwinglutils12 libkwinxrenderutils12
libkworkspace5-5 liblapack-dev libldb1 liblightdm-gobject-1-0 liblirc-client0 liblivemedia64 liblmdb0 liblog4cplus-1.1-9 liblua5.2-0 libmad0 libmarkdown2 libmatroska6v5 libmbedcrypto3 libmbedtls12 libmbedx509-0 libmedc11 libmediaart-2.0-0 libmetacity1 libmicrodns0 libminizip1 libmozjs-60-0 libmtdev1 libmtp-common libmtp-runtime
libmtp9 libmuparser2v5 libmysqlclient20 libncurses-dev libnemo-extension1 libnetcdf-c++4 libnetcdf13 libnfs12 libnl-3-dev libnl-route-3-200 libnl-route-3-dev libnm-glib4 libnm-gtk0 libnm-util2 libnuma-dev libnux-4.0-common liboauth0 libocct-foundation-7.3 libocct-modeling-algorithms-7.3 libocct-modeling-data-7.3 libodbc1 libogdi3.2
libopencolorio1v5 libopencv-core3.2 libopencv-imgcodecs3.2 libopencv-imgproc3.2 libopencv-videoio3.2 libopengl0 libopenimageio2.0 libopenmpi-dev libopenmpi3 libopenmpt-modplug1 libopenvdb5.2 libpackagekitqt5-1 libpam-fprintd libpam-kwallet-common libpam-kwallet5 libpcre2-16-0 libperl5.26 libphonenumber7 libplacebo7
libplasma-geolocation-interface5 libpmix2 libpoppler-qt5-1 libpowerdevilui5 libprocesscore7 libproj13 libprotobuf-lite17 libproxy-tools libpsm-infinipath1 libpsm2-2 libpthread-stubs0-dev libpyside2-py3-5.11 libqalculate20 libqalculate20-data libqapt3 libqca-qt5-2 libqca-qt5-2-plugins libqhull7 libqmobipocket2 libqrencode4 libqrupdate1
libqscintilla2-qt5-l10n libqt4-dbus libqt4-declarative libqt4-network libqt4-script libqt4-svg libqt4-xml libqt4-xmlpatterns libqt5concurrent5 libqt5core5a libqt5dbus5 libqt5gui5-gles libqt5multimedia5 libqt5network5 libqt5positioning5 libqt5qml5 libqt5script5 libqt5sensors5 libqt5sql5 libqt5sql5-sqlite libqt5test5 libqt5texttospeech5
libqt5waylandclient5 libqt5webchannel5 libqt5webengine-data libqt5x11extras5 libqt5xml5 libqt5xmlpatterns5 libqtcurve-utils2 libqtdbus4 libqtgui4 librdmacm1 libre2-5 libreadline-dev librecad-data libresid-builder0c2a libsane-common libscim8v5 libsdl-image1.2 libsdl2-2.0-0 libsgutils2-2 libshiboken2-py3-5.11 libsidplay2 libsignon-glib1
libsignon-plugins-common1 libsignon-qt5-1 libsmbclient libsnapd-qt1 libsnmp-base libsocket++1 libspatialaudio0 libspatialite7 libspnav0 libspooles2.2 libssh2-1 libsuperlu5 libsysmetrics1 libsz2 libtagc0 libtalloc2 libtbb2 libtevent0 libtext-unidecode-perl libtimezonemap-data libtimezonemap1 libtinyxml2.6.2v5 libtorrent-rasterbar9
libtracker-control-2.0-0 libtracker-miner-2.0-0 libtracker-sparql-2.0-0 libunity-control-center1 libunity-gtk2-parser0 libunity-gtk3-parser0 libunity-misc4 libunity-settings-daemon1 libupnp13 liburiparser1 liburl-dispatcher1 libusageenvironment3 libva-wayland2 libvlc-bin libvlc5 libvlccore9 libvoikko1 libwayland-server0 libwbclient0
libwoff1 libwxbase3.0-0v5 libx11-dev libx11-xcb-dev libxapp1 libxatracker2 libxau-dev libxcb-composite0 libxcb-cursor0 libxcb-damage0 libxcb-dpms0 libxcb-dri2-0-dev libxcb-dri3-dev libxcb-glx0 libxcb-glx0-dev libxcb-icccm4 libxcb-image0 libxcb-keysyms1 libxcb-present-dev libxcb-randr0-dev libxcb-record0 libxcb-render-util0
libxcb-render0-dev libxcb-res0 libxcb-shape0 libxcb-shape0-dev libxcb-sync-dev libxcb-xfixes0-dev libxcb-xinerama0 libxcb-xinput0 libxcb-xkb1 libxcb-xv0 libxcb1-dev libxdamage-dev libxdmcp-dev libxerces-c3.2 libxext-dev libxfixes-dev libxfont2 libxkbcommon-x11-0 libxklavier16 libxml2-utils libxshmfence-dev libxvmc1 libxxf86dga1
libxxf86vm-dev libyaml-cpp0.6 libzeitgeist-1.0-1 libzipios++0v5 mesa-common-dev mesa-vulkan-drivers metacity-common mobile-broadband-provider-info mysql-common nautilus-data nemo-data network-manager-gnome octave-common odbcinst odbcinst1debian2 openmpi-bin openmpi-common oxygen-sounds perl-modules-5.26 pgadmin3-data pgagent
plasma-desktop-data plasma-discover-common policykit-1-gnome powerdevil-data printer-driver-postscript-hp proj-bin proj-data python-matplotlib-data python3-bs4 python3-cycler python3-debconf python3-feedparser python3-html5lib python3-kiwisolver python3-lxml python3-macaroonbakery python3-mako python3-markupsafe python3-matplotlib
python3-numpy python3-olefile python3-pexpect python3-pil python3-protobuf python3-ptyprocess python3-pyparsing python3-pyside2.qtcore python3-pyside2.qtxml python3-pyside2uic python3-renderpm python3-reportlab python3-reportlab-accel python3-rfc3339 python3-sip python3-soupsieve python3-talloc python3-tz python3-webencodings qdbus
qdbus-qt5 qml-module-org-kde-bluezqt qml-module-org-kde-kholidays qml-module-qt-labs-folderlistmodel qml-module-qt-labs-settings qml-module-qtqml-models2 qt-at-spi qt5-gtk-platformtheme qt5-image-formats-plugins qtchooser qtspeech5-flite-plugin qttranslations5-l10n ruby-json samba-libs sgml-base sgml-data shiboken2 shotwell-common
signon-plugin-oauth2 sni-qt socat sonnet-plugins sshfs switcheroo-control tex-common texinfo totem-common tracker tracker-extract tracker-miner-fs tree ubuntu-system-service ubuntu-touch-sounds unity-asset-pool unity-gtk-module-common unity-gtk2-module unity-gtk3-module unity-lens-applications unity-lens-files unity-lens-music
unity-lens-photos unity-lens-video unity-schemas unity-scope-calculator unity-scope-chromiumbookmarks unity-scope-colourlovers unity-scope-devhelp unity-scope-firefoxbookmarks unity-scope-home unity-scope-manpages unity-scope-openclipart unity-scope-texdoc unity-scope-tomboy unity-scope-video-remote unity-scope-virtualbox
unity-scope-yelp unity-scope-zotero unity-scopes-master-default unity-scopes-runner unity-services update-notifier-common vlc-bin vlc-data vlc-l10n vlc-plugin-base vlc-plugin-notify vlc-plugin-samba vlc-plugin-video-splitter x11-apps x11-session-utils x11-xkb-utils x11proto-core-dev x11proto-damage-dev x11proto-dev x11proto-fixes-dev
x11proto-xext-dev x11proto-xf86vidmode-dev xapps-common xfonts-base xfonts-scalable xinit xinput xml-core xorg-sgml-doctools xserver-common xserver-xorg-legacy xtrans-dev yelp-xsl zenity-common zlib1g-dev
Use 'sudo apt autoremove' to remove them.
The following additional packages will be installed:
libqt5gui5-gles
Suggested packages:
qtwayland5 lm-sensors
Recommended packages:
libqt5svg5
The following packages will be REMOVED
apturl baloo-kf5 blender bluedevil breeze browser-plugin-freshplayer-pepperflash cheese colord compiz compiz-gnome compiz-plugins-default copyq debconf-kde-helper deja-dup dolphin drkonqi evolution-data-server ffmpegthumbs frameworkintegration freecad freecad-python3 gdm3 gir1.2-gst-plugins-base-1.0 gir1.2-mutter-4 gir1.2-rb-3.0
gir1.2-totem-1.0 gir1.2-webkit2-4.0 gnome-calendar gnome-color-manager gnome-control-center gnome-getting-started-docs gnome-initial-setup gnome-online-accounts gnome-session-bin gnome-shell gnome-shell-extension-appindicator gnome-shell-extension-desktop-icons gnome-shell-extension-ubuntu-dock gnome-startup-applications gnome-todo
gnome-user-docs gnuplot-qt gstreamer1.0-clutter-3.0 gstreamer1.0-gl gstreamer1.0-gtk3 gvfs gvfs-backends gvfs-daemons gvfs-fuse gwenview hplip hud indicator-bluetooth kaccounts-providers kactivitymanagerd kamera kate kde-baseapps kde-cli-tools kde-config-gtk-style kde-config-screenlocker kde-config-sddm kde-plasma-desktop
kde-spectacle kde-style-breeze kde-style-breeze-qt4 kde-style-oxygen-qt5 kde-style-qtcurve-qt5 kdeconnect kded5 kdegraphics-thumbnailers kdialog kdiff3 keditbookmarks kfind kgamma5 khelpcenter khotkeys kimageformat-plugins kinfocenter kinit kio kio-extras kmenuedit konqueror konsole konsole-kpart kpackagelauncherqml kross krusader
kscreen ksshaskpass ktexteditor-katepart ktorrent kwalletmanager kwayland-integration kwin-common kwin-style-breeze kwin-x11 kwrite kwrited libavdevice58 libcheese-gtk25 libcheese8 libclutter-1.0-0 libclutter-gst-3.0-0 libclutter-gtk-1.0-0 libcogl-pango20 libcogl-path20 libcogl20 libcoin80c libcolorcorrect5 libdbusmenu-qt5-2
libdebconf-kde1 libedataserverui-1.2-2 libfltk-gl1.3 libfreecad-python3-0.18 libgl1 libgl1-mesa-dev libgl1-mesa-dri libgl1-mesa-glx libgl2ps1.4 libglew2.1 libglewmx1.13 libglu1-mesa libglvnd-dev libglx-mesa0 libglx0 libgoa-backend-1.0-1 libgstreamer-gl1.0-0 libhpmud0 libkf5auth5 libkf5authcore5 libkf5baloo5 libkf5baloowidgets-bin
libkf5baloowidgets-data libkf5baloowidgets5 libkf5bookmarks5 libkf5completion5 libkf5configwidgets5 libkf5crash5 libkf5declarative5 libkf5emoticons-bin libkf5emoticons5 libkf5globalaccel-bin libkf5globalaccel5 libkf5globalaccelprivate5 libkf5iconthemes-bin libkf5iconthemes5 libkf5idletime5 libkf5itemviews5 libkf5jobwidgets5
libkf5jsembed5 libkf5kcmutils5 libkf5kdelibs4support5 libkf5kdelibs4support5-bin libkf5khtml-bin libkf5khtml5 libkf5kiocore5 libkf5kiofilewidgets5 libkf5kiogui5 libkf5kiowidgets5 libkf5kipi32.0.0 libkf5kirigami2-5 libkf5konq6 libkf5krosscore5 libkf5krossui5 libkf5newstuff5 libkf5newstuffcore5 libkf5notifications5 libkf5notifyconfig5
libkf5parts-plugins libkf5parts5 libkf5people5 libkf5peoplewidgets5 libkf5plasma5 libkf5plasmaquick5 libkf5plotting5 libkf5purpose-bin libkf5purpose5 libkf5quickaddons5 libkf5runner5 libkf5service-bin libkf5solid5 libkf5sonnetui5 libkf5style5 libkf5su-bin libkf5su5 libkf5texteditor-bin libkf5texteditor5 libkf5textwidgets5
libkf5wallet-bin libkf5wallet5 libkf5webkit5 libkf5widgetsaddons5 libkf5windowsystem5 libkf5xmlgui5 libkf5xmlrpcclient5 libkscreenlocker5 libktorrent-l10n libktorrent6 libkwalletbackend5-5 libkwin4-effect-builtins1 libkwineffects12 libmutter-4-0 libnux-4.0-0 libocct-data-exchange-7.3 libocct-ocaf-7.3 libocct-visualization-7.3
liboctave-dev liboctave6 libokular5core9 liboxygenstyle5-5 liboxygenstyleconfig5-5 libphonon4qt5-4 libpolkit-qt5-1-1 libpowerdevilcore2 libprocessui7 libqapt3-runtime libqscintilla2-qt5-13 libqt5designer5 libqt5gui5 libqt5help5 libqt5hunspellinputmethod5 libqt5multimedia5-plugins libqt5multimediagsttools5 libqt5multimediaquick5
libqt5multimediawidgets5 libqt5opengl5 libqt5printsupport5 libqt5quick5 libqt5quickcontrols2-5 libqt5quicktemplates2-5 libqt5quickwidgets5 libqt5svg5 libqt5virtualkeyboard5 libqt5waylandcompositor5 libqt5webengine5 libqt5webenginecore5 libqt5webenginewidgets5 libqt5webkit5 libqt5widgets5 librecad libsane libsane-hpaio libsensors4
libsnmp30 libsoqt520 libtaskmanager6 libtotem0 libunity-core-6.0-9 libvtk7.1 libweather-ion7 libwebkit2gtk-4.0-37 libwxgtk3.0-0v5 libyelp0 mesa-utils milou mutter nautilus nautilus-share nemo nemo-fileroller nux-tools octave okular okular-extra-backends pgadmin3 phonon4qt5 phonon4qt5-backend-vlc plasma-browser-integration
plasma-dataengines-addons plasma-desktop plasma-discover plasma-discover-snap-backend plasma-framework plasma-integration plasma-pa plasma-widgets-addons plasma-workspace polkit-kde-agent-1 powerdevil printer-driver-hpcups python3-pivy python3-pyqt5 python3-pyside2.qtgui python3-pyside2.qtopengl python3-pyside2.qtsvg
python3-pyside2.qtuitools python3-pyside2.qtwidgets qapt-batch qbittorrent qml-module-org-kde-activities qml-module-org-kde-draganddrop qml-module-org-kde-kcm qml-module-org-kde-kconfig qml-module-org-kde-kcoreaddons qml-module-org-kde-kio qml-module-org-kde-kirigami2 qml-module-org-kde-kquickcontrols
qml-module-org-kde-kquickcontrolsaddons qml-module-org-kde-kwindowsystem qml-module-org-kde-newstuff qml-module-org-kde-purpose qml-module-org-kde-qqc2desktopstyle qml-module-org-kde-runnermodel qml-module-org-kde-solid qml-module-qtgraphicaleffects qml-module-qtmultimedia qml-module-qtquick-controls
qml-module-qtquick-controls-styles-breeze qml-module-qtquick-controls2 qml-module-qtquick-dialogs qml-module-qtquick-layouts qml-module-qtquick-privatewidgets qml-module-qtquick-templates2 qml-module-qtquick-virtualkeyboard qml-module-qtquick-window2 qml-module-qtquick2 qml-module-qtwebengine qml-module-qtwebkit
qml-module-ubuntu-onlineaccounts qtvirtualkeyboard-plugin qtwayland5 rhythmbox-plugins sane-utils sddm sddm-theme-breeze session-shortcuts shotwell simple-scan software-properties-qt sysstat systemsettings totem totem-plugins ubuntu-desktop ubuntu-desktop-minimal ubuntu-docs ubuntu-release-upgrader-gtk ubuntu-release-upgrader-qt
ubuntu-session unity unity-control-center unity-greeter unity-session unity-settings-daemon update-manager update-notifier user-manager vlc vlc-plugin-qt vlc-plugin-skins2 vlc-plugin-video-output vlc-plugin-visualization x11-utils xdg-desktop-portal-kde xorg xserver-xephyr xserver-xorg xserver-xorg-core xserver-xorg-input-all
xserver-xorg-input-libinput xserver-xorg-input-synaptics xserver-xorg-input-wacom xserver-xorg-video-all xserver-xorg-video-amdgpu xserver-xorg-video-ati xserver-xorg-video-fbdev xserver-xorg-video-intel xserver-xorg-video-nouveau xserver-xorg-video-qxl xserver-xorg-video-radeon xserver-xorg-video-vesa xserver-xorg-video-vmware
xwayland yelp zenity
The following NEW packages will be installed
libqt5gui5-gles libsensors-config
0 to upgrade, 2 to newly install, 378 to remove and 0 not to upgrade.
Need to get 2,829 kB of archives.
After this operation, 1,482 MB disk space will be freed.
Do you want to continue? [Y/n] n
Abort.
Can anyone advise me on what to do here? I don't know what would happen exactly if I tried installing libsensors-config since it seems to want to remove xserver-*, ubuntu-*, *mesa* (without reinstalling new versions?) and a whole bunch of other important stuff, but I don't think it'd be good for my system...
Update 1:
Here is my sources.list:
$ cat /etc/apt/sources.list
# See http://help.ubuntu.com/community/UpgradeNotes for how to upgrade to
# newer versions of the distribution.
deb http://ftp.arnes.si/pub/mirrors/ubuntu/ disco main restricted
## Major bug fix updates produced after the final release of the
## distribution.
deb http://ftp.arnes.si/pub/mirrors/ubuntu/ disco-updates main restricted
## N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
## team. Also, please note that software in universe WILL NOT receive any
## review or updates from the Ubuntu security team.
deb http://ftp.arnes.si/pub/mirrors/ubuntu/ disco universe
deb http://ftp.arnes.si/pub/mirrors/ubuntu/ disco-updates universe
## team, and may not be under a free licence. Please satisfy yourself as to
## your rights to use the software. Also, please note that software in
## multiverse WILL NOT receive any review or updates from the Ubuntu
## security team.
deb http://ftp.arnes.si/pub/mirrors/ubuntu/ disco multiverse
deb http://ftp.arnes.si/pub/mirrors/ubuntu/ disco-updates multiverse
## N.B. software from this repository may not have been tested as
## extensively as that contained in the main release, although it includes
## newer versions of some applications which may provide useful features.
## Also, please note that software in backports WILL NOT receive any review
## or updates from the Ubuntu security team.
## Uncomment the following two lines to add software from Canonical's
## 'partner' repository.
## This software is not part of Ubuntu, but is offered by Canonical and the
## respective vendors as a service to Ubuntu users.
deb http://ftp.arnes.si/pub/mirrors/ubuntu/ disco-security main restricted
deb http://ftp.arnes.si/pub/mirrors/ubuntu/ disco-security universe
deb http://ftp.arnes.si/pub/mirrors/ubuntu/ disco-security multiverse
deb https://dl.winehq.org/wine-builds/ubuntu/ disco main
deb https://download.opensuse.org/repositories/Emulators:/Wine:/Debian/xUbuntu_19.04 ./
# deb-src https://download.opensuse.org/repositories/Emulators:/Wine:/Debian/xUbuntu_19.04 ./
Update 2:
My apt-cache policy output (also included libsensors4 if that helps in any way):
$ apt-cache policy sysstat libsensors5 libsensors-config libsensors4
sysstat:
Installed: 12.0.1-1
Candidate: 12.0.1-1build1
Version table:
12.0.1-1build1 500
500 http://ftp.arnes.si/pub/mirrors/ubuntu disco/main amd64 Packages
*** 12.0.1-1 100
100 /var/lib/dpkg/status
libsensors5:
Installed: (none)
Candidate: 1:3.5.0-3ubuntu1
Version table:
1:3.5.0-3ubuntu1 500
libsensors-config:
Installed: (none)
Version table:
500 http://ftp.arnes.si/pub/mirrors/ubuntu disco/main i386 Packages
libsensors4:
Installed: 1:3.4.0-4
Candidate: 1:3.4.0-4
Version table:
*** 1:3.4.0-4 100
Update 3:
After trying to "manually" download and install the libsensors5 via dpkg I got this:
$ sudo dpkg -i --force-all libsensors-config_3.5.0-3ubuntu1_all.deb libsensors5_3.5.0-3ubuntu1_amd64.deb
Selecting previously unselected package libsensors-config.
dpkg: considering removing libsensors4:amd64 in favour of libsensors-config ...
dpkg: warning: ignoring dependency problem with removal of libsensors4:amd64:
sysstat depends on libsensors4 (>= 1:3.0.0)
libsensors4:amd64 is to be removed.
libsnmp30:amd64 depends on libsensors4 (>= 1:3.0.0)
libgl1-mesa-dri:amd64 depends on libsensors4 (>= 1:3.0.0)
dpkg: yes, will remove libsensors4:amd64 in favour of libsensors-config
(Reading database ... 295245 files and directories currently installed.)
Preparing to unpack libsensors-config_3.5.0-3ubuntu1_all.deb ...
Unpacking libsensors-config (1:3.5.0-3ubuntu1) ...
Selecting previously unselected package libsensors5:amd64.
Preparing to unpack libsensors5_3.5.0-3ubuntu1_amd64.deb ...
Unpacking libsensors5:amd64 (1:3.5.0-3ubuntu1) ...
Setting up libsensors-config (1:3.5.0-3ubuntu1) ...
Installing new version of config file /etc/sensors3.conf ...
Setting up libsensors5:amd64 (1:3.5.0-3ubuntu1) ...
Processing triggers for libc-bin (2.29-0ubuntu2) ...
$ sudo apt remove libsensors4
Package 'libsensors4' is not installed, so not removed
You might want to run 'apt --fix-broken install' to correct these.
libgl1-mesa-dri : Depends: libsensors4 (>= 1:3.0.0) but it is not installable
libsnmp30 : Depends: libsensors4 (>= 1:3.0.0) but it is not installable
sysstat : Depends: libsensors4 (>= 1:3.0.0) but it is not installable
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
$ sudo apt -f install
Correcting dependencies... failed.
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
E: Unable to correct dependencies
And I still have the same packages held back. sudo apt upgrade gives me the same output as sudo apt -f install.
However now libsensors5 and libsensors-config seem to be installed?
sysstat:
Installed: 12.0.1-1
Version table:
12.0.1-1build1 500
*** 12.0.1-1 100
libsensors5:
Installed: 1:3.5.0-3ubuntu1
Version table:
*** 1:3.5.0-3ubuntu1 500
libsensors-config:
Version table:
libsensors4:
Installed: (none)
Candidate: (none)
Version table:
1:3.4.0-4 -1
The new problem is that I can't install any packages now via apt since it's always telling me to fix dependency isses apt --fix-broken install which doesn't help/fix anything.
Update 4:
apt-cache policy with just the 3 http://archive.ubuntu.com/ubuntu in the sources.list (as per Olimjon's suggestion):
$ apt-cache policy libgl1-mesa-dri libsnmp30
libgl1-mesa-dri:
Installed: 19.1~git1904141930.89b02b~oibaf~c
Candidate: 19.1~git1904141930.89b02b~oibaf~c
Version table:
*** 19.1~git1904141930.89b02b~oibaf~c 100
19.0.2-1ubuntu1 500
500 http://archive.ubuntu.com/ubuntu disco/main amd64 Packages
libsnmp30:
Installed: 5.7.3+dfsg-1.8ubuntu3.18.10.1
Candidate: 5.7.3+dfsg-5ubuntu1
Version table:
5.7.3+dfsg-5ubuntu1 500
*** 5.7.3+dfsg-1.8ubuntu3.18.10.1 100
