53
I have a MacBook Pro and only use Ubuntu on it. I just upgraded from 18.04 to 20.04.
Now when I start the computer it says:
Failed to Set MokListRT: Invalid Parameter
Could not create mokListRT: Invalid Parameter
Importing MOK states has failed: import_mok_state() failed: Invalid Parameter
Continuing boot since secure mode is disabled.
Does anyone know EXACTLY how I can fix this?? Step-by-step process I don't want to mess anything up trying to fix this.
karel
  • 122,292
  • 133
  • 301
  • 332
ubuntu18help
  • 631
You have to replace shimx64.efi with grubx64.efi as follows:
sudo su -
cd /boot/efi/EFI/ubuntu
cp grubx64.efi shimx64.efi
reboot
Shibiwan
  • 569
This is caused by Bug #1867092 and the proposed workaround (see comment #23) is:
apt-get purge shim
grub-install /dev/sda1 #replace sda1 with the correct grub partition for you
That solution worked for me.
Note that the best voted answer to this question, which is copying grubx64.efi over shimx64.efi, will be undone with each shim update according to that bug page.
Jaydin
  • 1,571
Solution that works on my 2010 iMac. Install rEFInd and make sure to boot from the option that specifies grubx64.efi.
