I carefully tried all steps here: https://wiki.winehq.org/Ubuntu
(it's core is equivalent to what is here: How to install and configure Wine?)
but when trying to install the dependencies, I end up with errors like:
Note, selecting 'libasound2-data' instead of 'libasound2-data:i386'
Basically it is saying it wont install the i386 no matter what I try...
If there is no error with some package, it asks me to uninstall a huge lot of packages I don't want to...
about the FAQ https://wiki.winehq.org/FAQ#How_do_I_solve_dependency_errors_when_trying_to_install_Wine.3F
the only extra repository I have enabled is: https://dl.winehq.org/wine-builds/ubuntu/ This means, there is no other PPAs that could cause a conflict and I am having problems with vanilla ubuntu 20.04...
I cant get past this command:
sudo apt install --install-recommends winehq-stable
even trying to use the FAQ and other tips...
Can someone at least say, before this question gets closed (despite I disagree), if you managed to install Wine on ubuntu 20.04 with i386 (win32) support?
trying this command: sudo add-apt-repository --remove 'deb https://dl.winehq.org/wine-builds /ubuntu/ focal main' && sudo apt update && sudo apt install -y wine32 wine64 wine-stable
fails with:
The following packages have unmet dependencies. wine-stable : Depends: wine-stable-i386 (= 5.0.2~focal) wine32:i386 : Depends: libwine:i386 (= 5.0-3ubuntu1) but it is not going to be installed E: Unable to correct problems, you have held broken packages.
WHY IT WONT INSTALL THE DEPENDENCIES? it says "but it is not going to be installed" :( ...
when trying these:
$sudo apt install --install-recommends winehq-stable #requires wine-stable
$sudo apt install --install-recommends wine-stable #requires wine-stable-i386
$sudo apt install --install-recommends wine-stable-i386 #quite a mess...
The following packages have unmet dependencies. wine-stable-i386:i386 : Depends: libasound2:i386 (>= 1.0.16) but it is not going to be installed Depends: libfaudio0:i386 (>= 19.06.07) but it is not going to be installed Depends: libglib2.0-0:i386 (>= 2.12.0) but it is not going to be installed Depends: libgphoto2-6:i386 (>= 2.5.10) but it is not going to be installed Depends: libgphoto2-port12:i386 (>= 2.5.10) but it is not going to be installed Depends: libgstreamer-plugins-base1.0-0:i386 (>= 1.0.0) but it is not going to be installed Depends: libgstreamer1.0-0:i386 (>= 1.4.0) but it is not going to be installed Depends: libldap-2.4-2:i386 (>= 2.4.7) but it is not going to be installed Depends: libopenal1:i386 (>= 1.14) but it is not going to be installed Depends: libpulse0:i386 (>= 0.99.1) but it is not going to be installed Depends: libudev1:i386 (>= 183) but it is not going to be installed Depends: libxml2:i386 (>= 2.9.0) but it is not going to be installed Depends: libasound2-plugins:i386 but it is not going to be installed Recommends: libcups2:i386 but it is not going to be installed Recommends: libdbus-1-3:i386 but it is not going to be installed Recommends: libglu1-mesa:i386 but it is not going to be installed or libglu1:i386 Recommends: libosmesa6:i386 but it is not going to be installed Recommends: libsane:i386 but it is not going to be installed or libsane1:i386 Recommends: libsdl2-2.0-0:i386 but it is not going to be installed Recommends: libtiff5:i386 but it is not going to be installed Recommends: libxslt1.1:i386 but it is not going to be installed E: Unable to correct problems, you have held broken packages.
and finally if I try to install these i386 stuff it asks to remove like 1.5GB of packages, like it want to convert my system to a 32 bits thing, and not compatible with 32bits...
trying with aptitude
$sudo aptitude install wine-stable-i386
I see these as a problem
  Remove the following packages:
  1.  mesa-vdpau-drivers [20.0.8-0ubuntu1~20.04.1 (now)]
  2.  vdpau-driver-all [1.3-1ubuntu2 (focal, now)]
    Leave the following dependencies unresolved:
  3. libgstreamer-plugins-base1.0-0:i386 recommends gstreamer1.0-plugins-base:i386
  4. libvulkan1:i386 recommends mesa-vulkan-drivers:i386 | vulkan-icd:i386
  5. libopenal1:i386 recommends libasound2:i386 (>= 1.0.16)
  6. wine-stable-i386:i386 recommends libcups2:i386
  7. wine-stable-i386:i386 recommends libdbus-1-3:i386
  8. wine-stable-i386:i386 recommends libglu1-mesa:i386 | libglu1:i386
  9. wine-stable-i386:i386 recommends libosmesa6:i386
  10. wine-stable-i386:i386 recommends libsane:i386 | libsane1:i386
  11. wine-stable-i386:i386 recommends libsdl2-2.0-0:i386
  12. wine-stable-i386:i386 recommends libtiff5:i386
  13. wine-stable-i386:i386 recommends libxslt1.1:i386
if I try to choose them, aptitude will never end trying to calculate stuff, with a lot of "package x breaks package y" and a huge lot of conflicts:
$sudo aptitude install wine-stable-i386 gstreamer1.0-plugins-base:i386 mesa-vulkan-drivers:i386 libasound2:i386  libcups2:i386 libdbus-1-3:i386 libglu1-mesa:i386 libosmesa6:i386 libsane:i386 libsdl2-2.0-0:i386 libtiff5:i386 libxslt1.1:i386
Actually, aptitude is just scaring me... I dont want to mess my system just to run win32 stuff.
I am checking what chroot can do now, I dont want to mess my OS...
These instructions are for 20.04 ubuntu focal, but may work with other releases.
Based on https://wiki.winehq.org/Building_Wine#Chroot
$ sudo apt-get install schroot debootstrap
create this file with ex.: sudo geany /etc/schroot/chroot.d/ubuntu_i386.conf AND set your user name properly on it!
$ cat /etc/schroot/chroot.d/ubuntu_i386.conf
[ubuntu_i386]
description=Ubuntu Release 32-Bit
personality=linux32
directory=/srv/chroot/ubuntu_i386
root-users=YOURUSERNAME
type=directory
users=YOURUSERNAME
$ sudo mkdir -p /srv/chroot/ubuntu_i386
where is focal use your release name!!!
$ sudo debootstrap --variant=minbase --arch=i386 focal /srv/chroot/ubuntu_i386 http://archive.ubuntu.com/ubuntu/
$ sudo cp /etc/apt/sources.list /srv/chroot/ubuntu_i386/etc/apt/
this will generate a command line to use later!
$ echo apt install `apt-cache depends ubuntu-minimal |egrep -v ":i386|ubuntu-minimal" |sed -e 's"Depends:""' -e 's"Recommends:""' |tr -d '\n'`
apt install ... # copy it
go to CHROOT
$ schroot -c ubuntu_i386 -u root
$ apt-get update
$ apt-get install ubuntu-minimal # this may fail
if apt-get install ubuntu-minimal fails, use the copied apt install ... from above. I had to remove some packages tho and it ended up like this on focal: apt install adduser apt apt-utils bzip2 debconf debconf-i18n e2fsprogs init iproute2 kmod less locales lsb-release mawk mount netbase netcat-openbsd passwd procps python3 sensible-utils sudo tzdata ubuntu-keyring udev vim-tiny whiptail
$ apt-get install wine # put a happy smile here! :)
$ exit
on HOST now (based on https://unix.stackexchange.com/a/47579/30352):
lets grant it can run X apps in the host
copy the below line, note that the 1st parameter "YourPCName/unix:" may not have the display number!!!
$ xauth list
YourPCName/unix:  MIT-MAGIC-COOKIE-1  39825672cb45c29b7c49b7
if needed, take note of the display number you will need it below
$ declare -p DISPLAY
declare -x DISPLAY=":1"
get back to chroot as normal user
inside CHROOT
it needs the display number after ':'
$ xauth add "YourPCName/unix:1" "MIT-MAGIC-COOKIE-1" "39825672cb45c29b7c49b7"
$ xauth list #confirm it worked
YourPCName/unix:1  MIT-MAGIC-COOKIE-1  39825672cb45c29b7c49b7
QOL, use the display number here too
$ export DISPLAY=:1
$ xterm # test it!
$ wine explorer # test with a smile! :)
To mount --bind directories inside schroot, use these instructions: https://unix.stackexchange.com/a/609808/30352
Basically, you will need to mount --bind at /run/schroot/mount/ubuntu_i386-... and NOT at /srv/chroot/ubuntu_i386 !!!
Winetricks will require cabextract.
Download and install these 2 with dpkg -i ...:
https://launchpad.net/ubuntu/bionic/i386/libmspack0/0.6-3ubuntu0.3
https://launchpad.net/ubuntu/bionic/i386/cabextract/1.6-1.1
(yes, the bionic package works on focal)
It ends up with about 1.2GB btw.
