I followed the following steps So first I confirmed that the multiverse Ubuntu repository is enabled:
$ sudo add-apt-repository multiverse
$ sudo apt update
and then I installed the steam package:
$ sudo apt install steam and then I tried to execute the following command:
$ steam
and then;
   libgl1-mesa-dri:i386, libgl1:i386, libc6:i386
[sudo] password for user:```
I enter my password and then this appears:
[sudo] password for veer:
Reading package lists... Done
Building dependency tree
libc6:i386 : Depends: libgcc-s1:i386 but it is not going to be installed
             Depends: libcrypt1:i386 (>= 1:4.4.10-10ubuntu4) but it is not going to be installed
libgl1:i386 : Depends: libglx0:i386 (= 1.3.1-1ubuntu0.20.04.1) but it is not going to be installed
libgl1-mesa-dri:i386 : Depends: libgcc-s1:i386 (>= 4.2) but it is not going to be installed
                       Depends: libglapi-mesa:i386 (= 20.0.8-0ubuntu1~20.04.1) but it is not going to be installed
                       Depends: libllvm10:i386 (>= 1:9~svn298832-1~) but it is not going to be installed
                       Depends: libstdc++6:i386 (>= 5.2) but it is not going to be installed
Press return to continue:```
I press return and then after some time this appears
`You are missing the following 32-bit libraries, and Steam may not run:
libGL.so.1
libstdc++.so.6
libstdc++.so.6
libstdc++.so.6
libstdc++.so.6
libgcc_s.so.1
libstdc++.so.6
libstdc++.so.6
libgcc_s.so.1
libstdc++.so.6
libgcc_s.so.1
libdrm.so.2`
I do not know what to do next. Please help
</code></pre>
