Referring to the Ask-Ubuntu link here, I am hoping to use the following CL term to make an input the default input using pactl set-default-sink. Despite what I believe is proper syntax, I continue to get Failure: No such entity.
So for example if I run
pactl list short sources
1 alsa_output.pci-0000_09_00.1.hdmi-stereo-extra1.monitor module-alsa-card.c s16le 2ch 44100Hz SUSPENDED
2 alsa_output.pci-0000_0b_00.4.iec958-stereo.monitor module-alsa-card.c s16le 2ch 44100Hz SUSPENDED
3 alsa_input.pci-0000_0b_00.4.analog-stereo module-alsa-card.c s16le 2ch 44100Hz SUSPENDED
23 alsa_input.usb-JOUNIVO_JV601_JOUNIVO_JV601_20180508-00.analog-stereo module-alsa-card.c s16le 2ch 44100Hz RUNNING
24 alsa_input.usb-HDA_Webcam_USB_HDA_Webcam_USB_HDA_Webcam_USB-02.iec958-stereo module-alsa-card.c s16le 2ch 44100Hz RUNN
And then:
pactl set-default-sink 'alsa_input.usb-JOUNIVO_JV601_JOUNIVO_JV601_20180508-00.analog-stereo'
Any advice on what I may be doing wrong would be highly appreciated.
[The following commands also yield No such entity]
pactl set-default-sink alsa_input.usb-JOUNIVO_JV601_JOUNIVO_JV601_20180508-00.analog-stereo
pactl set-default-sink "alsa_input.usb-JOUNIVO_JV601_JOUNIVO_JV601_20180508-00.analog-stereo
