Writing this from an older Dell Notebook, ugpraded to 12.04 32-Bit, which works well.
My more modern Dell Notebook worked well for 1/2 day after upgrading to 12.04 64-Bit, now I'm having problems logging in:
System boots normally, (Unity) can enter my password, the login-screen reports 'Logging in....', but that's the end, won't log in even after 30 minutes - it just stays on the login screen. Same for guest login.
Console log in works well and quick. Checked Xorg.0.log.old, but didn't see an error message. The user:group for my home directory is correct. An fsck didn't find any errors.
Will need to find out how to mount an USB stick from command line, sure you'll want me to upload log files...
Thanks tino
david6
  • 14,528
  • 38
  • 46
I found that when I set: Ubuntu Tweak, Login Settings, "Set the same background as the current desktop background" (I also have "Draw Grid" ON, but that was ON before), the login screen then actually does not show my current background but the purple default - however, when before it took me 2-4 cycles of shutdown/login to actually log in, with the changes I was able to login 5x in a row without problems.
I quote: System boots normally, (Unity) can enter my password, the login-screen reports 'Logging in....', but that's the end, won't log in even after 30 minutes - it just stays on the login screen. Same for guest login.
I found a silly solution: Don't press ENTER after your login password but press the character > at the end of the button.
I am using Dell Vostro 3350 laptop. Dual boot Windows 7 and Ubuntu 12.04 64 bit (Fresh install).
Same problem at login screen. After keying in password and pressing enter, stuck indefinitely at "Logging in".
Using mouse to click the arrow instead of pressing enter did not work for me.
If key in a wrong password on purpose, system recognises the wrong password immediately. Shows "Invalid password, please try again".
Guest account is stuck at "Logging in" as well.
Update: after a few reboots, login works. then problem return at next reboot.
Update2: I gave up. Did a fresh install of Ubuntu 12.04, and problem has not resurface since.
After the SW-Update this morning (which included Xorg components), the problem seems to be gone. Reverted my login-screen settings and was able to login a couple of times without any problems. Will observe over the coming days, but expect no more problems.
