I updated my system to Ubuntu 12.04. It was running great. I decide to download Ubuntu Tweak and do some housecleaning. After reboot when I try to login nothing happens except a "Logging in" message. This happens with all options including Gnome 3.4.
What should I do?
Jorge Castro
  • 73,717
chazdg
  • 575
It happened to me too. use gdm to replace lightdm
  1. go to a text terminal using alt-ctrl-F1
  2. Stop LightDM with sudo stop lightdm
  3. Start GDM with sudo start gdm
  4. Run sudo dpkg-reconfigure lightdm to set the default display manager for gdm
  5. Edit /etc/X11/default-display-manager and set it to /usr/sbin/gdm if you can't run the above
  6. Restart your computer and login.
I found that when I set: Ubuntu Tweak, Login Settings, "Set the same background as the current desktop background" (I also have "Draw Grid" ON, but that was ON before), the login screen then actually does not show my current background but the purple default - however, when before it took me 2-4 cycles of shutdown/login to actually log in, with the changes I was able to login 5x in a row without problems.
Wonder whether this will work for you as well.
In my own question thread After upgrade to 12.04, hanging in login screen , Roberto says not to hit ENTER but to press the > icon (I assume he doesn't mean the > key on the keyboard). Can't test it since I've stored my notebook in the office, going an a 1 week vacation...
Hope it works for you....l
