I have an Acer E5-574-307M notebook and I have Ubuntu 20.04 installed but it cannot recognize my headset microphone (Xiaomi Piston 3).
I searched the internet and found these possible solutions:
  1. Edit the file /etc/modprobe.d/alsa-base.conf and add this command to the last line: options snd-hda-intel model=dell-headset-multi. However, it didn't work!
  2. rm -rf ~/.config/pulse/ and then restart the pc. However, it didn't work!
  3. Use cat /proc/asound/card0/codec# | grep Codec to find out what the audio codec is and enter in this website to find out what the configuration is (alc255-acer, in my case). After knowing the configuration, enter the command: options snd-hda-intel model=alc255-acer in the file: /etc/modprobe.d/alsa-base.conf and restart the PC. However, it didn't work!
P.S: This notebook only has one P2 input for the phone and microphone.
Zanna
  • 72,312
This question is possible to duplicate of the question from here -> Headset microphone not working on Ubuntu 20.04 If not, try these steps:
Yeppii
  • 126
You need to add the following commands in /etc/modprobe.d/alsa-base.conf.
options snd-hda-intel dmic_detect=0
Now, reboot.
This will disable the internal mic and detect the external headset mic.
This worked on Acer Aspire 5 A514-54.
I had the same issue in my lenovo ideapad 135
I have added below lines to /etc/modprobe.d/alsa-base.conf
 options snd-hda-intel model=headset-mode
Reboot your system once after adding above lines
tinlyx
  • 3,328
Thanks to the answer above for Acer A514!
This helped, despite my codec is alc256. When I tried model=alc256-acer it stopped working.
CCargo
