Installed ubuntu 20.04 on a usb stick then used that to create a full ubuntu installation on a usb stick with 3 partitions swap, /boot & ex4 with a "/"
Now the usb stick works well on the same laptop used to install ubuntu but on other machines it does not work it shows a blinking cursor on the left corner with a blank screen please help :)
There can be different causes of this problem:
  • You installed the bootloader into the internal drive. This can be avoided if you unplug, disconnect or otherwise disable the internal drive during the installation to the external drive.
  • There is no hardware driver for the other computer(s). This can happen for example if you install a proprietary graphics driver, that does not work in the other computer(s) and blocks the built-in linux driver that should be used.
See the following links,
sudodus
  • 47,684
