I have upgraded from ubuntu 16 LTS to 18 to 20 recently. Works nicely. My version is Ubuntu 20.04.1 LTS
Now my nextcloud client lets me know it needs an update with a pop-up. When I follow the pop-up it downloads an appimage form this link https://download.nextcloud.com/desktop/releases/Linux/Nextcloud-2.6.5-x86_64.AppImage
All good and fine, but after the download that file sits in my download folder. How do I get it "installed" so it becomes the new version?
My ps lists this:
$ ps waux | egrep next
hanscees    2414  0.1  2.0 1718460 157308 ?      SLl  14:48   0:02 /usr/bin/nextcloud
Should I move the appimage to that binary or something, and why doesnt it update automagically?
Make the appimage file as executable file and run it.
chmod +x name_of_the_appimage_file
So after searching longer, I found out the best way to update the nextcloud agent, at least if you also want integration in ubuntu 20.x. You shouldnt use an appimage at all. You can of course, but better integration is possible using apt.
You are supposed to use an apt-get PPA like is described here: https://launchpad.net/~nextcloud-devs/+archive/ubuntu/client
Probably, after the upgrade to ubuntu 20.x this PPA needs to be added (again).
I thought I needed the appimage because the old version of the nextcloud version shows a pop-up saying you should download an appimage.
And probably also my conclusion is ubuntu has no proper way to run appimages as a service, as I wanted to, since the client should run after every boot.
-1
What is an "AppImage"? How do I install it?
here the answer your question maybe mark as duplicate since the link shows how to install appimage , you can save lot of time if you google stuff than ask a whole question and wait for answer
also here step change permission of app image to executable chmod +x < appname >
./< appname >
edit:
You want to run from anywhere you can simply write bash script or copy your appimage choose which one is suitable for you here sample script
#!/bin/sh /Path/to/appimage/appimage
and save this file as any name you want to /usr/bin or /usr/local/bin dir
Change permission to allow this to execute by
chmod +x /usr/bin/script-name
You need sudo permission to execute command
after you can execute any where you want
also check following
https://stackoverflow.com/questions/14637979/how-to-permanently-set-path-on-linux-unix \
How do I add a custom launcher?
there one more trick you can direcly link appimage
ln < app image> /usr/bin/
