34
I need to use NVIDIA drivers, and I used the nvidia-smi command to check which NVIDIA I have, but this was the output:
Command 'nvidia-smi' not found, but can be installed with:
sudo apt install nvidia-utils-390 # version 390.138-0ubuntu0.19.10.1, or sudo apt install nvidia-utils-440 # version 440.100-0ubuntu0.19.10.1 sudo apt install nvidia-340 # version 340.107-0ubuntu7 sudo apt install nvidia-utils-430 # version 430.50-0ubuntu2 sudo apt install nvidia-utils-435 # version 435.21-0ubuntu2
Any clue which one to install?
I am running on Ubuntu Live on a Lenovo Ideapad 130S (11), but let me know if you need any more information about my system
To check which is the recommended driver for your Nvidia card run:
ubuntu-drivers devices
If you want to install the driver automatically, run :
sudo ubuntu-drivers autoinstall
If you want to install a specific driver version (410, 440...), run:
sudo apt install nvidia-<driver number>
Once the installation is finished, restart your PC.
Then run prime-select query to check which graphic card is being used by your device.
If you want to change the graphic card used by your PC, run : sudo prime-select <intel/ nvidia>; choose between Nvidia and Intel graphic cards.
After that, restart your PC to apply changes
singrium
  • 7,320
