11
I began by trying to install xubuntu-desktop, and then tried xfce4, and other packages (like GIMP) on a freshly installed Ubuntu Server 20.04 on my Raspberry Pi 4 but apt reported that it couldn't find these packages. This is very similar to another report here: Apt can't find package libasound2-dev 20.04 arm64
I would add a comment to that post, but I don't yet have enough reputation to comment. But I figured it's important enough to share here again and bring up the question:
QUESTION: What could cause some of the files in /var/lib/apt/lists/ to be of zero size?
I suppose if I reset my RPI4 during the first couple minutes of the initial boot (display issues)... Could this cause unattended-upgrades to fail to complete or download package/repo data, for example?
To be clear, I also have all the default repositories enabled in /etc/apt/sources.list:
deb http://ports.ubuntu.com/ubuntu-ports focal main restricted
deb http://ports.ubuntu.com/ubuntu-ports focal-updates main restricted
deb http://ports.ubuntu.com/ubuntu-ports focal universe
deb http://ports.ubuntu.com/ubuntu-ports focal-updates universe
deb http://ports.ubuntu.com/ubuntu-ports focal multiverse
deb http://ports.ubuntu.com/ubuntu-ports focal-updates multiverse
deb http://ports.ubuntu.com/ubuntu-ports focal-backports main restricted universe multiverse
deb http://ports.ubuntu.com/ubuntu-ports focal-security main restricted
deb http://ports.ubuntu.com/ubuntu-ports focal-security universe
deb http://ports.ubuntu.com/ubuntu-ports focal-security multiverse
Ultimately, when I ran the following (deleting all the lists) and tried again as suggested, I was able to locate all the packages I desired:
sudo apt-get clean
sudo apt-get autoclean
sudo rm -rf /var/lib/apt/lists/
sudo apt update
Yes, this is an ancient question, but the "got it to work" answer isn't correct.
sudo nano /etc/apt/sources.list
append these to the bottom of the file
deb [arch=arm64] http://ports.ubuntu.com/ focal main multiverse universe
deb [arch=arm64] http://ports.ubuntu.com/ focal-security main multiverse universe
deb [arch=arm64] http://ports.ubuntu.com/ focal-backports main multiverse universe
deb [arch=arm64] http://ports.ubuntu.com/ focal-updates main multiverse universe
Exit and save.
sudo dpkg --print-foreign-architectures
sudo dpkg --add-architecture arm64
You should now see arm64 in your list of foreign architectures
sudo apt-get update
You should see quite a few arm64 entries listed. There will be a few "404 not found" as repos move around. The problem is that many of the development packages for arm64 (notably libx11-dev) are in "ports"
I don't like to answer this way but use Debian instead of Ubuntu in this case.
I had a similar problem and only managed to fix it by using Debian 12.
t7e
  • 298
