25
I'm running Ubuntu 18.04.1 LTS and I'm trying to update things on my system. I've tried running:
sudo apt-get update
Which produces a few 404 errors:
sudo apt-get update
Ign:1 http://dl.google.com/linux/chrome/deb stable InRelease
Hit:2 http://dl.google.com/linux/chrome/deb stable Release
Hit:3 https://packages.microsoft.com/repos/vscode stable InRelease
Hit:8 http://ppa.launchpad.net/graphics-drivers/ppa/ubuntu bionic InRelease
Hit:9 http://ppa.launchpad.net/nilarimogard/webupd8/ubuntu bionic InRelease
Get:5 http://us.archive.ubuntu.com/ubuntu bionic InRelease [242 kB]
Get:7 http://security.ubuntu.com/ubuntu bionic-security InRelease [88.7 kB]
Get:6 http://us.archive.ubuntu.com/ubuntu bionic-updates InRelease [88.7 kB]
Hit:10 http://ppa.launchpad.net/webupd8team/java/ubuntu bionic InRelease
Get:11 http://us.archive.ubuntu.com/ubuntu bionic/main i386 Packages [1,007 kB]
Get:12 http://us.archive.ubuntu.com/ubuntu bionic/main arm64 Packages [975 kB]
Get:21 http://security.ubuntu.com/ubuntu bionic-security/main amd64 Packages [295 kB]
Get:22 http://security.ubuntu.com/ubuntu bionic-security/main arm64 Packages [212 kB]
Ign:22 http://security.ubuntu.com/ubuntu bionic-security/main arm64 Packages
Ign:47 http://security.ubuntu.com/ubuntu bionic-security/restricted arm64 Packages
Ign:49 http://security.ubuntu.com/ubuntu bionic-security/universe arm64 Packages
Ign:12 http://us.archive.ubuntu.com/ubuntu bionic/main arm64 Packages
Ign:78 http://security.ubuntu.com/ubuntu bionic-security/multiverse arm64 Packages
Ign:79 http://us.archive.ubuntu.com/ubuntu bionic/restricted arm64 Packages
Ign:80 http://us.archive.ubuntu.com/ubuntu bionic/universe arm64 Packages
Ign:81 http://us.archive.ubuntu.com/ubuntu bionic/multiverse arm64 Packages
Ign:82 http://us.archive.ubuntu.com/ubuntu bionic-updates/main arm64 Packages
Ign:83 http://us.archive.ubuntu.com/ubuntu bionic-updates/restricted arm64 Packages
Ign:84 http://us.archive.ubuntu.com/ubuntu bionic-updates/universe arm64 Packages
Ign:85 http://us.archive.ubuntu.com/ubuntu bionic-updates/multiverse arm64 Packages
Err:22 http://security.ubuntu.com/ubuntu bionic-security/main arm64 Packages
  404  Not Found [IP: 91.189.88.149 80]
Err:12 http://us.archive.ubuntu.com/ubuntu bionic/main arm64 Packages
  404  Not Found [IP: 91.189.91.23 80]
Err:82 http://us.archive.ubuntu.com/ubuntu bionic-updates/main arm64 Packages
Fetched 419 kB in 4s (104 kB/s)
Reading package lists... Done
E: Failed to fetch http://us.archive.ubuntu.com/ubuntu/dists/bionic/main/binary-arm64/Packages  404  Not Found [IP: 91.189.91.23 80]
E: Failed to fetch http://security.ubuntu.com/ubuntu/dists/bionic-security/main/binary-arm64/Packages  404  Not Found [IP: 91.189.88.149 80]
E: Failed to fetch http://us.archive.ubuntu.com/ubuntu/dists/bionic-updates/main/binary-arm64/Packages  404  Not Found [IP: 91.189.91.23 80]
E: Some index files failed to download. They have been ignored, or old ones used instead.
Then sudo apt-get upgrade seems to think nothing exists:
tombot@Magma-Core-Kernel:~$ sudo apt-get upgrade
Building dependency tree
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Also --fix-missing doesn't help. I've tried upgrading the distro with
sudo apt-get dist-upgrade
But this gives the same result as "sudo apt-get upgrade"
I'm able to ping 91.189.91.26 just fine:
ping 91.189.91.26
PING 91.189.91.26 (91.189.91.26) 56(84) bytes of data.
64 bytes from 91.189.91.26: icmp_seq=1 ttl=47 time=79.6 ms
I tried downloading a new sources.list file, but I still get:
E: Failed to fetch http://security.ubuntu.com/ubuntu/dists/bionic-security/main/binary-arm64/Packages  404  Not Found [IP: 91.189.91.23 80]
E: Failed to fetch http://us.archive.ubuntu.com/ubuntu/dists/bionic/main/binary-arm64/Packages  404  Not Found [IP: 91.189.91.26 80]
E: Failed to fetch http://us.archive.ubuntu.com/ubuntu/dists/bionic-updates/main/binary-arm64/Packages  404  Not Found [IP: 91.189.91.26 80]
Also, this is my first StackExchange post, so I hope I've done everything right with my post..
Thanks!
TomBot
  • 253
5 Answers5
16
The problem you're facing is basically a problem to reach the IP 91.189.91.26, try restarting your Internet connection and check if you can ping the IP address using this command:
ping 91.189.91.26
In my case it works correctly.
If nothing works for you, try changing the mirror you're using to get the updates:
Open your sources.list file using your favorite text editor, in my case nano.
sudo nano /etc/apt/sources.list
Locate the text
and replace it with
http://archive.ubuntu.com/ubuntu
And then run:
sudo apt update && sudo apt upgrade
If it still doesn't work, you might try a distribution update:
If still not working, this is what I've found here
Run the following command to update archive.ubuntu.com and security.ubuntu.com package repository URLs with old-releases.ubuntu.com. Since the normal Ubuntu releases link to the archive.XXX and security.XX URLs, the support will be removed after their live cycle of 9 months and respective repositories moved to old-releases.….
sudo sed -i -e 's/archive.ubuntu.com\|security.ubuntu.com/old-releases.ubuntu.com/g' /etc/apt/sources.list
Good luck.
A slightly different solution; If this is happening when you build a docker Dockerfile with Ubuntu, using a command similar to docker build -t "localhost:5000/blahblah" . then it's due to the sources.list being cached and being obsolete. To fix this, use the no-cache switch, like so docker build --no-cache -t "localhost:5000/blahblah" ..
Alex
  • 161
Partial answer...
From the comments...
The user is having problems updating their software repositories.
/etc/apt/sources.list and /etc/apt/sources.list.d/*.list files have been modified. They have references to a non-existent arm64 repo.
/etc/apt/sources.list has been replaced with a standard 18.04 version. The errors are decreased.
We're searching /etc/apt/sources.list.d/*.list files for "binary-arm64" errors now.
Update #1:
The new /etc/apt/sources.list has some wrong stuff. Do these to fix it...
sudo chown root:root /etc/apt/sources.list
sudo chmod 644 /etc/apt/sources.list
Then lets do a gross search for arm64...
sudo grep -r arm64 /etc/apt
Update #2:
Ubuntu was reinstalled, and everything is working fine again, including Virtualbox.
heynnema
  • 73,649
I haven't installed a ladder, so I met the 404,too. After I deselected checkboxes which is before 'http://us...' in 'Software & Updates' > 'Other Software', click button 'close' then 'reload', I could use sudo apt-get update with no error
cocomac
  • 3,824
noob
For cross-compiling (e.g. arm64) on distributions that use backports, this solution is needed: https://askubuntu.com/a/1372223/412004.
WARNING: As a word of caution, this causes some unexpected issues with apt, please use with caution!
Quoting:
Yes, this is an ancient question, but the "got it to work" answer isn't correct.
append these to the bottom of the file
deb [arch=arm64] http://ports.ubuntu.com/ focal main multiverse universe
deb [arch=arm64] http://ports.ubuntu.com/ focal-security main multiverse universe
deb [arch=arm64] http://ports.ubuntu.com/ focal-backports main multiverse universe
deb [arch=arm64] http://ports.ubuntu.com/ focal-updates main multiverse universe
Exit and save.
sudo dpkg --print-foreign-architectures
sudo dpkg --add-architecture arm64
You should now see arm64 in your list of foreign architectures
sudo apt-get update
You should see quite a few arm64 entries listed. There will be a few "404 not found" as repos move around. The problem is that many of the development packages for arm64 (notably libx11-dev) are in "ports"
tresf
  • 1,072
