  1. wrote out the Ubuntu 24.04 LTS with rpi-imager to an USB SSD.
  2. It installed OK, working on a Raspberry Pi 5 with the USB SSD plugged in (microSD cards are weak..).
But if I issue a plain "apt-get update", then i get this:
# apt-get update
Hit:1 http://ports.ubuntu.com/ubuntu-ports noble InRelease
Get:2 http://archive.ubuntu.com/ubuntu noble InRelease [256 kB]
Get:3 http://archive.ubuntu.com/ubuntu noble-updates InRelease [89.7 kB]
Hit:4 http://archive.ubuntu.com/ubuntu noble-backports InRelease
Get:5 http://archive.ubuntu.com/ubuntu noble-security InRelease [89.7 kB]
Ign:6 http://archive.ubuntu.com/ubuntu noble/main arm64 Packages
Get:7 http://archive.ubuntu.com/ubuntu noble/main Translation-en [513 kB]
Get:8 http://archive.ubuntu.com/ubuntu noble/main arm64 Components [460 kB]
Get:9 http://archive.ubuntu.com/ubuntu noble/main Icons (48x48) [106 kB]
Get:10 http://archive.ubuntu.com/ubuntu noble/main Icons (64x64) [156 kB]
Get:11 http://archive.ubuntu.com/ubuntu noble/main Icons (64x64@2) [21.8 kB]
Get:12 http://archive.ubuntu.com/ubuntu noble/main arm64 c-n-f Metadata [30.0 kB]
Ign:13 http://archive.ubuntu.com/ubuntu noble/universe arm64 Packages
Get:14 http://archive.ubuntu.com/ubuntu noble/universe Translation-en [5982 kB]
Get:15 http://archive.ubuntu.com/ubuntu noble/universe arm64 Components [3573 kB]
Get:16 http://archive.ubuntu.com/ubuntu noble/universe Icons (48x48) [3717 kB]
Get:17 http://archive.ubuntu.com/ubuntu noble/universe Icons (64x64) [7747 kB]
Get:18 http://archive.ubuntu.com/ubuntu noble/universe Icons (64x64@2) [75.0 kB]
Get:19 http://archive.ubuntu.com/ubuntu noble/universe arm64 c-n-f Metadata [295 kB]
Ign:20 http://archive.ubuntu.com/ubuntu noble/restricted arm64 Packages
Get:21 http://archive.ubuntu.com/ubuntu noble/restricted Translation-en [18.7 kB]
Get:22 http://archive.ubuntu.com/ubuntu noble/restricted arm64 c-n-f Metadata [412 B]
Ign:23 http://archive.ubuntu.com/ubuntu noble/multiverse arm64 Packages
Get:24 http://archive.ubuntu.com/ubuntu noble/multiverse Translation-en [118 kB]
Get:25 http://archive.ubuntu.com/ubuntu noble/multiverse arm64 Components [31.6 kB]
Get:26 http://archive.ubuntu.com/ubuntu noble/multiverse Icons (48x48) [56.1 kB]
Get:27 http://archive.ubuntu.com/ubuntu noble/multiverse Icons (64x64) [186 kB]
Get:28 http://archive.ubuntu.com/ubuntu noble/multiverse Icons (64x64@2) [904 B]
Get:29 http://archive.ubuntu.com/ubuntu noble/multiverse arm64 c-n-f Metadata [7152 B]
Ign:30 http://archive.ubuntu.com/ubuntu noble-updates/main arm64 Packages
Get:31 http://archive.ubuntu.com/ubuntu noble-updates/main Translation-en [6704 B]
Get:32 http://archive.ubuntu.com/ubuntu noble-updates/main arm64 c-n-f Metadata [108 B]
Ign:33 http://archive.ubuntu.com/ubuntu noble-updates/universe arm64 Packages
Get:34 http://archive.ubuntu.com/ubuntu noble-updates/universe Translation-en [4524 B]
Get:35 http://archive.ubuntu.com/ubuntu noble-updates/universe arm64 c-n-f Metadata [112 B]
Get:36 http://archive.ubuntu.com/ubuntu noble-updates/restricted arm64 c-n-f Metadata [116 B]
Get:37 http://archive.ubuntu.com/ubuntu noble-updates/multiverse arm64 c-n-f Metadata [116 B]
Ign:38 http://archive.ubuntu.com/ubuntu noble-security/main arm64 Packages
Get:39 http://archive.ubuntu.com/ubuntu noble-security/main Translation-en [6544 B]
Get:40 http://archive.ubuntu.com/ubuntu noble-security/main arm64 c-n-f Metadata [108 B]
Ign:41 http://archive.ubuntu.com/ubuntu noble-security/universe arm64 Packages
Get:42 http://archive.ubuntu.com/ubuntu noble-security/universe Translation-en [3672 B]
Get:43 http://archive.ubuntu.com/ubuntu noble-security/universe arm64 c-n-f Metadata [112 B]
Get:44 http://archive.ubuntu.com/ubuntu noble-security/restricted arm64 c-n-f Metadata [116 B]
Get:45 http://archive.ubuntu.com/ubuntu noble-security/multiverse arm64 c-n-f Metadata [116 B]
Err:6 http://archive.ubuntu.com/ubuntu noble/main arm64 Packages
  404  Not Found [IP: 2620:2d:4002:1::102 80]
Err:30 http://archive.ubuntu.com/ubuntu noble-updates/main arm64 Packages
Err:38 http://archive.ubuntu.com/ubuntu noble-security/main arm64 Packages
Fetched 23.6 MB in 4s (5503 kB/s)
** (appstreamcli:3555): WARNING **: 15:24:19.985: No origin found for file ports.ubuntu.com_ubuntu-ports_dists_noble_main_dep11_Components-arm64.yml.gz
** (appstreamcli:3555): WARNING **: 15:24:19.985: No origin found for file ports.ubuntu.com_ubuntu-ports_dists_noble_universe_dep11_Components-arm64.yml.gz
** (appstreamcli:3555): WARNING **: 15:24:19.985: No origin found for file ports.ubuntu.com_ubuntu-ports_dists_noble_multiverse_dep11_Components-arm64.yml.gz Reading package lists... Done E: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/noble/main/binary-arm64/Packages 404 Not Found [IP: 2620:2d:4002:1::102 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/noble-updates/main/binary-arm64/Packages 404 Not Found [IP: 2620:2d:4002:1::102 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/noble-security/main/binary-arm64/Packages 404 Not Found [IP: 2620:2d:4002:1::102 80] E: Some index files failed to download. They have been ignored, or old ones used instead.
The Question: is this a temporary issue? Or manual workaround needed as permanent fix? I don't think this is normal. They are missing the ARM64 packages in Ubuntu 24 LTS?
I sent mail to the official mirror bug mail: [rt.ubuntu.com #82727] - will update if they reply.
Using the default config.. eg.: apt sources:
# cat ubuntu.sources
Types: deb
URIs: http://archive.ubuntu.com/ubuntu/
Suites: noble noble-updates noble-backports
Components: main universe restricted multiverse
Signed-By: /usr/share/keyrings/ubuntu-archive-keyring.gpg
Ubuntu security updates. Aside from URIs and Suites,
this should mirror your choices in the previous section.
Types: deb URIs: http://archive.ubuntu.com/ubuntu/ Suites: noble-security Components: main universe restricted multiverse Signed-By: /usr/share/keyrings/ubuntu-archive-keyring.gpg
If i use the find_mirros script from Are there alternative repositories to ports.ubuntu.com for ARM? then the best looks like "http://ubuntu.macarne.com/ubuntu/", the output:
# apt-get clean
# apt-get update
Get:2 https://ubuntu.macarne.com/ubuntu noble InRelease [256 kB]
Get:3 https://ubuntu.macarne.com/ubuntu noble-updates InRelease [89.7 kB]
Hit:4 https://ubuntu.macarne.com/ubuntu noble-backports InRelease
Get:5 https://ubuntu.macarne.com/ubuntu noble-security InRelease [89.7 kB]
Ign:6 https://ubuntu.macarne.com/ubuntu noble/main arm64 Packages
Get:7 https://ubuntu.macarne.com/ubuntu noble/main Translation-en [513 kB]
Get:8 https://ubuntu.macarne.com/ubuntu noble/main arm64 Components [460 kB]
Get:9 https://ubuntu.macarne.com/ubuntu noble/main Icons (48x48) [106 kB]
Get:10 https://ubuntu.macarne.com/ubuntu noble/main Icons (64x64) [156 kB]
Get:11 https://ubuntu.macarne.com/ubuntu noble/main Icons (64x64@2) [21.8 kB]
Get:12 https://ubuntu.macarne.com/ubuntu noble/main arm64 c-n-f Metadata [30.0 kB]
Ign:13 https://ubuntu.macarne.com/ubuntu noble/universe arm64 Packages
Get:14 https://ubuntu.macarne.com/ubuntu noble/universe Translation-en [5982 kB]
Get:15 https://ubuntu.macarne.com/ubuntu noble/universe arm64 Components [3573 kB]
Get:16 https://ubuntu.macarne.com/ubuntu noble/universe Icons (48x48) [3717 kB]
Get:17 https://ubuntu.macarne.com/ubuntu noble/universe Icons (64x64) [7747 kB]
Get:18 https://ubuntu.macarne.com/ubuntu noble/universe Icons (64x64@2) [75.0 kB]
Get:19 https://ubuntu.macarne.com/ubuntu noble/universe arm64 c-n-f Metadata [295 kB]
Ign:20 https://ubuntu.macarne.com/ubuntu noble/restricted arm64 Packages
Get:21 https://ubuntu.macarne.com/ubuntu noble/restricted Translation-en [18.7 kB]
Get:22 https://ubuntu.macarne.com/ubuntu noble/restricted arm64 c-n-f Metadata [412 B]
Ign:23 https://ubuntu.macarne.com/ubuntu noble/multiverse arm64 Packages
Get:24 https://ubuntu.macarne.com/ubuntu noble/multiverse Translation-en [118 kB]
Get:25 https://ubuntu.macarne.com/ubuntu noble/multiverse arm64 Components [31.6 kB]
Get:26 https://ubuntu.macarne.com/ubuntu noble/multiverse Icons (48x48) [56.1 kB]
Get:27 https://ubuntu.macarne.com/ubuntu noble/multiverse Icons (64x64) [186 kB]
Get:28 https://ubuntu.macarne.com/ubuntu noble/multiverse Icons (64x64@2) [904 B]
Get:29 https://ubuntu.macarne.com/ubuntu noble/multiverse arm64 c-n-f Metadata [7152 B]
Ign:30 https://ubuntu.macarne.com/ubuntu noble-updates/main arm64 Packages
Get:31 https://ubuntu.macarne.com/ubuntu noble-updates/main Translation-en [6704 B]
Get:32 https://ubuntu.macarne.com/ubuntu noble-updates/main arm64 c-n-f Metadata [108 B]
Ign:33 https://ubuntu.macarne.com/ubuntu noble-updates/universe arm64 Packages
Get:34 https://ubuntu.macarne.com/ubuntu noble-updates/universe Translation-en [4524 B]
Get:35 https://ubuntu.macarne.com/ubuntu noble-updates/universe arm64 c-n-f Metadata [112 B]
Get:36 https://ubuntu.macarne.com/ubuntu noble-updates/restricted arm64 c-n-f Metadata [116 B]
Get:37 https://ubuntu.macarne.com/ubuntu noble-updates/multiverse arm64 c-n-f Metadata [116 B]
Ign:38 https://ubuntu.macarne.com/ubuntu noble-security/main arm64 Packages
Get:39 https://ubuntu.macarne.com/ubuntu noble-security/main Translation-en [6544 B]
Get:40 https://ubuntu.macarne.com/ubuntu noble-security/main arm64 c-n-f Metadata [108 B]
Ign:41 https://ubuntu.macarne.com/ubuntu noble-security/universe arm64 Packages
Get:42 https://ubuntu.macarne.com/ubuntu noble-security/universe Translation-en [3672 B]
Get:43 https://ubuntu.macarne.com/ubuntu noble-security/universe arm64 c-n-f Metadata [112 B]
Get:44 https://ubuntu.macarne.com/ubuntu noble-security/restricted arm64 c-n-f Metadata [116 B]
Get:45 https://ubuntu.macarne.com/ubuntu noble-security/multiverse arm64 c-n-f Metadata [116 B]
Ign:6 http://ubuntu.macarne.com/ubuntu noble/main arm64 Packages
Ign:13 http://ubuntu.macarne.com/ubuntu noble/universe arm64 Packages
Ign:20 http://ubuntu.macarne.com/ubuntu noble/restricted arm64 Packages
Ign:23 http://ubuntu.macarne.com/ubuntu noble/multiverse arm64 Packages
Ign:30 http://ubuntu.macarne.com/ubuntu noble-updates/main arm64 Packages
Ign:33 http://ubuntu.macarne.com/ubuntu noble-updates/universe arm64 Packages
Ign:38 http://ubuntu.macarne.com/ubuntu noble-security/main arm64 Packages
Ign:41 http://ubuntu.macarne.com/ubuntu noble-security/universe arm64 Packages
Err:6 http://ubuntu.macarne.com/ubuntu noble/main arm64 Packages
  404  Not Found [IP: 2602:2ea::93 443]
37% [Waiting for headers]        3860 kB/s 20sE: Transaction http://ubuntu.macarne.com/ubuntu/dists/noble/InRelease was already aborted and is aborted again
Err:13 http://ubuntu.macarne.com/ubuntu noble/universe arm64 Packages
Err:30 http://ubuntu.macarne.com/ubuntu noble-updates/main arm64 Packages
37% [Waiting for headers]        3860 kB/s 20sE: Transaction http://ubuntu.macarne.com/ubuntu/dists/noble-updates/InRelease was already aborted and is aborted again
Err:33 http://ubuntu.macarne.com/ubuntu noble-updates/universe arm64 Packages
Err:38 http://ubuntu.macarne.com/ubuntu noble-security/main arm64 Packages
E: Transaction http://ubuntu.macarne.com/ubuntu/dists/noble-security/InRelease was already aborted and is aborted again
Err:41 http://ubuntu.macarne.com/ubuntu noble-security/universe arm64 Packages
# apt-get install gimp
Building dependency tree... Done
E: Unable to locate package gimp
if i try to use the "https://ports.ubuntu.com/ubuntu/" then:
# apt-get clean
# apt-get update
Ign:2 https://ports.ubuntu.com/ubuntu noble InRelease
Ign:3 https://ports.ubuntu.com/ubuntu noble-updates InRelease
Ign:4 https://ports.ubuntu.com/ubuntu noble-backports InRelease
Ign:5 https://ports.ubuntu.com/ubuntu noble-security InRelease
Err:2 https://ports.ubuntu.com/ubuntu noble InRelease
  Could not connect to ports.ubuntu.com:443 (2620:2d:4000:1::19). - connect (111: Connection refused) Could not connect to ports.ubuntu.com:443 (185.125.190.39). - connect (111: Connection refused) Could not connect to ports.ubuntu.com:443 (2620:2d:4000:1::16). - connect (111: Connection refused) Could not connect to ports.ubuntu.com:443 (185.125.190.36). - connect (111: Connection refused)
Err:3 https://ports.ubuntu.com/ubuntu noble-updates InRelease
  Unable to connect to ports.ubuntu.com:https:
Err:4 https://ports.ubuntu.com/ubuntu noble-backports InRelease
Err:5 https://ports.ubuntu.com/ubuntu noble-security InRelease
W: Failed to fetch https://ports.ubuntu.com/ubuntu/dists/noble/InRelease  Could not connect to ports.ubuntu.com:443 (2620:2d:4000:1::19). - connect (111: Connection refused) Could not connect to ports.ubuntu.com:443 (185.125.190.39). - connect (111: Connection refused) Could not connect to ports.ubuntu.com:443 (2620:2d:4000:1::16). - connect (111: Connection refused) Could not connect to ports.ubuntu.com:443 (185.125.190.36). - connect (111: Connection refused)
W: Failed to fetch https://ports.ubuntu.com/ubuntu/dists/noble-updates/InRelease  Unable to connect to ports.ubuntu.com:https:
W: Failed to fetch https://ports.ubuntu.com/ubuntu/dists/noble-backports/InRelease  Unable to connect to ports.ubuntu.com:https:
W: Failed to fetch https://ports.ubuntu.com/ubuntu/dists/noble-security/InRelease  Unable to connect to ports.ubuntu.com:https:
W: Some index files failed to download. They have been ignored, or old ones used instead.
update: even usin plain https it is 404
# apt-get clean
# apt-get update
Ign:2 http://ports.ubuntu.com/ubuntu noble InRelease
Ign:3 http://ports.ubuntu.com/ubuntu noble-updates InRelease
Ign:4 http://ports.ubuntu.com/ubuntu noble-backports InRelease
Ign:5 http://ports.ubuntu.com/ubuntu noble-security InRelease
Err:6 http://ports.ubuntu.com/ubuntu noble Release
  404  Not Found [IP: 185.125.190.36 80]
Err:7 http://ports.ubuntu.com/ubuntu noble-updates Release
Err:8 http://ports.ubuntu.com/ubuntu noble-backports Release
Err:9 http://ports.ubuntu.com/ubuntu noble-security Release
E: The repository 'http://ports.ubuntu.com/ubuntu noble Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
E: The repository 'http://ports.ubuntu.com/ubuntu noble-updates Release' does not have a Release file.
E: The repository 'http://ports.ubuntu.com/ubuntu noble-backports Release' does not have a Release file.
E: The repository 'http://ports.ubuntu.com/ubuntu noble-security Release' does not have a Release file.
update: Paul Collins via RT:
The URL for the ports repository is as follows: http://ports.ubuntu.com/ubuntu-ports
but after updating, it is still bad.. https://pastebin.com/raw/wRqdNN1S same 404 issue like after the default install
peterK88
  • 151
Apt can't find packages on Ubuntu 20.04 arm64 (Raspberry Pi 4)
sudo apt-get clean
sudo apt-get autoclean
sudo rm -rf /var/lib/apt/lists/
sudo apt update
have repo as: http://ports.ubuntu.com/ubuntu-ports
peterK88
  • 151
ARM64 is inot in the main repos. It's in the ports repository.
Only amd64 and i386 architectures are in the main archive repositories. Use ports.ubuntu.com instead of archive.ubuntu.com in your source declarations. It should then behave.
Thomas Ward
  • 78,878
