My PPTP VPN works fine on Windows and Android. On Android and Windows, no specific configuration is needed only I need to check PPP encryption(MPPE).
But on Ubuntu 20.04 it disconnects randomly after a period of time.
pjsofts
  • 359
I found the answer here: Ubuntu 14 pptp client disconnects frequently.
I had to use on the client.
sudo ifconfig wlp3s0 mtu 1400
sudo ifconfig ppp0 mtu 1300
This could be investigated by reading syslog errors:
pouria@pouria-pc:~$ cat /var/log/syslog | grep pptp | grep long
May 31 09:36:11 pouria-pc pptp[18156]: nm-pptp-service-18147 warn[decaps_gre:pptp_gre.c:352]: short read (-1): Message too long
May 31 09:47:14 pouria-pc pptp[18617]: nm-pptp-service-18609 warn[decaps_gre:pptp_gre.c:352]: short read (-1): Message too long
May 31 09:57:18 pouria-pc pptp[19439]: nm-pptp-service-19430 warn[decaps_gre:pptp_gre.c:352]: short read (-1): Message too long
May 31 10:07:21 pouria-pc pptp[20790]: nm-pptp-service-20781 warn[decaps_gre:pptp_gre.c:352]: short read (-1): Message too long
May 31 10:17:57 pouria-pc pptp[21003]: nm-pptp-service-20994 warn[decaps_gre:pptp_gre.c:352]: short read (-1): Message too long
May 31 11:16:36 pouria-pc pptp[23730]: nm-pptp-service-23718 warn[decaps_gre:pptp_gre.c:352]: short read (-1): Message too long
By setting mtu we are telling the wlan to use smaller messages.
I wonder why users of other operating systems don't have to configure their WLAN message size to use the simplest form of VPN.
update
To do it permanently
Find your device's interface name wlan0... by ifconfig.
Create the file /etc/network/if-up.d/ppp with the following content:
#! /bin/bash
sudo ifconfig wlp0s20f3 mtu 1400
Use chmod +x /etc/network/if-up.d/ppp to make it executable. It runs on every connect and disconnect.
pjsofts
  • 359
I use your answer, and answer it to solve the question about Set the MTU permanently:
I found this link (for permanent set the MTU)
We make a script in /etc/network/if-up.d/ and call it set-pptp.sh, this script will be called whenever a link is trying to get up.
Now inside this file we insert these lines:
[We are checking the current interface that is trying to get up, if it's a VPN, we set its MTU to 1300 and if not we set its MTU to 1400]
#!/bin/sh
if [ "$IFACE" = "ppp0" ]; then ifconfig ppp0 mtu 1300 fi
if [ "$IFACE" = "wlp3s0" ]; then ifconfig wlp3s0 mtu 1400 fi
Now we need to make it executable:
$ sudo chmod 755 /etc/network/if-up.d/set-pptp.sh
Last Step (Important):
If you are using a graphical network manager, those that are in KDE, Gnome, etc ..., you need to do this too:
Open this file: /etc/NetworkManager/dispatcher.d/01-ifupdown, in my computer, its name is 01-ifupdown, maybe in yours it has other names, open it.
Find the line that has something like this:
if [ "$2" = "vpn-up" ] || [ "$2" = "vpn-down" ]; then
Change it to this:
   ADDRESS_FAMILIES=""
fi
Done, you have a permanently MTU settings now.
SdSaati
  • 201
