19
I tried the shortcut Super + L nothing happens.
In the settings, have set lockdown timer for 1 min, nothings happens after that.
In the right corner menu after clicking lock item, it is showing black screen and logging me out.
gsettings get org.gnome.desktop.lockdown disable-lock-screen
shows false.
5 Answers5
28
I was having EXACTLY the same problem. It turns out I have several display managers installed, and I was using lightdm instead of gdm3.
You can confirm you are using lightdm if this command works:
$ dm-tool lock
(But even if that doesn't work you may be using another display manager.)
I got the screen blanking to work properly by configuring gdm3.
Open a terminal and issue this command:
$ sudo dpkg-reconfigure gdm3
Select gdm3 in the list on the terminal, then reboot your system.
I have the same gsettings get org.gnome.desktop.lockdown disable-lock-screen config and Super+L works
Could you check Settings > Keyboard Shortcuts > search(Super+L), this one should be assigned to lock the screen.
The lock is a feature of gnome-session. In your research maybe swap "ubuntu" for "gnome" or "gnome3.36.2" with a bit of luck you have the same as me ;)
Zanna
  • 72,312
Zoyolin
  • 69
I couldn't even get to "Settings" on my Ubuntu 20.04 box, probably because I've been updating the same hardware since 12.04.
First I had to run:
sudo apt-get install --reinstall gnome-control-center
... to get "Settings" back. Then I typed:
... to pull settings up.
While I had Settings up I right-clicked "Add to Favorites" on the toolbar to keep the Settings icon on my desktop.
After that I went to Settings > Privacy > Screen Lock to get at all of the settings.
Earl Ruby
  • 841
-1
Problem solved for me by going to
Settings > Screensaver > Lock Screen
and then deactivating Lock Screen.
Now everything works fine for me.
-1
Not the OP's case, but if your gsettings get org.gnome.desktop.lockdown disable-lock-screen shows true then you can change it with:
gsettings set org.gnome.desktop.lockdown disable-lock-screen false
I don't know what set that to false on my system, it was a fresh Ubuntu 23.10 install with GDB display manager.
